Skyjack Rough Terrain Scissors SJ8831RT SJ8841RT Parts Manual 165939AH 2022
Brand: Skyjack
Type of Machine: Rough Terrain Scissors
Model: Skyjack SJ8831RT, SJ8841RT Rough Terrain Scissors
Serial Number: SJRT8831 36000276 to 36999999, SJRT8841 40001211 to 40999999
Part Number: 165939AH
Publication Date: 2022
Number of Pages: 256 Pages
Foreword
General
Parts Ordering Information
Method of Listing
Quantities
How To Order Repair Parts
Section 1 – Platforms
1.1 Platform and Hinged Railing
1.2 Roll-Out Extension Deck
1.3 Quick Release Pins
1.4 Powered Extension Deck
1.5 Power Unit Assembly A
1.6 Power Unit Assembly B
1.7 Power Unit - Single Extension
1.8 Power Unit - Double Extension
1.9 Powered Extension Deck Cylinder Mounting
1.10 Powered Extension Deck Cylinder
1.11 Powered Extension Deck Control Box
1.12 Powered Extension Deck Electrical Panel
1.13 Hydraulic Hoses - Single Powered Extension Deck A
1.14 Hydraulic Hoses - Single Powered Extension Deck B
1.15 Hydraulic Hoses - Dual Powered Extension Decks (8831) A
1.16 Hydraulic Hoses - Dual Powered Extension Decks (8831) B
1.17 Hydraulic Hoses - Dual Powered Extension Decks (8841) A
1.18 Hydraulic Hoses - Dual Powered Extension Decks (8841) B
1.19 Safety D-Rings
1.20 Platform Control Box
1.21 Platform Control Box Switches
1.22 Drive/Steer Controller
1.23 Platform AC Outlet
Section 2 – Scissors
2.1 Scissors - SJ8831 RT
2.2 Scissors - SJ8841 RT
2.3 Scissor Arm Mounting Hardware
2.4 Scissor Arm Connecting Hardware
2.5 Horn, Light and Beeper
2.6 Additional Beeper - KC
2.7 Lift Cylinder
2.8 Hydraulic Hose Connections - Lift Cylinders
2.9 Holding Valve
2.10 Holding Valve with Pressure Switch
2.11 Scissor Control Cable
Section 3 – Base
3.1 Base
3.2 Tires
3.3 Hydraulic Hose Connections - Base
3.4 Fuel/Hydraulic Tank Cabinet
3.5 Hydraulic Tank
3.6 Fuel Tank
3.7 Hydraulic/Electric Cabinet
3.8 Hydraulic Hose Connections - Cabinet
3.9 Brake Valve
3.10 Motion Control Valve
3.11 Main Control Valve
3.12 Electrical Panel
3.13 Electrical Harnesses
3.14 Base Controls
3.15 Brake Release Pump with Lanyard
Section 4 – Axles
4.1 Front Idle Axle - 2WD
4.2 Front Axle Hardware - 4WD
4.3 Front Axle - 4WD
4.4 Steer Cylinder - 2WD
4.5 Steer Cylinder - 4WD
4.6 Drive Shaft
4.7 Drive Motor
4.8 Brake Mount and Brake
4.9 Center Drive
4.10 Rear Drive Assembly
4.11 Rear Axle
Section 5 – Engine
5.1 Engine Roll-Out Tray
5.2 Engine Control Panel
5.3 Engine Tray Lock
5.4 Kubota Diesel Engine D1305
5.5 Kubota Diesel Fuel System (D1305)
5.6 Kubota Diesel Engine Harness
5.7 Air Intake - Kubota D1305
5.8 Hydraulic Pump A
5.9 Hydraulic Pump B
5.10 Exhaust Manifold - Kubota D1305
5.11 Kubota Dual Fuel Engine DF972 EFI
5.12 Exhaust - DF972 EFI
5.13 Air Intake - DF972 EFI
5.14 Display Module - DF972 EFI
5.15 Engine Display - DF972 EFI
5.16 Engine Harnesses - DF972 EFI
5.17 Kubota Dual Fuel Hoses - DF972 EFI
5.18 Radiator Kit - Kubota
5.19 Kubota Dual Fuel Engine - DF972
5.20 Air Cleaner - Kubota DF972
5.21 Exhaust - Kubota DF972
5.22 Kubota Fuel Hoses - DF972
5.23 Kubota Dual Fuel Engine Harness - DF972
5.24 Engine - Kubota Diesel T4F
5.25 Air Intake - Kubota Diesel T4F
