Skyjack Rough Terrain Scissors SJ6826RT SJ6832RT Parts Manual 213559AEA 2023
Brand: Skyjack
Type of Machine: Rough Terrain Scissors
Model: Skyjack SJ6826RT, SJ6832RT Rough Terrain Scissors
Serial Number: A200000001 - A200999999
Part Number: 213559AEA
Publication Date: 2023
Number of Pages: 240 Pages
Foreword
General
Parts Ordering Information
Method of Listing
Quantities
How To Order Repair Parts
Recommended Service Parts
Section 1 – Platform
1.1 Main and Extension Platforms
1.2 Extension Platform Railing
1.3 Left Extension Railing
1.4 Right Extension Railing
1.5 Front Extension Railing
1.6 Main Platform Railing
1.7 Left Rear Platform Railing
1.8 Right Rear Platform Railing
1.9 Left Platform Railing
1.10 Right Platform Railing
1.11 Full Gate
1.12 Control Box
1.13 Control Box Cover
1.14 Electrical Outlet Box - ANSI/CSA, KC
1.15 Electrical Outlet - CE, AS
1.16 Platform Mounting Hardware
Section 2 – Scissors
2.1 Scissor Assembly - SJ6826 RT
2.2 Scissor Assembly - SJ6832 RT
2.3 Scissor Level 1, Inside
2.4 Scissor Level 2 & 4, Inside
2.5 Scissor Level 3, Inside
2.6 Scissor Level 5, Inside - SJ6832 RT
2.7 Scissor Level 1, Outside
2.8 Scissor Level 2, 3 & 4, Outside
2.9 Scissor Level 5, Outside - SJ6832 RT
2.10 Center Pin
2.11 Upper Lift Cylinder
2.12 Lower Lift Cylinder - ANSI/CSA, CE, AS
2.13 Lower Lift Cylinder - KC
2.14 Maintenance Support Stand
2.15 Angle Transducer and Beeper - ANSI/CSA, CE, AS
2.16 Beeper - KC
2.17 Limit Switch
2.18 Flashing Light
Section 3 – Base
3.1 Base
3.2 Outrigger Hydraulics
3.3 Drive System
3.4 Outrigger Manifold
3.5 Splitter Manifold
3.6 Cushion Cylinder
3.7 Tie Rod
3.8 Steer Cylinder
3.9 Counterweight with Outriggers - CE, AS, KC
3.10 Counterweight without Outriggers - ANSI/CSA, KC
3.11 Ladder
3.12 Emergency Lowering Rod
3.13 Tires
Section 4 – Cabinets
4.1 Engine Cabinet
4.2 Electrical Panel
4.3 Hydraulic Cabinet
4.4 Main Manifold
4.5 Hydraulic Oil Tank
4.6 Fuel Tank
4.7 Hydraulic Cabinet Door
4.8 Engine Cabinet Door
4.9 Key Switch
4.10 GP-108 Controller
4.11 Battery
Section 5 – Engines
5.1 Engine - Kubota WG752
5.2 Engine Tray
5.3 Vaporizer
5.4 Radiator Kit - Kubota WG752
5.5 Solenoid - Kubota WG752
5.6 Air Intake - Kubota WG752
5.7 Exhaust - Kubota WG752
5.8 Engine Accessories - Kubota WG752
5.9 Propane Tank Mount
5.10 Engine - Kubota D902
5.11 Radiator Kit - Kubota D902
5.12 Air Cleaner Kit - Kubota D902
Section 6 – Electrical Harnesses
6.1 Platform Control Harness
6.2 Engine Pull Out Harness
6.3 Main Manifold Harness
6.4 Electrical Panel Control Cable
6.5 Electrical Panel Harness
6.6 Limit Switch Wiring
6.7 Horn Harness
6.8 Base to Platform Cable
6.9 Base to Platform Holding Harness
6.10 Pressure Switch Harness - KC
6.11 Pressure Transducer Harness
6.12 Engine Harness - Kubota WG752
6.13 Harness - Kubota WG752
6.14 Engine Harness - Kubota D902
6.15 Harness - Kubota D902
6.16 Outrigger and Hydraulic Generator Harness
6.17 Outrigger Auto Level Limit Switch Harness
6.18 Outrigger Manifold Harness
6.19 Outrigger Auto-leveling Control Module Harness
6.20 Outrigger Control Cable
6.21 Outrigger Control Module Harness
