7,392
Skyjack Rough Terrain Scissors SJ6826RT SJ6832RT Parts Manual 194370AF 2023
Brand: Skyjack
Type of Machine: Rough Terrain Scissors
Model: Skyjack SJ6826RT, SJ6832RT Rough Terrain Scissors
Serial Number: 37006157 - 37299999
Part Number: 194370AF
Publication Date: 2023
Number of Pages: 178 Pages
Foreword
General
Parts Ordering Information
Method of Listing
Quantities
How To Order Repair Parts
Section 1 – Platform
1.1 Gate
1.2 Platform Railing
1.3 Extension Deck Railing
1.4 Main and Extension Platforms
1.5 Gate Latch
1.6 Quick Release Pins
1.7 Platform AC Outlet
1.8 Control Box with Rotary Switches
1.9 Control Box with Toggle Switches
1.10 Drive/Steer Controller
Section 2 – Scissors
2.1 Scissors - SJ6826 RT
2.2 Scissors - SJ6832 RT
2.3 Scissor Mounting Hardware
2.4 Scissor Connecting Hardware
2.5 Scissor Arm Control Cable
2.6 Limit Switch
2.7 Lift Cylinder and Mounting Hardware
2.8 Holding Valve
2.9 Light and Beeper
Section 3 – Base Related Parts
3.1 Base
3.2 Tires
3.3 Propane Tray - ANSI/CSA
3.4 Steer Cylinder
3.5 Tie Rod
3.6 Splitter Manifold
3.7 Hydraulic Hose Connections - Splitter Manifold
3.8 Wheel Motor - Front
3.9 Wheel Motor - Rear
3.10 Hydraulic Hose Connections - Main Manifold
3.11 Hydraulic Cabinet - S/N 37 009 781 & above
3.12 Hydraulic Cabinet - S/N 37 009 780 & below
3.13 Hydraulic Tank
3.14 Fuel Tank
3.15 Main Manifold
3.16 Hydraulic Cabinet Door
3.17 Engine Cabinet
3.18 Electrical Panel - S/N 37 000 235 & above
3.19 Electrical Panel - S/N 37 000 234 & below
3.20 Engine to Tray Assembly - Kubota D972
3.21 Engine to Tray Assembly - Kubota D902
3.22 Engine Tray
3.23 Engine Cabinet Door
3.24 Engine and Main Manifold Harnesses
3.25 Electrical Panel Harnesses
Section 4 – Engine Related Parts
4.1 Engine - Kubota DF972
4.2 Air Cleaner - Kubota DF972
4.3 Exhaust - Kubota DF972
4.4 Engine - Kubota WG752
4.5 Air Cleaner - Kubota WG752
4.6 Exhaust - Kubota WG752
4.7 Engine - Kubota D902
4.8 Air Cleaner - Kubota D902
4.9 Exhaust - Kubota D902
4.10 Fuel Line Connections - Kubota DF972 & WG752
4.11 Fuel Line Connections - Kubota D902
4.12 Hydraulic Pump
4.13 Radiator - DF972
4.14 Radiator - WG752
Section 5 – Optional Equipment
5.1 Outrigger/Generator Control Box
5.2 Electrical Harness Connections - Outriggers
5.3 GP-108 Controller
5.4 Flashing Light Relay Harness
5.5 Front and Rear Outriggers
5.6 Outrigger Assembly
5.7 Outrigger Cylinder
5.8 Hydraulic Hose Connections - Outriggers
5.9 Outrigger Manifold
5.10 Hydraulic Generator - Harrison
5.11 Hose Connections - Harrison Hydraulic Generator
5.12 Hydraulic Generator - Fabco & Control Fluid
5.13 Hose Connections - Fabco & Control Fluid Generators
5.14 Hydraulic Generator Relay
5.15 Air Hose to Platform
5.16 Cold Weather Start - DF972/D902
5.17 Cold Weather Start - WG752
5.18 Telematics - ZTR
5.19 Positive Air Shut Off
5.20 Tool Caddy
5.21 Heavy Duty Pipe Rack
5.22 Secondary Guarding Lift Enable Kit
5.23 Elevate Telematics
5.24 Cabinet Locking Service Kit
Section 6 – Labels
6.1 Label Kits
6.2 Labels - Left and Rear
6.3 Labels - Right and Front
6.4 Labels - Top
6.5 Labels - Miscellaneous
6.6 Labels - Cabinets
Section 7 – Tables
7.1 Fluid Tables
