118
6,911
Skyjack Rough Terrain Scissors SJ9250RT Parts Manual 165942AD 2022
Brand: Skyjack
Type of Machine: Rough Terrain Scissors
Model: Skyjack SJ9250RT Rough Terrain Scissors
Serial Number: 50001121 - 50001152
Part Number: 165942AD
Publication Date: 2022
Number of Pages: 192 Pages
1.0 Platform Related Parts
1.1 Platform and Hinged Railing Assembly
1.2 Gate Latch Assembly
1.3 Powered Extension Platform Assembly
1.4 Quick Release Pin Assemblies
1.5 Powered Extension Cylinder Mounting Assembly
1.6 Powered Extension Cylinder Assembly
1.7 Powered Extension Power Unit Assembly
1.8 Platform Extension Platform Control Console
1.9 Electrical Panel Connection - Platform Extension (ANSI/CSA)
1.10 Electrical Panel Connection - Platform Extension (KC)
1.11 Safety D-Ring Assembly
1.12 Hydraulic Hose Connection - Single Powered Extension Cylinder
1.13 Hydraulic Hose Connection - Dual Powered Extension Cylinders
1.14 Platform Control Console Assembly - Hardware
1.15 Platform Control Console Assembly - Switches
1.16 Drive/Steer Controller Assembly
2.0 Scissor Related Parts
2.1 Scissor Assembly
2.2 Scissor Arm Mounting Hardware
2.3 Scissor Arm Connecting Hardware
2.4 Hydraulic Hose Connection - Lift Cylinders
2.5 Lift Cylinder Assembly
2.6 Holding Valve Assembly
2.7 Holding Valve Assembly with Pressure Switch (KC)
2.8 Electrical Connection - Scissor Assembly
2.9 Horn, Light and Beeper Assembly (ANSI/CSA)
2.10 Horn, Light, Beeper and Transducer Assembly (KC)
2.11 Scissor Control Cable Assembly
3.0 Base Related Parts
3.1 Base Assembly
3.2 Fuel Cabinet Assembly
3.3 Fuel Tank Assembly
3.4 Hydraulic/Electrical Cabinet Assembly
3.5 Hydraulic Oil Tank Assembly
3.6 Hydraulic Hose Connections - Base
3.7 Hydraulic Hose Connections - Hydraulic Cabinet
3.8 Cushion Valve Assembly
3.9 Emergency Lowering Valve Assembly
3.10 Electrical Cabinet Components - Emergency Lowering and Powerdeck
3.11 Electrical Connections - Emergency Lowering (ANSI/CSA)
3.12 Electrical Connections - Emergency Lowering & Platform Retraction (KC)
3.13 Motion Control Valve Assembly
3.14 Auto Reset Brake Manifold Assembly
3.15 Main Manifold Assembly
3.16 Electrical Panel Assembly (ANSI/CSA)
3.17 Electrical Panel Assembly (KC)
3.18 Electrical Harnesses
3.19 Base Controls Assembly
4.0 Axle Related Parts
4.1 Front Axle Assembly
4.2 Front Axle Hardware
4.3 Steer Cylinder Assembly
4.4 Drive Motor Assembly
4.5 Drive Shaft Assembly
4.6 Center Drive Assembly
4.7 Brake Caliper and Mount
4.8 Rear Axle Assembly
5.0 Engine Related Parts
5.1 Engine Roll-Out Tray Assembly
5.2 Engine Control Panel
5.3 Kubota Diesel Engine Assembly (D1305)
5.4 Kubota Diesel Fuel System (D1305)
5.5 Kubota Diesel Engine Harness
5.6 Air Intake Assembly (Kubota Diesel Engine D1305)
5.7 Exhaust Manifold Assembly (Kubota Diesel Engine D1305)
5.8 Hydraulic Pump Assembly
5.9 Engine Roll-Out Tray Hardware (GM Engine)
5.10 GM Dual Fuel Engine Assembly
5.11 Bell Housing Assembly (GM Engine)
5.12 Engine Interface Harness (GM Engine)
5.13 Hose Connections - GM Dual Fuel Engine
6.0 Optional Equipment
6.1 Electrical Panel Connections - Hydraulic Outrigger
6.2 Hydraulic Hose Connections - Hydraulic Outrigger
6.3 Outrigger Assembly
6.4 Outrigger Cylinder Assembly
6.5 Outrigger Manifold Assembly
6.6 Outrigger/Hydraulic Generator Control Console Assembly
6.7 3500W Generator and Oil Cooler Assembly
6.8 Hydraulic Hose Connections - 3500W Hydraulic Generator and Oil Cooler
6.9 Air Hose to Platform Option
6.10 Platform AC Outlet Assembly
6.11 Cold Start Option
6.12 Gate Hand Rail Kit
6.13 GP-108 Controller
6.14 Flashing Light Relay Harness
7.0 Labels
7.1 Label Kits
7.2 Labels - Left and Right Sides
7.3 Labels - Front and Rear
7.4 Labels - Hydraulic Outriggers
7.5 Labels - Miscellaneous
7.6 Labels - Control Consoles
8.0 Tables
8.1 Fluid Tables