5.26 Engine Mount - Kubota Diesel T4F
5.27 Engine Cover and Tray
5.28 Starter, Stud Extension - Kubota Diesel Engine
5.29 Engine Tray - Kubota D1305
5.30 Filter - Kubota D1305
5.31 Solenoid - Throttle
5.32 Engine Base - Kubota T4F
Section 6 – Optional Equipment
6.1 Hydraulic Hose Connections - Outriggers
6.2 Outrigger Assembly
6.3 Outrigger Cylinder Assembly
6.4 Outrigger Manifold Assembly
6.5 Outrigger Electrical Panel Assembly
6.6 GP-108 Controller
6.7 Flashing Light Relay Harness
6.8 Electrical Panel Connections - Hydraulic Outriggers with Auto-Level
6.9 Outrigger/Generator Control Console Assembly
6.10 3500 W Hydraulic Generator and Oil Option
6.11 12 kW Hydraulic Generator and Oil Cooler Option
6.12 Hydraulic Generator and Oil Cooler Assembly
6.13 12 kW Generator Control Breaker Box and Mount Assembly
6.14 Hydraulic Hose Connections - 12 kW Generator
6.15 Hydraulic Valve Assembly - 12 kW Generator
6.16 Dual Flashing Light
6.17 Air Hose to Platform Assembly
6.18 Cold Start
6.19 Gate Hand Rail Kit
6.20 Telematics - ZTR
6.21 Positive Air Shut Off
6.22 Material Handling Stand
6.23 Tool Caddy
6.24 Heavy Duty Pipe Rack
6.25 Elevate Telematics, Rework - Service Kit
6.26 Elevate Telematics Ready - Service Kit
6.27 Secondary Guarding Lift Enable
6.28 Secondary Guarding Lift Enable with Shroud
Section 7 – Labels
7.1 Labels Kits
7.2 Labels - Right and Left Sides
7.3 Labels - Front and Rear
7.4 Labels - Outriggers
7.5 Labels - Miscellaneous
7.6 Labels - Control Boxes
Section 8 – Tables
8.1 Fluid Tables
Brand: Skyjack
Foreword
General
Method of Listing
Quantities
1.19 Safety D-Rings
2.7 Lift Cylinder
2.9 Holding Valve
Section 3 – Base
3.1 Base
3.2 Tires
3.5 Hydraulic Tank
3.6 Fuel Tank
3.9 Brake Valve
3.14 Base Controls
Section 4 – Axles
4.6 Drive Shaft
4.7 Drive Motor
4.9 Center Drive
4.11 Rear Axle
Section 5 – Engine
6.18 Cold Start
6.23 Tool Caddy
Section 7 – Labels
7.1 Labels Kits
Section 8 – Tables
8.1 Fluid Tables
- Skyjack Rough Terrain Scissors SJ6826RT SJ6832RT Service Manual 157951AF 2023
- Skyjack Rough Terrain Scissors SJ6826RT SJ6832RT Service Manual 167955AGA 2023
- Skyjack Rough Terrain Scissors SJ6826RT SJ6832RT Service Manual 213560ADA 2023
- Skyjack Rough Terrain Scissors SJ6832RTE Operating Manual 159176AE-A 2022
- Skyjack Rough Terrain Scissors SJ6832RTE Operating Manual 194419AFA 2022
- Skyjack Rough Terrain Scissors SJ6832RTE Parts Manual 167571AE 2023
- Skyjack Rough Terrain Scissors SJ6832RTE Parts Manual 194373AF 2023
- Skyjack Rough Terrain Scissors SJ6832RTE Service Manual 167574AGA 2023
- Skyjack Rough Terrain Scissors SJ7127RT to SJ9250RT Operating Manual 129922AE-A 2006
- Skyjack Rough Terrain Scissors SJ7127RT to SJ9250RT Operating Manual 143861AB-A 2008
- Skyjack Rough Terrain Scissors SJ7127RT to SJ9250RT Operating Manual 143884AC-A 2010
- Skyjack Rough Terrain Scissors SJ7127RT to SJ9250RT Operating Manual 157949AB-A 2022
- Skyjack Rough Terrain Scissors SJ7127RT to SJ9250RT Operating Manual 158009AP-A 2013
- Skyjack Rough Terrain Scissors SJ7127RT to SJ9250RT Operating Manual 159148AC-A 2022
- Skyjack Rough Terrain Scissors SJ7127RT to SJ9250RT Operating Manual 159166AC-A 2014
