Skyjack DC Electric Scissors SJIII3220 to SJIII4632 Parts Manual 165974AM 2022
Brand: Skyjack
Type of Machine: DC Electric Scissors
Model: Skyjack SJIII3220, SJIII3226, SJIII4620, SJIII4626, SJIII4632
Serial Number:
SJIII3220 60004189 to 60999999
SJIII3226 27017551 to 27999999
SJIII46XX 70017596 to 70199999
Part Number: 165974AM
Publication Date: 2022
Number of Pages: 217 Pages
Foreword
General
Parts Ordering Information
Method of Listing
Quantities
How To Order Repair Parts
Section 1 – Platform Related Parts
1.1 Entrance Gates and Chains
1.2 Gate Latch Assembly
1.3 Side Railings - Rigid
1.4 Side Railings - Hinged
1.5 Extension Platform Railing Assembly
1.6 Extension Handrail
1.7 Quick Release Pins
1.8 Main Platform Assembly
1.9 Extension Platform Assembly
1.10 Extension Cylinder Mounting Hardware
1.11 Extension Cylinder Assembly
1.12 Hose Connections - Powered Extension (Models 3220/4620)
1.13 Hose Connections - Powered Extension (Model 4626)
1.14 Platform Control Console Assembly
1.15 Enable Controller Assembly
1.16 Powered Extension Platform Cables
1.17 Extension Platform Harness
1.18 Extension Platform Control Console
1.19 Control Cable Assemblies
1.20 Platform AC Outlet
Section 2 – Scissor Related Parts
2.1 Scissor Stack Assembly (Model 3220/4620)
2.2 Scissor Stack Assembly (Model 3226/4626)
2.3 Scissor Stack Assembly (Model 4632)
2.4 Scissor Stack Assembly - Mounting Hardware
2.5 Scissor Stack Assembly - Connecting Hardware
2.6 Limit Switch Assembly (Scissor Stack)
2.7 Lift Cylinder and Mounting Hardware
2.8 Holding Valve Assembly (Model 3220/4620)
2.9 Holding Valve Assembly (Model 3226/4626/4632)
Section 3 – Base Related Parts
3.1 Base Assembly
3.2 Pothole Protection Device
3.3 Brake Assembly
3.4 Wheel Assembly
3.5 Tie Rod Assembly
3.6 Steer Cylinder Assembly
3.7 Pin Brake Cylinder Assembly
3.8 Rear Drive Manifold Assembly
3.9 Brake Release Manifold Assembly (Models 46xx)
3.10 Front Hub and Spindle Assembly
3.11 Hydraulic Hose Connections - Pin Brake
3.12 Hydraulic Hose - Disc Brake (Models 46xx)
3.13 Base Control Console
3.14 Base Control Console - B
Section 4 – Hydraulic Tray Related Parts
4.1 Hydraulic/Electrical Tray Assembly
4.2 Main Manifold Assembly
4.3 Pump and Motor Assembly
4.4 Proportional Manifold Assembly
4.5 Hydraulic Hose Connections (Hydraulic/Electrical Tray)
Section 5 – Battery Tray Related Parts
5.1 Battery Tray Assembly
5.2 Battery Charger - Delta-Q
5.3 Battery Charger - Signet
Section 6 – Electrical Related Parts
6.1 Electrical Panel Hardware Assembly
6.2 Electrical Panel Hardware Assembly (EE-Rated)
6.3 Main Manifold Harness
6.4 Rear Manifold Harness
6.5 Horn/Flashing Light and Tilt Switch Harnesses
6.6 Holding Valve, Charger Cutout, and Pressure Switch
6.7 Electrical Panel Powerdeck Modification
6.8 Elevate Telematics Harness
Section 7 – Optional Equipment
7.1 24VDC Inverter Assembly (ANSI/CSA)
7.2 Inverter Assembly
7.3 Air Hose to Platform Assembly
