118
7,392
Skyjack Rough Terrain Scissors SJ6826RT SJ6832RT Parts Manual 157950AE 2023
Brand: Skyjack
Type of Machine: Rough Terrain Scissors
Model: Skyjack SJ6826RT, SJ6832RT Rough Terrain Scissors
Serial Number: SJ68XXRT 37002788 through 37003468
Part Number: 157950AE
Publication Date: 2023
Number of Pages: 152 Pages
1.0 Platform Related Parts
1.1 Gate Assembly
1.2 Platform Railing Assembly
1.3 Extension Platform Railing Assembly
1.4 Main and Extension Platform Assembly
1.5 Gate Latch Assembly
1.6 Quick Release Pins
1.7 Air Hose to Platform Assembly
1.8 Platform AC Outlet Assembly
1.9 Control Console Assembly
1.10a Drive/Steer Controller Assembly
1.10b Drive/Steer Controller Assembly
1.11 Scissor Arm Control Cable Assembly
2.0 Scissor Related Parts
2.1 Scissor Assembly (Model 6826RT)
2.2 Scissor Assembly (Model 6832RT)
2.3 Scissar Assembly - Mounting Hardware
2.4 Scissor Assembly - Connecting Hardware
2.5 Limit Switch Assembly
2.6 Lift Cylinder Assembly and Mounting Hardware
2.7 Holding Valve Assembly
2.8 Light and Beeper Assembly
3.0 Base Related Parts
3.1 Base Assembly
3.2 Propane Tray Assembly (ANSI/CSA)
3.3 Steer Cylinder Assembly (with Hardware)
3.4 Tie Rod Assembly (with Hardware)
3.5 Splitter Manifold Assembly
3.6 Hydraulic Hose Connections - Splitter Manifold
3.7 Wheel Motor Assembly (Front)
3.8 Wheel Motor Assembly (Rear)
3.9 Hydraulic Hose Connections - Main Manifold
3.10 Hydrauilc Cabinet Assembly
3.11 Oil Tank Assembly
3.12 Fuel Tank Assembly
3.13 Main Manifold Assembly
3.14 Hydraulic Cabinet Door Assembly
3.15 Engine Cabinet Assembly
3.16 Electrical Panel Assembly
3.17 Engine to Tray Assembly (Kubota DF972)
3.18 Engine to Tray Assembly (Kubota D902)
3.19 Engine Tray Assembly
3.20 Engine Cabinet Door Assembly
3.21 Engine and Main Manifold Harnesses
3.22 Electrcal Panel Harnesses
4.0 Engine Related Parts
4.1 Engine Assembly (Kubota DF972)
4.2 Air Cleaner Assembly Kit (Kubota DF972)
4.3 Exhaust System Assembly (Kubota DF972/D902)
4.4 Radiator Kit (Kubota DF972/D902)
4.5 Hydraulic Pump Assembly (Kubota DF972/D902)
4.6 Single Propane Tank Assembly (Kubota DF972)
4.7 Dual Propane Tank Assembly (Kubota DF972)
4.8 Engine Assembly (Kubota D902)
4.9 Air Cleaner Assembly Kit (Kubota D902)
4.10 Fuel Line Connections (Kubota D902)
5.0 Optional Equipment
5.1 Outrigger Control Box Assembly
5.2 ELectrical Harness Connections - Outriggers
5.3 GP-108 Controller
5.4 Flashing Light Relay Harness
5.5 Front and Rear Outrigger Assembly
5.6 Outrigger Assembly
5.7 Outrigger Cylinder Assembly
5.8 Hydraulic Hose Connections - Outriggers
5.9 Outrigger Manifold Assembly
5.10 800W Inverter Option
5.11 Hydraulic Generator Option
5.12 Hydraulic Hose Connections - Hydraulic Generator
5.13 Hydraulic Generator Relay Assembly
5.14 Scissor Guard Option (with Diesel Fuel)
5.15 Scissor Guard Option (ANSI/CSA with Dual Fuel)
5.16 Work Light Option
6.0 Labels
6.1 Label Kit
6.2 Labels - Chassis (Left and Rear)
6.3 Labels - Chassis (Front and Right)
6.4 Labels - Chassis (Top)
6.5 Labels - Miscellaneous
7.0 Tables
7.1 Fluid Tables
