118
6,911
Skyjack Telehandler SJ1256THS Parts Manual 205154AF 2023
Brand: Skyjack
Type of Machine: Telehandler
Model: Skyjack SJ1256THS Telehandler
Serial Number: 87410001 to 87499999
Part Number: 205154AF
Publication Date: 2023
Number of Pages: 342 Pages
Section 1 – Main Frame
1.1 Sheet Metal
1.2 Frame Subgroup
1.3 Frame Subgroup - Dual tilt
1.4 Outriggers Group
1.5 Cowling Assembly
1.6 Steel Cowling
1.7 Fuel Tank
1.8 Hydraulic Tank
Section 2 – Axles
2.1 Front Axle
2.2 Front Axle - Internal Breakdown
2.3 Front Axle - Reduction Hub
2.4 Front Axle - Brakes
2.5 Front Axle - Steering
2.6 Front Axle - Trunion
2.7 Rear Axle
2.8 Rear Axle - Internal Breakdown
2.9 Rear Axle - Reduction Hub
2.10 Rear Axle - Brakes
2.11 Rear Axle - Steering
2.12 Rear Axle - Trunion
2.13 Drive Shaft
2.14 Tires and Wheels
Section 3 – Engine and Transmission
3.1 Engine Tray
3.2 Engine and Poweshift Transmission
3.3 Engine Components
3.4 Powershift Transmission - Housing & Case
3.5 Transmission - Gear Group
3.6 Transmission - Drive Plate, Torque Converter & Pump
3.7 Transmission - Forward & Reverse Group
3.8 Transmission - 1st, 2nd & 3rd Shaft
3.9 Transmission - Output Shaft & Control Group
3.10 Transmission - Drop Box
3.11 R1 & H1 Shaft Double Cone Assembly
3.12 Pump & Limit Switch Assembly
3.13 Fuel Lines
3.14 Air Intake System
3.15 Exhaust Aftertreatment System
3.16 DEF Lines
3.17 Cooling Package Style A
3.18 Cooler - Internal Breakdown
3.19 Cooling Package Style B
3.20 Cooling Package Style B - Internal Breakdown
3.21 Powershift Transmission Hydraulic Pump
Section 4 – Operator's Compartment
4.1 Cab Installation
4.2 Open Cab
4.3 Open Cab Side Window
4.4 Right Hand Console
4.5 Joystick Control
4.6 Joystick Control - Internal Breakdown
4.7 Premium Joystick
4.8 Front Console
4.9 LH Dash Panel
4.10 Flip Chart
4.11 RH Dash Panel
4.12 Steering Console
4.13 Main Relay
4.14 Fuse and Power
4.15 Relay RH
4.16 Enclosed Cab
4.17 Door Assembly
4.18 Cab Heater System
4.19 Cab A/C System
4.20 A/C Compressor
4.21 A/C Condenser
4.22 A/C Harness
4.23 A/C and Heater Harness
Section 5 – Electrical
5.1 Chassis Harness
5.2 Engine Harness
5.3 Console Harness
5.4 DEF Engine Harness
5.5 Low Fuel Pressure Harness
5.6 Alternator Cable Harness
5.7 Glow Plug Harness
5.8 Battery
5.9 Battery Disconnect
5.10 Battery Cables
5.11 Tilt Sensor
Section 6 – Boom
6.1 Boom Installation
6.2 Boom Installation - Dual Tilt
6.3 Boom Assembly
6.4 First Boom Section
6.5 Second Boom Section
6.6 Third Boom Section
6.7 Fourth Boom Section
6.8 Cable Carrier
6.9 Auxiliary Hydraulics
Section 7 – Cylinders
7.1 Extend Cylinder Components
7.2 Lift Cylinder Components
7.3 Fork Tilt Cylinder Components
7.4 Tilt Compensation Cylinder
7.5 Frame Level Cylinder Components
7.6 Outriggers Cylinder Assembly
7.7 RAS Cylinder Components
Section 8 – Hydraulics
8.1 Standard Hose Numbering System
8.2 Main Manifold Installation
8.3 Main Manifold Assembly
8.4 Manifold Components
8.5 Hydraulic Return Filter
8.6 Pressure Filter
8.7 Outriggers Manifold
8.8 Boom & Telescopic Hydraulic Hoses
8.9 Carriage Hydraulic Hoses
8.10 Carriage Hydraulic Hoses - Dual Tilt
8.11 Frame Level Hydraulic Hoses
8.12 Brakes & Steering Hydraulic Hoses
8.13 Hydraulic Pump Hoses
8.14 Hydraulic Pump Hoses - Pressure Filter
8.15 Cab Hydraulic Hoses
8.16 RAS Cylinder Hydraulic Hoses
8.17 Auxiliary Hydraulic Hoses
8.18 Outriggers Hydraulic Hoses
8.19 Auxiliary Manifold
Section 9 – Standard and Optional Attachments
9.1 Quick-Attach Carrier / Carriage & Forks
9.2 Quick-Attach Carrier / Carriage & Forks (Skyjack)
9.3 Side-Tilt Carriage
9.4 Side-Tilt Carriage Installation (Skyjack)
9.5 48'', 60'' & 72'' Side Tilt Carriage - Internal Breakdown
9.6 72'' Swing Carriage Installation
9.7 72'' Swing Carriage Components
9.8 Forks Positioner Carriage
9.9 Truss Boom 12' and 15'
9.10 Loader Bucket
9.11 2' Jib Boom
Section 10 – Factory Options
10.1 Boom Lights
10.2 Boom Lights Harness
10.3 Work Lights
10.4 Work Lights Harness
10.5 Road Lights
10.6 Road Lights Harness
10.7 Oil Quick Drain
10.8 Air Intake Shut Off
10.9 Air Intake Shut Off Harness
10.10 Remote Axle Grease
10.11 Reserve Brake
10.12 Cold Weather Package
10.13 4 Wheel Fender
10.14 Beacon Light Assembly
10.15 Pintle Hook
10.16 Fire Extinguisher
10.17 Backup Camera and Sensor
10.18 Back up Sensor
10.19 Elevate Telematic
10.20 Elevate Telematics Harness
Section 11 – Labels
11.1 Model Specific
11.2 Pictorial Group Labels
11.3 Cab Labels
11.4 Load Charts
Section 12 – Tables
12.1 Recommended Fluids