6.22 Tilt Switch Harness - KC
6.23 Scissor Harness - KC
6.24 Beeper Harness
6.25 Light/Bepper Harness
6.26 Transducer Harness
6.27 Beeper Wiring - KC
6.28 Positive Air Shut-off Harness
6.29 Limit Switch Wiring - Soft Stop
6.30 Trackunit Harness
6.31 Flashing Light Relay Harness
Section 7 – Optional Equipment
7.1 Hydraulic Generator - ANSI/CSA
7.2 Hydraulic Generator - CE
7.3 Hydraulic Generator Hoses
7.4 Outrigger Control Box
7.5 Outriggers PC Board
7.6 Wire Locking Pins
7.7 Outrigger Assembly
7.8 Outrigger
7.9 Outrigger Cylinder
7.10 Tool Caddy
7.11 Cold Weather Start
7.12 Scissor Guards - CE
7.13 Heavy Duty Pipe Rack
7.14 White Noise Alarm
7.15 Residual Current Device (RCD)
7.16 Positive Air Shut-Off Valve
7.17 Elevate Telematics
7.18 Elevate Telematics Subscription
Section 8 – Hoses
8.1 Standard Hose Numbering System
8.2 Wheel Motor Hoses
8.3 Base Cylinders Hoses
8.4 Lift Cylinders Hoses
8.5 Pump Hoses
8.6 Flow Divider Hoses
8.7 Fuel Hoses - Kubota WG752
8.8 Fuel Hoses - Kubota D902
Section 9 – Labels
9.1 Label Kits
9.2 Top
9.3 Right & Left
9.4 Front & Back
9.5 Hydraulic & Propane Tanks
9.6 Railings
9.7 Platform Control Box
9.8 Outrigger & Hydraulic Generator Box
9.9 Outriggers
9.10 Base Control
9.11 Miscellaneous
Brand: Skyjack
Foreword
General
Method of Listing
Quantities
1.11 Full Gate
1.12 Control Box
2.10 Center Pin
2.16 Beeper - KC
2.17 Limit Switch
2.18 Flashing Light
Section 3 – Base
3.1 Base
3.3 Drive System
3.7 Tie Rod
3.8 Steer Cylinder
3.11 Ladder
3.13 Tires
4.1 Engine Cabinet
4.4 Main Manifold
4.6 Fuel Tank
4.9 Key Switch
4.11 Battery
Section 5 – Engines
5.2 Engine Tray
5.3 Vaporizer
6.7 Horn Harness
6.24 Beeper Harness
7.8 Outrigger
7.10 Tool Caddy
Section 8 – Hoses
8.5 Pump Hoses
Section 9 – Labels
9.1 Label Kits
9.2 Top
9.3 Right & Left
9.4 Front & Back
9.6 Railings
9.9 Outriggers
9.10 Base Control
9.11 Miscellaneous
- Skyjack Rough Terrain Scissors SJ6826RT SJ6832RT Service Manual 157951AF 2023
- Skyjack Rough Terrain Scissors SJ6826RT SJ6832RT Service Manual 167955AGA 2023
- Skyjack Rough Terrain Scissors SJ6826RT SJ6832RT Service Manual 213560ADA 2023
- Skyjack Rough Terrain Scissors SJ6832RTE Operating Manual 159176AE-A 2022
- Skyjack Rough Terrain Scissors SJ6832RTE Operating Manual 194419AFA 2022
- Skyjack Rough Terrain Scissors SJ6832RTE Parts Manual 167571AE 2023
- Skyjack Rough Terrain Scissors SJ6832RTE Parts Manual 194373AF 2023
- Skyjack Rough Terrain Scissors SJ6832RTE Service Manual 167574AGA 2023
- Skyjack Rough Terrain Scissors SJ7127RT to SJ9250RT Operating Manual 129922AE-A 2006
- Skyjack Rough Terrain Scissors SJ7127RT to SJ9250RT Operating Manual 143861AB-A 2008
- Skyjack Rough Terrain Scissors SJ7127RT to SJ9250RT Operating Manual 143884AC-A 2010
- Skyjack Rough Terrain Scissors SJ7127RT to SJ9250RT Operating Manual 157949AB-A 2022
- Skyjack Rough Terrain Scissors SJ7127RT to SJ9250RT Operating Manual 158009AP-A 2013
- Skyjack Rough Terrain Scissors SJ7127RT to SJ9250RT Operating Manual 159148AC-A 2022
- Skyjack Rough Terrain Scissors SJ7127RT to SJ9250RT Operating Manual 159166AC-A 2014
