Skyjack Rough Terrain Scissor Lift SJ9233RT to SJ9253RT Parts Manual 224578AFA 2023
Brand: Skyjack
Type of Machine: Rough Terrain Scissor Lift
Model: Skyjack SJ9233RT, SJ9243RT, SJ9253RT Rough Terrain Scissor Lift
Serial Number: A202000001 - A202999999
Part Number: 224578AFA
Publication Date: 2023
Number of Pages: 250 Pages
Foreword
General
Parts Ordering Information
Method of Listing
Quantities
How To Order Repair Parts
Recommended Service Parts
Section 1 – Platform
1.1 Main Platform Deck
1.2 Main Platform Railings - Single Extension Deck
1.3 Main Platform Railings - Dual Extension Decks
1.4 Full Gate
1.5 Extension Deck Platform
1.6 Extension Deck Railings
1.7 Platform Control Box
1.8 Joystick
1.9 Power Outlet - ANSI/CSA
1.10 Power Outlet - CE/AS/KC
Section 2 – Scissors
2.1 Scissor Assembly - SJ9233 RT
2.2 Scissor Assembly - SJ9243 RT
2.3 Scissor Assembly - SJ9253 RT
2.4 Scissor Level 1
2.5 Scissor Level 2/4
2.6 Scissor Level 3
2.7 Scissor Level Top - SJ9233 RT & SJ9253 RT
2.8 Scissor Level Top - SJ9243 RT
2.9 Center Pin
2.10 Lower Slider
2.11 Upper Slider
2.12 Lift Cylinders
2.13 Splitter Manifolds
2.14 Lift Cylinder Manifolds
2.15 Centering Bar - Top
2.16 Centering Bar - Bottom
2.17 Scissor Electrical Components
2.18 Maintenance Stand - Top - SJ9253 RT
2.19 Maintenance Stand - Bottom
Section 3 – Base
3.1 Chassis
3.2 Drive Shaft Guard
3.3 Chassis Bumper
3.4 Lateral Bracket - Right Side
3.5 Lateral Bracket - Left Side
3.6 Axles
3.7 Differential - Front Axle
3.8 Hub Reduction - Front Axle
3.9 Central Housing - Front Axle
3.10 Steering - Front Axle
3.11 Differential - Rear Axle
3.12 Hub Reduction - Rear Axle
3.13 Brakes - Rear Axle
3.14 Gear Box - Rear Axle
3.15 Central Housing - Rear Axle
3.16 Drive Motor
3.17 Tires
3.18 Ladder
3.19 Fuel Tank
3.20 Outriggers
3.21 Outrigger Cylinder
3.22 Outrigger Limit Switches
3.23 GP401 Controller
3.24 Base Control Box Hardware
3.25 Base Control Box
3.26 Battery
3.27 Hydraulic Tank
3.28 Drive Manifold
3.29 Auxiliary Manifold
3.30 Motor Shift Manifold
3.31 Outrigger Manifold
Section 4 – Engine
4.1 Engine Cover
4.2 Engine - Kubota D1305
4.3 Air Intake - Kubota D1305
4.4 Exhaust - Kubota D1305
4.5 Pump - Kubota D1305
4.6 Bell Housing - Kubota D1305
4.7 Fuel Lines - Kubota D1305
4.8 Electrical Components - Kubota D1305
4.9 Engine - Kubota WG972
4.10 Air Intake - Kubota WG972
4.11 Exhaust - Kubota WG972
4.12 Regulator/Vaporizer - Kubota WG972
4.13 Pump - Kubota WG972
4.14 Bell Housing - Kubota WG972
4.15 Electrical Components - Kubota WG972
4.16 Fuel System - Kubota WG972
4.17 Propane Tank - Kubota WG972
Section 5 – Electrical Harnesses
5.1 Outrigger Manifold Harness
5.2 Drive Manifold Harness
5.3 Kubota D1305 Engine Harness - S/N A202 000 461 and above
5.4 Kubota D1305 Engine Harness - S/N A202 000 460 and below
5.5 Fuse Box - Kubota D1305
5.6 Engine Harness - Kubota WG972
5.7 Positive Air Shut Off Harness
5.8 Fuel Pump Harness
5.9 ECU Power Harness
5.10 Pressure Transducer Harness
