118
6,911
Skyjack Rough Terrain Scissors SJ9233RT to SJ9664RT Service Manual 229046AGA 2023
Brand: Skyjack
Type of Machine: Rough Terrain Scissors
Type of Manual: Service Manual, Electrical Schematic, Hydraulic Schematic
Model: Skyjack SJ9233RT, SJ9243RT, SJ9253RT, SJ9664RT Rough Terrain Scissors
Serial Number:
SJ9233RT A202000001 - A202999999, SJ9243RT A202000001 - A202999999
SJ9253RT A202000001 - A202999999, SJ9664RT A203000001 - A203999999
Part Number: 229046AGA
Publication Date: 2023
Number of Pages: 242 Pages
Section 1 – Maintenance
1.1 Read and Heed
1.2 General information
1.3 Scheduled maintenance and inspections
1.4 Owner’s annual inspection record
1.5 Frequent/periodic/annual/pre-delivery inspection checklist
1.6 Scheduled maintenance inspections
1.7 Function tests
Section 2 – Maintenance Tables and Diagrams
2.1 Standard hose numbering system
2.2 Torque specifications for fasteners (US imperial)
2.3 Torque specifications for fasteners (metric)
2.4 Torque specifications for hydraulic couplings & hoses
2.5 Axle torque specifications
2.6 Axle maintenance intervals
2.7 Specifications - SJ9253 RT, SJ9243 RT, SJ9253 RT
2.8 Specifications - SJ9664 RT
2.10 Fluids
2.9 Environment
2.11 Floor loading pressure
2.12 Maximum platform capacities (evenly distributed)
Section 3 – System Component Identification and Schematics
3.1 Electrical symbol chart
3.2 Hydraulic symbol chart
3.3 Wire number and color code
3.4 Hydraulic parts list
3.5 Electrical parts list
3.6 Major Component Identification
3.7 Drive Manifold - Hose Port Identification
3.8 Drive Manifold - Hydraulic & Electrical Component Identification
3.9 Auxiliary Manifold - Hose Port Identification
3.10 Auxiliary Manifold - Hydraulic & Electrical Component Identification
3.11 Outrigger Manifold
3.12 Pressure Reducing & Motor Shift Manifolds
3.13 Outrigger Manifold Harness
3.14 Drive Manifold Harness
3.15 Drive Manifold Harness Schematic
3.16 Kubota D1305 Engine Harness - S/N A202 000 461 and above
3.17 Kubota D1305 Engine Harness Schematic - S/N A202 000 461 and above
3.18 Kubota D1305 Engine Harness - S/N A202 000 160 and below
3.19 Kubota D1305 Engine Harness Schematic - S/N A202 000 460 and below
3.20 Kubota WG972 Engine Harness
3.21 Kubota WG972 Engine Harness Schematic
3.22 Fuel Pump Harness
3.23 ECU Power Harness
3.24 Pressure Transducer Harness - SJ9233 RT, SJ9243 RT, SJ9253 RT
3.25 Outrigger Control Harness
3.26 Outrigger Terminal Strip
3.27 Skycoded controller Harness - SJ9233 RT, SJ9243 RT, SJ9253 RT
3.28 Skycoded controller Harness - Wiring Diagram - SJ9233 RT, SJ9243 RT, SJ9253 RT
3.29 Skycoded controller Harness - SJ9664 RT
3.30 Skycoded controller Harness - Wiring Diagram - SJ9664 RT
3.31 Base Control Cable
3.32 Control Harness A
3.33 Control Harness B
3.34 Dual Holding Valve Harness - SJ9233 RT, SJ9243 RT, SJ9253 RT
3.35 Holding Valve Harnesses - SJ9664 RT
3.36 Angle Transducer/Beeper/Flashing Light Harness - SJ9664 RT
3.37 Load Cell Module Harness - SJ9664 RT - S/N A203 000 060 and above
3.38 Load Cell Module Harness - SJ9664 RT - S/N A203 000 059 and below
3.39 Load Cell Module Power Harness - SJ9664 RT
3.40 Load Cell Module CAN Harness - SJ9664 RT
3.41 3.5 kW Generator Harness - with outriggers
3.42 3.5 kW Generator Harness - no outriggers
3.43 Hydraulic Schematic - SJ9233 RT, SJ9243 RT, SJ9253 RT
3.44 Hydraulic Schematic - SJ9664 RT
3.45 Base Control Box Wiring - with Outriggers
3.46 Base Control Box Wiring - No Outriggers
3.47 Platform Control Box Wiring
3.48 Electrical Schematic - No Options - SJ9233 RT, SJ9243 RT, SJ9253 RT
3.49 Electrical Schematic - All Options - SJ9233 RT, SJ9243 RT, SJ9253 RT
3.50 Electrical Schematic - No Options - SJ9664 RT
3.51 Electrical Schematic - All Options - SJ9664 RT
3.52 Engine Electrical Schematic - Kubota D1305 - SJ9233 RT, SJ9243 RT, SJ9253 RT
3.53 Engine Electrical Schematic - Kubota WG972
3.54 Engine Electrical Schematic - Kubota D1305 - SJ9664 RT
Section 4 – Troubleshooting Information
4.1 Introduction
4.2 Electrical System
4.3 Hydraulic System
Section 5 – Procedures
5.1 General
5.2 Platform
5.3 Scissors
5.4 Engines
5.5 Axles
5.6 Manifolds and Hydraulic Pumps
5.7 Outriggers
5.8 Skycoded Controller Module
5.9 EZcal Diagnostic Tool
