Skyjack Rough Terrain Scissors SJ9241RT SJ9250RT Parts Manual 143904AG 2022
Brand: Skyjack
Type of Machine: Rough Terrain Scissors
Model: Skyjack SJ9241RT, SJ9250RT Rough Terrain Scissors
Serial Number:
ANSI/CSA & AS SJ9250 50000513 - 50000745
CE SJ9241 55000001 - 55000032, SJ9250 50000513 - 50000745
Part Number: 143904AG
Publication Date: 2022
Number of Pages: 226 Pages
Platform Related Parts
Figure 1.1 Main Platform and Railings
Figure 1.2 Gate Latch Assembly
Figure 1.3 Powered Extension Platform
Figure 1.4 Quick Release Pin Assemblies
Figure 1.5 Powered Extension Platform Cylinder Mounting Assembly
Figure 1.6 Powered Extension Platform Cylinder Assembly
Figure 1.7 Powered Extension Power Unit Assembly
Figure 1.8 Powered Extension Platform Control Console
Figure 1.9 Powered Extension Platform Electrical Panel - Model 9250 ANSI
Figure 1.10 Powered Extension Platform Electrical Panel - Models 9241 & 9250 CE
Figure 1.11 Lanyard Attachment D-Ring Assemblies
Figure 1.12 Hydraulic Hose Connections - Sinlge Powered Extension Platform
Figure 1.13 Hydraulic Hose Connections - Dual Powered Extension Platform
Platform Control Console Assembly
Figure 2.1 Platform Control Console Assembly - Hardware
Figure 2.2 Platform Control Console Assembly - Switches
Figure 2.3 Drive/Steer Controller Assembly
Figure 2.4 Control Cable Assemblies
Scissors Related Parts
Figure 3.1 Scissor Arm Assembly - Model 9250
Figure 3.2 Scissor Stack Mounting Hardware Assemblies - Model 9250
Figure 3.3 Scissor Arm Connecting Hardware Assemblies - Model 9250
Figure 3.4 Hydraulic Hose Connections - Scissors - Model 9250
Figure 3.5 Lift Cylinder Assembly - Model 9250
Figure 3.6 Lift Cylinder Holding Valve Manifold Assembly - Model 9250
Figure 3.7 Lift Cylinder Holding Valve Manifold Assembly with Transducer - Model 9250 CE
Figure 3.8 Scissor Arm Electrical Connections - Model 9250
Figure 3.9 Scissor Arm Assembly - Model 9241
Figure 3.10 Scissor Stack Mounting Hardware Assemblies - Model 9241
Figure 3.11 Scissor Arm Connecting Hardware Assemblies - Model 9241
Figure 3.12 Hydraulic Hose & Electrical Connections- Scissors - Model 9241
Figure 3.13 Lift Cylinder Assembly - Model 9241
Figure 3.14 Lift Cylinder Holding Valve Manifold Assembly without Transducer - Model 9241
Figure 3.15 Lift Cylinder Holding Valve Manifold Assembly with Transducer - Model 9241
Figure 3.16 Horn, Light & Beeper Assembly (ANSI/CSA)
Figure 3.17 Horn, Light, Beeper, & Load Sensing Assemblies (CE)
Base Related Parts
Figure 4.1 Base, Axles, and Wheels
Figure 4.2 Fuel Side Cabinet
Figure 4.3 Fuel Tank and Connections
Figure 4.4 Hydraulic/Electric Side Cabinet
Figure 4.5 Hydraulic Oil Tank Assembly
Figure 4.6 Hydraulic Hose Connections - Base (Cushman Axles) (Model 9250)
Figure 4.7 Hydraulic Hose Connections - Base (Dana Axles) (Model 9250)
Figure 4.8 Hydraulic Hose Connections - Base (Model 9241)
Figure 4.9 Hydraulic Hose Connections - Hydraulic Cabinet
Figure 4.10 Cushion Valve Assembly
Figure 4.11 Emergency Lowering Valve Assembly
Figure 4.12 Emergency Lowering Wiring Assembly (Model 9250 ANSI/CSA)
Figure 4.13 Emergency Lowering and Power Platform Retraction Wiring Assembly (Model 9250 CE)
Figure 4.14 Brake Cylinder Assembly (Model 9250)
Figure 4.15 Motion Control Valve Assembly
Figure 4.16 Auto Reset Brake Manifold Assembly (Cushman Axles)
Figure 4.17 Main Manifold Assembly
Figure 4.18 Base Control / Electrical Panel Assembly
Figure 4.19 GP-108 Controller
Figure 4.20 Flashing Light Relay Harness
Figure 4.21 Base Control/Electrical Panel Harnesses
Figure 4.22 Base Control Console
Axle Related Parts
Figure 5.1 Front Idle Arm Assembly - 2-Wheel Drive Machines
Figure 5.2. Front Axle Hardware Assembly - All Wheel Drive Option (Cushman Axles)
Figure 5.3 Front Axle Assembly - All Wheel Drive Option (Cushman Axles)
Figure 5.4 Front Axle Assembly (Axle End) - All Wheel Drive Option (Cushman Axles)
