118
6,911
Skyjack Rough Terrain Scissors SJ9664RT Parts Manual 239430AEA 2023
Brand: Skyjack
Type of Machine: Rough Terrain Scissors
Model: Skyjack SJ9664RT Rough Terrain Scissors
Serial Number: A203000001 - A203999999
Part Number: 239430AEA
Publication Date: 2023
Number of Pages: 236 Pages
Foreword
General
Parts Ordering Information
Method of Listing
Quantities
How To Order Repair Parts
Recommended Service Parts
Section 1 – Platform
1.1 Main Platform Deck
1.2 Main Platform Railings - Single Extension Deck
1.3 Main Platform Railings - Dual Extension Decks
1.4 Full Gate
1.5 Extension Deck Platform
1.6 Extension Deck Railings
1.7 Platform Control Box
1.8 Joystick
1.9 Power Outlet - ANSI/CSA
1.10 Power Outlet - CE/AS
Section 2 – Scissors
2.1 Scissor Assembly
2.2 Scissor Level 1/3
2.3 Scissor Level 2/4
2.4 Scissor Level Top
2.5 Center Pin
2.6 Centering Link
2.7 Lower Sliders
2.8 Upper Sliders
2.9 Lift Cylinder
2.10 Lift Cylinder Manifolds
2.11 Maintenance Stand
2.12 Scissor Electrical Components
Section 3 – Base
3.1 Chassis
3.2 Drive Shaft Guard & Counterweight
3.3 Lateral Bracket - Right Side
3.4 Lateral Bracket - Left Side
3.5 Axles
3.6 Differential - Front Axle
3.7 Hub Reduction - Front Axle
3.8 Central Housing - Front Axle
3.9 Steering - Front Axle
3.10 Differential - Rear Axle
3.11 Hub Reduction - Rear Axle
3.12 Brakes - Rear Axle
3.13 Gear Box - Rear Axle
3.14 Central Housing - Rear Axle
3.15 Drive Motor
3.16 Tires
3.17 Ladder
3.18 Fuel Tank
3.19 Outriggers
3.20 Outrigger Cylinder
3.21 Outrigger Limit Switches
3.22 GP401 Controller
3.23 Base Control Box Hardware
3.24 Base Control Box
3.25 Battery
3.26 Hydraulic Tank
3.27 Drive Manifold
3.28 Auxiliary Manifold
3.29 Pressure Reducing Manifold
3.30 Outrigger Manifold
Section 4 – Engine
4.1 Engine Cover Cage
4.2 Engine Covers
4.3 Engine - Kubota D1305
4.4 Air Intake - Kubota D1305
4.5 Exhaust - Kubota D1305
4.6 Pump - Kubota D1305
4.7 Bell Housing - Kubota D1305
4.8 Fuel Lines - Kubota D1305
4.9 Electrical Components - Kubota D1305
4.10 Engine - Kubota WG972
4.11 Air Intake - Kubota WG972
4.12 Exhaust - Kubota WG972
4.13 Regulator/Vaporizer - Kubota WG972
4.14 Pump - Kubota WG972
4.15 Bell Housing - Kubota WG972
4.16 Electrical Components - Kubota WG972
4.17 Fuel System - Kubota WG972
4.18 Propane Tank - Kubota WG972
Section 5 – Electrical Harnesses
5.1 Engine Harness - Kubota D1305
5.2 Fuse Box - Kubota D1305
5.3 Engine Harness - Kubota WG972
5.4 Positive Air Shut Off Harness
5.5 Fuel Pump Harness
5.6 ECU Power Harness
5.7 Control A Harness
5.8 Control B Harness
5.9 Base Control Cable
5.10 Platform to Base Control Cable
5.11 Drive Manifold Harness
5.12 Outrigger Manifold Harness
5.13 Outrigger Control Harness
5.14 Holding Valve Harnesses
5.15 Scissor Harness
5.16 GP401 Controller Harness
5.17 CANBUS Harness
5.18 Angle Transducer/Beeper/Flashing Light Harness
5.19 Load Cell Module Harness
5.20 Load Cell Module Power Harness
5.21 Load Cell Module CAN Harness
5.22 Platform Harness
5.23 Generator and Oil Cooler Harness
5.24 Generator Control Harness
Section 6 – Hose Connections
6.1 Standard Hose Numbering System
6.2 Hydraulic Hoses - Base
6.3 Hydraulic Hoses - Outriggers
6.4 Hydraulic Hoses - Scissors
Section 7 – Optional Equipment
7.1 Heavy Duty Pipe Rack
7.2 Tool Caddy
7.3 Material Handling Stand
7.4 Eco Start
7.5 Wire Loop Lock Pin
7.6 RCD Option
7.7 Belt-Driven Generator - 3.5 kW
7.8 Hydraulic Generator - 7.5 kW
7.9 Hydraulic Hoses - 7.5 kW Generator
7.10 Cold & Arctic Weather Packages
7.11 Arctic Weather Package
7.12 Elevate Telematics
7.13 Elevate Telematics Subscription
7.14 Storage Box
7.15 White Noise Alarm
Section 8 – Labels
8.1 Label Kits
8.2 Labels - Left & Right Sides
8.3 Labels - Front & Back
8.4 Labels - Engines
8.5 Labels - Outriggers
8.6 Labels - Railings
8.7 Labels - Control Boxes
