7,392
Skyjack Rough Terrain Scissors SJ8831RT SJ8841RT Parts Manual 160616AH 2022
Brand: Skyjack
Type of Machine: Rough Terrain Scissors
Model: Skyjack SJ8831RT, SJ8841RT Rough Terrain Scissors
Serial Number: SJRT8831 36000252 to 36000275, SJRT8841 40000918 to 40001134
Part Number: 160616AH
Publication Date: 2022
Number of Pages: 214 Pages
1.0 Platform Related Parts
1.1 Platform and Hinged Railing Assembly
1.2 Roll-Out Extension Deck Assembly
1.3 Powered Extension Deck Assembly
1.4 Quick Release Pins
1.5 Powered Extension Deck Cylinder Mounting Assembly
1.6 Powered Extension Deck Cylinder Assembly
1.7 Powered Extension Deck Control Box Assembly
1.8 Powered Extension Deck Electrical Panel
1.9 Hydraulic Hose Connections - Single Powered Extension Deck
1.10 Hydraulic Hose Connections - Dual Powered Extension Decks (8831)
1.11 Hydraulic Hose Connections - Dual Powered Extension Decks (8841)
1.12 Safety D-Ring Assembly
1.13 Platform Control Box Assembly - Hardware
1.14 Platform Control Box Assembly - Switches
1.15 Drive/Steer Controller Assembly
1.16 Platform AC Outlet
2.0 Scissor Related Parts
2.1 Scissor Assembly (Model 8831 ANSI/CSA)
2.2 Scissor Assembly (Model 8841)
2.3 Scissor Arm Mounting Hardware
2.4 Scissor Arm Connecting Hardware
2.5 Horn, Light and Beeper Assemblies
2.6 Beeper Assembly (KC)
2.7 Lift Cylinder Assembly
2.8 Hydraulic Hose Connections - Lift Cylinders
2.9 Holding Valve Assembly (Upper and Lower Lift Cylinder)
2.10 Holding Valve Assembly with Pressure Switch (KC - Lower Lift Cylinder)
2.11 Scissor Control Cable Assembly
3.0 Base Related Parts
3.1 Base Assembly
3.2 Tire Assemblies
3.3 Hydraulic Hose Connections - Base
3.4 Fuel/Hydraulic Tank Cabinet Assembly
3.5 Hydraulic Tank Assembly
3.6 Fuel Tank Assembly
3.7 Hydraulic/Electric Cabinet Assembly
3.8 Hydraulic Hose Connections - Cabinet
3.9 Brake Manifold Assembly
3.10 Motion Control Valve Assembly
3.11 Main Manifold Assembly
3.12 Electrical Panel Assembly
3.13 Electrical Harnesses
3.14 Base Controls Assembly
4.0 Axle Related Parts
4.1 Front Idle Axle Assembly - 2WD (ANSI/CSA)
4.2 Front Axle Hardware Assembly - 4WD
4.3 Front Axle Assembly - 4WD
4.4 Front Axle End Assembly - 4WD
4.5 Front Axle Differential Assembly - 4WD
4.6 Wheel Hub Assembly - 4WD
4.7 Front Drive Axle Shaft Assembly - 4WD
4.8 Front Axle Steer Cylinder Assembly - 2WD (ANSI/CSA)
4.9 Front Axle Steer Cylinder Assembly - 4WD
4.10 Drive Shaft Assembly
4.11 Drive Motor Assembly
4.12 Rear Axle Assembly Hardware
4.13 Center Drive Assembly
4.14 Rear Axle Assembly
4.15 Rear Axle Differential Assembly
4.16 Rear Axle Brake Assembly
5.0 Engine Related Parts
5.1 Engine Roll-Out Tray Assembly
5.2 Engine Control Panel
5.3 Engine Tray Lock Assembly
5.4 Kubota Diesel Engine Assembly (D1305)
5.5 Kubota Diesel Fuel System (D1305)
5.6 Kubota Diesel Engine Harness
5.7 Air Intake Assembly (Kubota D1305)
5.8 Hydraulic Pump Assembly
5.9 Exhaust Manifold Assembly (Kubota D1305)
5.10 GM Dual Fuel Engine Assembly
5.11 Bell Housing Assembly (GM Engine)
5.12 Engine Interface Harness (GM Engine)
5.13 Hose Connections - GM Dual Fuel Engine
6.0 Optional Equipment
6.1 Hydraulic Hose Connections - Outriggers
6.2 Outrigger Assembly
6.3 Outrigger Cylinder Assembly
6.4 Outrigger Manifold Assembly
6.5 Outrigger Electrical Panel Assembly
6.6 Electrical Panel Connections - Hydraulic Outrigger with Auto-Level
6.7 Outrigger/Generator Control Console Assembly
6.8 3500W Hydraulic Generator and Oil Cooler Option
6.9 12kW Hydraulic Generator and Oil Cooler Option
6.10 Hydraulic Generator and Oil Cooler Assembly
6.11 12kW Generator Control Breaker Box and Mount Assembly
6.12 Hydraulic Hose Connections - 12kW Generator
6.13 Hydraulic Valve Assembly - 12kW Generator
6.14 Dual Flashing Light
6.15 Air Hose to Platform Assembly
6.16 Work Light Assembly
6.17 Cold Start
6.18 Gate Hand Rail Kit
6.19 GP-108 Controller
6.20 Flashing Light Relay Harness
7.0 Labels
7.1 Labels Kits
7.2 Labels - Right and Left Sides
7.3 Labels - Front and Rear
7.4 Labels - Outriggers
7.5 Labels - Miscellaneous
7.6 Labels - Control Boxes
8.0 Tables
8.1 Fluid Tables