5.11 Dual Holding Valve Harness
5.12 Base Control Cable
5.13 Control A Harness
5.14 Control B Harness
5.15 GP401 Controller Harness
5.16 Outrigger Control Harness
5.17 Generator and Oil Cooler Harness
5.18 3.5 kW Generator Control Harness - with Outriggers
5.19 3.5 kW Generator Harness - No Outriggers
5.20 CANBUS Harness
5.21 Platform Harness
5.22 Scissor Harness
Section 6 – Hose Connections
6.1 Standard Hose Numbering System
6.2 Hydraulic Hoses - Base
6.3 Hydraulic Hoses - Outriggers
6.4 Hydraulic Hoses - Scissors
Section 7 – Optional Equipment
7.1 Heavy Duty Pipe Rack
7.2 Tool Caddy
7.3 Material Handling Stand
7.4 Eco Start
7.5 Wire Loop Lock Pin
7.6 RCD Option
7.7 Anti-Overrising Poles (2 Poles)
7.8 Anti-Overrising Poles (4 Poles)
7.9 Belt-Driven Generator - 3.5 kW
7.10 Hydraulic Generator - 7.5 kW
7.11 Hydraulic Hoses - 7.5 kW Generator
7.12 Cold & Arctic Weather Packages
7.13 Arctic Weather Package
7.14 Elevate Telematics
7.15 Elevate Telematics Subscription
7.16 Storage Box
7.17 White Noise Alarm
7.18 Brawler Tires - SJ9243 RT - CE
Section 8 – Labels
8.1 Label Kits
8.2 Labels - Left & Right Sides
8.3 Labels - Front & Back
8.4 Labels - Engines
8.5 Labels - Outriggers
8.6 Labels - Railings
8.7 Labels - Control Boxes
Brand: Skyjack
Foreword
General
Method of Listing
Quantities
1.4 Full Gate
1.8 Joystick
2.4 Scissor Level 1
2.6 Scissor Level 3
2.9 Center Pin
2.10 Lower Slider
2.11 Upper Slider
2.12 Lift Cylinders
Section 3 – Base
3.1 Chassis
3.3 Chassis Bumper
3.6 Axles
3.16 Drive Motor
3.17 Tires
3.18 Ladder
3.19 Fuel Tank
3.20 Outriggers
3.26 Battery
3.27 Hydraulic Tank
3.28 Drive Manifold
Section 4 – Engine
4.1 Engine Cover
5.20 CANBUS Harness
7.2 Tool Caddy
7.4 Eco Start
7.6 RCD Option
7.16 Storage Box
Section 8 – Labels
8.1 Label Kits
- Skyjack Rough Terrain Scissors SJ6826RT SJ6832RT Service Manual 157951AF 2023
- Skyjack Rough Terrain Scissors SJ6826RT SJ6832RT Service Manual 167955AGA 2023
- Skyjack Rough Terrain Scissors SJ6826RT SJ6832RT Service Manual 213560ADA 2023
- Skyjack Rough Terrain Scissors SJ6832RTE Operating Manual 159176AE-A 2022
- Skyjack Rough Terrain Scissors SJ6832RTE Operating Manual 194419AFA 2022
- Skyjack Rough Terrain Scissors SJ6832RTE Parts Manual 167571AE 2023
- Skyjack Rough Terrain Scissors SJ6832RTE Parts Manual 194373AF 2023
- Skyjack Rough Terrain Scissors SJ6832RTE Service Manual 167574AGA 2023
- Skyjack Rough Terrain Scissors SJ7127RT to SJ9250RT Operating Manual 129922AE-A 2006
- Skyjack Rough Terrain Scissors SJ7127RT to SJ9250RT Operating Manual 143861AB-A 2008
- Skyjack Rough Terrain Scissors SJ7127RT to SJ9250RT Operating Manual 143884AC-A 2010
- Skyjack Rough Terrain Scissors SJ7127RT to SJ9250RT Operating Manual 157949AB-A 2022
- Skyjack Rough Terrain Scissors SJ7127RT to SJ9250RT Operating Manual 158009AP-A 2013
- Skyjack Rough Terrain Scissors SJ7127RT to SJ9250RT Operating Manual 159148AC-A 2022
- Skyjack Rough Terrain Scissors SJ7127RT to SJ9250RT Operating Manual 159166AC-A 2014