7.4 Work Light Option (ANSI/CSA)
7.5 Flashing Amber Light Option
7.6 Dual Flashing Amber Light Option (Excluding EE-Rated)
7.7 Light Duty Pipe Rack Option
7.8 Black Logo Labels Option (Model 4626)
7.9 Board Carrier (Models 3226/4632 including EE-rated)
7.10 Tool Caddy
7.11 Heavy Duty Pipe Rack Assembly
7.12 Elevate Telematics
7.13 Secondary Guarding Lift Enable Kit
Section 8 – Labels
8.1 Label Kit
8.2 Labels - Platform Control Console
8.3 Labels - Miscellaneous
8.4 Labels - Left & Right Sides (Chassis)
8.5 Labels - Chassis (Front & Top)
8.6 Labels - Rear (Scissor and Platform)
8.7 Labels - Rear (Chassis)
Section 9 – Fluids
9.1 Fluid Table
Section 10 – Appendix A - Motor Controller
10.1 Platform Control Console Assembly
10.2 Platform Control Box (Top)
10.3 Enable Controller Assembly
10.4 Hydraulic/Electrical Tray Assembly - Welded Tank
10.5 Hydraulic/Electrical Tray - Welded Tank
10.6 Hydraulic/Electrical Tray Assembly - Plastic Tank
10.7 Hydraulic Tank Lid Assembly - Welded Tank
10.8 Hydraulic Tank Lid Assembly - Plastic Tank
10.9 Motor/Pump Assembly - Plastic Tank
10.10 Main Manifold Assembly - Welded Tank
10.11 Main Manifold Assembly - Plastic Tank
10.12 Hydraulic Hose Connections - Welded Tank
10.13 Hydraulic Hose Connections - Plastic Tank
10.14 Electrical Panel, Hardware and Wire Kit
10.15 RST Wire Assemblies
10.16 Main Manifold Harness
10.17 Rear Manifold Harness
10.18 Charger, Horn/Flashing Lights, Tilt Switch Harnesses
10.19 Control Cable Assemblies
10.20 Powerdeck Conversion Kit - Motor Controller
Brand: Skyjack
Serial Number:
Foreword
General
Method of Listing
Quantities
3.1 Base Assembly
3.3 Brake Assembly
3.4 Wheel Assembly
7.10 Tool Caddy
Section 8 – Labels
8.1 Label Kit
Section 9 – Fluids
9.1 Fluid Table
- Skyjack Rough Terrain Scissors SJ6826RT SJ6832RT Service Manual 157951AF 2023
- Skyjack Rough Terrain Scissors SJ6826RT SJ6832RT Service Manual 167955AGA 2023
- Skyjack Rough Terrain Scissors SJ6826RT SJ6832RT Service Manual 213560ADA 2023
- Skyjack Rough Terrain Scissors SJ6832RTE Operating Manual 159176AE-A 2022
- Skyjack Rough Terrain Scissors SJ6832RTE Operating Manual 194419AFA 2022
- Skyjack Rough Terrain Scissors SJ6832RTE Parts Manual 167571AE 2023
- Skyjack Rough Terrain Scissors SJ6832RTE Parts Manual 194373AF 2023
- Skyjack Rough Terrain Scissors SJ6832RTE Service Manual 167574AGA 2023
- Skyjack Rough Terrain Scissors SJ7127RT to SJ9250RT Operating Manual 129922AE-A 2006
- Skyjack Rough Terrain Scissors SJ7127RT to SJ9250RT Operating Manual 143861AB-A 2008
- Skyjack Rough Terrain Scissors SJ7127RT to SJ9250RT Operating Manual 143884AC-A 2010
- Skyjack Rough Terrain Scissors SJ7127RT to SJ9250RT Operating Manual 157949AB-A 2022
- Skyjack Rough Terrain Scissors SJ7127RT to SJ9250RT Operating Manual 158009AP-A 2013
- Skyjack Rough Terrain Scissors SJ7127RT to SJ9250RT Operating Manual 159148AC-A 2022
- Skyjack Rough Terrain Scissors SJ7127RT to SJ9250RT Operating Manual 159166AC-A 2014
