Skyjack Rough Terrain Scissors SJ6826RT SJ6832RT Parts Manual 143898AF 2023
Brand: Skyjack
Type of Machine: Rough Terrain Scissors
Model: Skyjack SJ6826RT, SJ6832RT Rough Terrain Scissors
Serial Number: 37002164 - 37002787
Part Number: 143898AF
Publication Date: 2023
Number of Pages: 152 Pages
Platform And Related Parts
Figure 1.1. Gate Assembly
Figure 1.2. Platform Railings
Figure 1.3. Extension Platform Railings
Figure 1.4. Main and Extension Platform Assembly
Figure 1.5. Gate Latch Assembly
Figure 1.6. Quick Release Pins
Figure 1.7. Air Hose to Platform Assembly
Figure 1.8. Outlet Box Assembly
Figure 1.9. Control Box Assembly - Hardware
Figure 1.10. Drive/Steer Controller Assembly
Figure 1.11. Scissor Arm Control Cable Assemblies
Scissors And Related Parts
Figure 2.1. Scissor Stack Assembly - Model 6826
Figure 2.2. Scissor Stack Assembly - Model 6832
Figure 2.3. Scissor Stack Assembly Mounting
Figure 2.4. Scissor Arm Assembly Connecting Hardware
Figure 2.5. Limit Switch Assemblies
Figure 2.6. Lift Cylinder Assembly And Mounting Hardware
Figure 2.7. Lift Cylinder Holding Valve Assemblies without Transducer
Figure 2.8. Lift Cylinder Holding Valve Assembly with Transducer
Figure 2.9. Light & Beeper Assemblies
Base And Related Parts
Figure 3.1. Base, Axles and Wheels
Figure 3.2. Propane Tray Assembly
Figure 3.3. Steer Cylinder Assembly with Hardware
Figure 3.4. Tie Rod Assembly with Hardware
Figure 3.5. Splitter Manifold
Figure 3.6. Splitter Manifold Plumbing
Figure 3.7. Front Wheel Motor
Figure 3.8. Rear Wheel Motor
Figure 3.9. Main Manifold Plumbing
Figure 3.10. Hydraulic Cabinet Assembly
Figure 3.11. Oil Tank Assembly
Figure 3.12. Gas Tank Assembly
Figure 3.13. Main Manifold
Figure 3.14. Hydraulic Door Assembly
Figure 3.15. Engine Cabinet Assembly
Figure 3.16. Electrical Panel Assembly
Figure 3.17. Engine Installation (Kubota DF972)
Figure 3.18. Engine Installation (Kubota D902)
Figure 3.19. Tray Engine Assembly
Figure 3.20. Engine Door Assembly
Figure 3.21. Engine and Main Manifold Harness Diagrams
Figure 3.22. Electrical Panel Harness Diagram
Figure 3.23. Load Sensing Components
Engines And Related Parts
Figure 4.1. Engine Assembly (Kubota Engine DF972)
Figure 4.2. Air Cleaner Assembly - Kubota Dual Fuel Engine DF972
Figure 4.3. Exhaust System Assembly - Kubota Engines DF972 / D902
Figure 4.4. Radiator Kit - Kubota DF972 / D902
Figure 4.5. Hydraulic Pump Assembly (Kubota Engine DF972 / D902)
Figure 4.6. Propane Fuel System - Kubota Dual Fuel Engine DF972
Figure 4.7. Propane Fuel System - Dual Tank (Kubota Engine DF972)
Figure 4.8. Engine Assembly (Kubota Engine D902)
Figure 4.9. Air Cleaner Assembly (Kubota Engine D902)
Optional Equipment
Figure 5.1. Outrigger Control Box Assembly
Figure 5.2. Outrigger Electrical Connections
Figure 5.3. GP-108 Controller
Figure 5.4. Flashing Light Relay Harness
Figure 5.5. Front And Rear Outrigger Assembly
Figure 5.6. Outrigger Assembly
Figure 5.7. Outrigger Cylinder Assembly
Figure 5.8. Outrigger Hydraulic Connections
Figure 5.9. Outrigger Manifold Assembly
Figure 5.10. 800W Inverter Option
Figure 5.11. 110/220 Clamp Assembly Option
Figure 5.12. Hydraulic Generator Option
Figure 5.13. Hydraulic Hose Connection - Hydraulic Generator Option
Figure 5.14. Hydraulic Generator Relay Assembly
Figure 5.15. Scissor Guard Option With Diesel Fuel
Figure 5.16. Scissor Guard With Dual Fuel
Figure 5.17. Work Light Option
Labels And Nameplate
Figure 6.1. Label Kit
Figure 6.2. Labels - Chassis (Left and Back)
Figure 6.3. Labels - Chassis (Front and Right)
Figure 6.4. Labels - Chassis (Top)
Figure 6.5. Labels - Misc
Figure 6.6. Labels - Misc
Tables
Table 1.1. SJRT Scissor Fluids
Brand: Skyjack
Optional Equipment
Tables
- Skyjack Rough Terrain Scissors SJ6826RT SJ6832RT Service Manual 157951AF 2023
- Skyjack Rough Terrain Scissors SJ6826RT SJ6832RT Service Manual 167955AGA 2023
- Skyjack Rough Terrain Scissors SJ6826RT SJ6832RT Service Manual 213560ADA 2023
- Skyjack Rough Terrain Scissors SJ6832RTE Operating Manual 159176AE-A 2022
- Skyjack Rough Terrain Scissors SJ6832RTE Operating Manual 194419AFA 2022
- Skyjack Rough Terrain Scissors SJ6832RTE Parts Manual 167571AE 2023
- Skyjack Rough Terrain Scissors SJ6832RTE Parts Manual 194373AF 2023
- Skyjack Rough Terrain Scissors SJ6832RTE Service Manual 167574AGA 2023
- Skyjack Rough Terrain Scissors SJ7127RT to SJ9250RT Operating Manual 129922AE-A 2006
- Skyjack Rough Terrain Scissors SJ7127RT to SJ9250RT Operating Manual 143861AB-A 2008
- Skyjack Rough Terrain Scissors SJ7127RT to SJ9250RT Operating Manual 143884AC-A 2010
- Skyjack Rough Terrain Scissors SJ7127RT to SJ9250RT Operating Manual 157949AB-A 2022
- Skyjack Rough Terrain Scissors SJ7127RT to SJ9250RT Operating Manual 158009AP-A 2013
- Skyjack Rough Terrain Scissors SJ7127RT to SJ9250RT Operating Manual 159148AC-A 2022
- Skyjack Rough Terrain Scissors SJ7127RT to SJ9250RT Operating Manual 159166AC-A 2014