Figure 5.5 Front Axle (Differential Assembly) - All Wheel Drive Option (Cushman Axles)
Figure 5.6 Front & Rear Axle (Wheel Hub Assembly) - All Wheel Drive Option (Cushman Axles)
Figure 5.7 Front Axle (Axle Shaft Assembly) - All Wheel Drive Option (Cushman Axles)
Figure 5.8 Steer Cylinder Assembly (Cushman Axles)
Figure 5-9 Front Axle Assembly (For 4-wheel Drive Machines) (Dana Axles)
Figure 5.10 Front Drive Axle Assembly - Four Wheel Drive Machines (Dana Axles)
Figure 5.11 Steer Cylinder Assembly (Dana Axles)
Figure 5.12 Drive Shaft Assembly
Figure 5.13 Drive Motor Assembly
Figure 5.14 Center Drive Assembly
Figure 5.15 Rear Axle Assembly - (Cushman Axles)
Figure 5.16 Rear Axle (Differential Assembly) - (Cushman Axles)
Figure 5.17 Rear Axle (Brake Assembly) - (Cushman Axles)
Figure 5.18 Rear Drive Axle Assembly (Dana Axles)
Engines Related Parts
Figure 6.1 Engine Roll Out Tray & Cover Assembly
Figure 6.2 Engine Control Panel
Figure 6.3 Diesel Engine Assembly (Kubota Diesel Engine D1305)
Figure 6.4 Diesel Fuel System (Kubota Diesel Engine D1305)
Figure 6.5 Kubota Diesel Fuel Engine Harness
Figure 6.6 Air Intake Assembly (Kubota Diesel Engine D1305)
Figure 6.7 Hydraulic Pump Assembly
Figure 6.8 Exhaust Manifold Assembly (Kubota Diesel Engine D1305)
Figure 6.9 Engine Roll Out Accessories (GM Dual Fuel Engine)
Figure 6.10 Dual Fuel Engine Assembly (GM Dual Fuel Engine)
Figure 6.11 Bell Housing Assembly (GM Dual Fuel Engine)
Figure 6.12 Engine Interface Harness (GM Dual Fuel Engine)
Figure 6.13 Dual Fuel Hose Assembly (GM Dual Fuel Engine)
Optional Equipments
Figure 7.1 Hydraulic Outrigger - Electrical Panel Connections
Figure 7.2 Hydraulic Outrigger Option - Hydraulic Hose Connection
Figure 7.3 Hydraulic Outrigger Option - Leg Assembly
Figure 7.4 Hydraulic Outrigger Option - Cylinder Assembly
Figure 7.5 Hydraulic Outrigger Option - Manifold Assembly
Figure 7.6 Outrigger/Hydraulic Generator Control Console Assembly
Figure 7.7 3500W Hydraulic Generator Option - Generator, Oil Cooler & Mounting
Figure 7.8 3500W Hydraulic Generator Option - Hydraulic Hose Connections
Figure 7.9 1500W Inverter Option
Figure 7.10 Scissor Guard
Figure 7.11 Work Light Option
Figure 7.12 Air Hose to Platform Option
Figure 7.13 Load Sensing Components (CE)
Figure 7.14 Platform AC Outlet Assembly
Labels
Figure 8.1 Label Kit
Figure 8.2 Labels and Nameplate - Control Console Assemblies
Figure 8.3 Labels and Nameplate - Misc
Figure 8.4 Labels and Nameplate - Chassis
Figure 8.5 Labels - Outrigger
Tables
Table 1.1 SJRT Scissor Fluids
Brand: Skyjack
Serial Number:
Base Related Parts
Axle Related Parts
Optional Equipments
Labels
Tables
- Skyjack Rough Terrain Scissors SJ6826RT SJ6832RT Service Manual 157951AF 2023
- Skyjack Rough Terrain Scissors SJ6826RT SJ6832RT Service Manual 167955AGA 2023
- Skyjack Rough Terrain Scissors SJ6826RT SJ6832RT Service Manual 213560ADA 2023
- Skyjack Rough Terrain Scissors SJ6832RTE Operating Manual 159176AE-A 2022
- Skyjack Rough Terrain Scissors SJ6832RTE Operating Manual 194419AFA 2022
- Skyjack Rough Terrain Scissors SJ6832RTE Parts Manual 167571AE 2023
- Skyjack Rough Terrain Scissors SJ6832RTE Parts Manual 194373AF 2023
- Skyjack Rough Terrain Scissors SJ6832RTE Service Manual 167574AGA 2023
- Skyjack Rough Terrain Scissors SJ7127RT to SJ9250RT Operating Manual 129922AE-A 2006
- Skyjack Rough Terrain Scissors SJ7127RT to SJ9250RT Operating Manual 143861AB-A 2008
- Skyjack Rough Terrain Scissors SJ7127RT to SJ9250RT Operating Manual 143884AC-A 2010
- Skyjack Rough Terrain Scissors SJ7127RT to SJ9250RT Operating Manual 157949AB-A 2022
- Skyjack Rough Terrain Scissors SJ7127RT to SJ9250RT Operating Manual 158009AP-A 2013
- Skyjack Rough Terrain Scissors SJ7127RT to SJ9250RT Operating Manual 159148AC-A 2022
- Skyjack Rough Terrain Scissors SJ7127RT to SJ9250RT Operating Manual 159166AC-A 2014
