Skyjack Rough Terrain Scissors SJ9250RT Parts Manual 160618AG 2022
Brand: Skyjack
Type of Machine: Rough Terrain Scissors
Model: Skyjack SJ9250RT Rough Terrain Scissors
Serial Number: 50000873 - 50000873, 50000879 - 50001023
Part Number: 160618AG
Publication Date: 2022
Number of Pages: 212 Pages
1.0 Platform Related Parts
1.1 Platform and Hinged Railing Assembly
1.3 Powered Extension Platform Assembly
1.4 Quick Release Pin Assemblies
1.5 Powered Extension Cylinder Mounting Assembly
1.7 Powered Extension Power Unit Assembly
1.8 Platform Extension Platform Control Console
1.9 Electrical Panel Connection - Platform Extension (ANSI/CSA)
1.10 Electrical Panel Connection - Platform Extension (KC)
1.12 Hydraulic Hose Connection - Single Powered Extension Cylinder
1.14 Platform Control Console Assembly - Hardware
1.15 Platform Control Console Assembly - Switches
1.16 Drive/Steer Controller Assembly
2.0 Scissor Related Parts
2.1 Scissor Assembly
2.2 Scissor Arm Mounting Hardware
2.3 Scissor Arm Connecting Hardware
2.4 Hydraulic Hose Connection - Lift Cylinders
2.5 Lift Cylinder Assembly
2.6 Holding Valve Assembly
2.8 Electrical Connection - Scissor Assembly
2.9 Horn, Light and Beeper Assembly (ANSI/CSA)
2.10 Horn, Light, Beeper and Transducer Assembly (KC)
2.11 Scissor Control Cable Assembly
3.0 Base Related Parts
3.1 Base Assembly
3.2 Fuel Cabinet Assembly
3.4 Hydraulic/Electrical Cabinet Assembly
3.5 Hydraulic Oil Tank Assembly
3.6 Hydraulic Hose Connections - Base with Axles
3.7 Hydraulic Hose Connections - Hydraulic Cabinet
3.8 Cushion Valve Assembly
3.10 Electrical Cabinet Components - Emergency Lowering and Powerdeck
3.11 Electrical Connections - Emergency Lowering (ANSI/CSA)
3.12 Electrical Connections - Emergency Lowering & Platform Retraction (KC)
3.13 Motion Control Valve Assembly
3.15 Main Manifold Assembly
3.16 Electrical Panel Assembly (ANSI/CSA)
3.17 Electrical Panel Assembly (KC)
3.18 Electrical Harnesses
3.19 Base Controls Assembly
4.0 Axle Related Parts
4.1 Front Idle Arm Assembly - 2 Wheel Drive (ANSI/CSA)
4.2 Front Axle Hardware Assembly - All Wheel Drive
4.3 Front Axle Assembly - All Wheel Drive
4.4 Front Axle End Assembly - All Wheel Drive
4.5 Front Axle Differential Assembly - All Wheel Drive
4.6 Wheel Hub Assembly - All Wheel Drive
4.8 2WD Front Axle Steer Cylinder Assembly
4.9 4WD Front Axle Steer Cylinder Assembly
4.10 Drive Shaft Assembly
4.11 Center Drive Assembly
4.12 Drive Motor Assembly
4.14 Rear Axle Assembly
4.15 Rear Axle Differential Assembly
4.16 Rear Axle Brake Assembly
5.0 Engine Related Parts
5.1 Engine Roll-Out Tray Assembly
5.2 Engine Control Panel
5.3 Kubota Diesel Engine Assembly (D1305)
5.4 Kubota Diesel Fuel System (D1305)
5.5 Kubota Diesel Engine Harness
5.6 Air Intake Assembly (Kubota Diesel Engine D1305)
5.8 Exhaust Manifold Assembly (Kubota Diesel Engine D1305)
5.9 Engine Roll-Out Tray Hardware (GM Engine)
5.10 GM Dual Fuel Engine Assembly
5.11 Bell Housing Assembly (GM Engine)
5.12 Engine Interface Harness (GM Engine)
5.13 Hose Connections - GM Dual Fuel Engine
6.0 Optional Equipment
6.1 Electrical Panel Connections - Hydraulic Outrigger
6.2 GP-108 Controller
6.3 Flashing Light Relay Harness
6.4 Hydraulic Hose Connections - Hydraulic Outrigger
6.5 Outrigger Assembly
6.6 Outrigger Cylinder Assembly
6.8 Outrigger/Hydraulic Generator Control Console Assembly
6.9 3500W Generator and Oil Cooler Assembly
6.10 Hydraulic Hose Connections - 3500W Hydraulic Generator and Oil Cooler
6.11 Work Light Option
6.12 Air Hose to Platform Option
6.13 Platform AC Outlet Assembly
6.14 Cold Start Option
6.15 Gate Hand Rail Kit
7.0 Labels
7.1 Label Kits
7.2 Labels - Left and Right Sides
7.3 Labels - Front and Rear
7.5 Labels - Miscellaneous
7.6 Labels - Control Consoles
8.0 Tables
8.1 Fluid Tables
Brand: Skyjack
3.1 Base Assembly
7.0 Labels
7.1 Label Kits
8.0 Tables
8.1 Fluid Tables
- Skyjack Rough Terrain Scissors SJ6826RT SJ6832RT Service Manual 157951AF 2023
- Skyjack Rough Terrain Scissors SJ6826RT SJ6832RT Service Manual 167955AGA 2023
- Skyjack Rough Terrain Scissors SJ6826RT SJ6832RT Service Manual 213560ADA 2023
- Skyjack Rough Terrain Scissors SJ6832RTE Operating Manual 159176AE-A 2022
- Skyjack Rough Terrain Scissors SJ6832RTE Operating Manual 194419AFA 2022
- Skyjack Rough Terrain Scissors SJ6832RTE Parts Manual 167571AE 2023
- Skyjack Rough Terrain Scissors SJ6832RTE Parts Manual 194373AF 2023
- Skyjack Rough Terrain Scissors SJ6832RTE Service Manual 167574AGA 2023
- Skyjack Rough Terrain Scissors SJ7127RT to SJ9250RT Operating Manual 129922AE-A 2006
- Skyjack Rough Terrain Scissors SJ7127RT to SJ9250RT Operating Manual 143861AB-A 2008
- Skyjack Rough Terrain Scissors SJ7127RT to SJ9250RT Operating Manual 143884AC-A 2010
- Skyjack Rough Terrain Scissors SJ7127RT to SJ9250RT Operating Manual 157949AB-A 2022
- Skyjack Rough Terrain Scissors SJ7127RT to SJ9250RT Operating Manual 158009AP-A 2013
- Skyjack Rough Terrain Scissors SJ7127RT to SJ9250RT Operating Manual 159148AC-A 2022
- Skyjack Rough Terrain Scissors SJ7127RT to SJ9250RT Operating Manual 159166AC-A 2014
