Skyjack DC Electric Scissors SJIII3220 to SJIII4632 Parts Manual 160609AG 2018
Brand: Skyjack
Type of Machine: DC Electric Scissors
Model: Skyjack SJIII3220, SJIII3226, SJIII4620, SJIII4626, SJIII4632 DC Electric Scissors
Serial Number:
SJIII3220 60003131 to 60004188
SJIII3226 27010035, 27010036, 27010207, 27010423 to 27017550
SJIII46XX 70010111, 70010112, 70010671, 70010916 to 70017595
Part Number: 160609AG
Publication Date: 2018
Number of Pages: 199 Pages
1.0 Platform Related Parts
1.1 Entrance Gates and Chains
1.2 Gate Latch Assembly
1.3a Side Railings - Rigid
1.4 Side Railings - Hinged
1.5a Extension Platform Railing Assembly
1.6a Extension Handrail
1.6b Extension Handrail
1.7 Quick Release Pins
1.8 Main Platform Assembly
1.9a Extension Platform Assembly
1.10a Extension Cylinder Mounting Hardware
1.11a Extension Cylinder Assembly
1.12a Hose Connections - Powered Extension (Models SJIII 3220/4620/4626)
1.13a Hose Connections - Powered Extension (Model SJIII 4626 ANSI/CSA)
1.14 Powered Extension Platform Directional Manifold Assembly
1.15 Platform Control Console Assembly
1.16a Enable Controller Assembly
1.17 Platform Control Console - Powered Extension Platform Cables
1.18 Extension Platform Harness
1.19 Extension Platform Control Console
1.20 Control Cable Assemblies
1.21 Platform AC Outlet
2.0 Scissor Related Parts
2.1 Scissor Stack Assembly (Model SJIII 3220/4620)
2.2 Scissor Stack Assembly (Model SJIII 3226/4626)
2.3 Scissor Stack Assembly (Model SJIII 4632)
2.4 Scissor Stack Assembly - Mounting Hardware
2.5 Scissor Stack Assembly - Connecting Hardware
2.6 Limit Switch Assembly (Scissor Stack)
2.7 Lift Cylinder and Mounting Hardware
2.8 Holding Valve Assembly (Model SJIII 3220/4620)
2.9 Holding Valve Assembly (Model SJIII 3226/4626/4632)
3.0 Base Related Parts
3.1 Base Assembly
3.2 Pothole Protection Device
3.3 Brake Assembly
3.4 Wheel Assembly (Models SJIII 322x & 46xx)
3.5 Tie Rod Assembly
3.6 Steer Cylinder Assembly
3.6a Steer Cylinder Assembly
3.7 Pin Brake Cylinder Assembly
3.8 Rear Drive Manifold Assembly
3.9 Brake Release Manifold Assembly (Models SJIII 46xx)
3.10 Front Hub and Spindle Assembly
3.11 Hydraulic Hose Connections - Pin Brake (Models SJIII 322x)
3.12 Hydraulic Hose Connections - Disc Brake (Models SJIII 46xx)
3.13 Base Control Console
4.0 Hydraulic Tray Related Parts
4.1 Hydraulic/Electrical Tray Assembly
4.2 Main Manifold Assembly
4.3 Pump and Motor Assembly
4.4 Proportional Manifold Assembly
4.5 Hydraulic Hose Connections (Hydraulic/Electrical Tray)
5.0 Battery Tray Related Parts
5.1 Battery Tray Assembly
5.2 Battery Charger - Delta-Q
5.3 Battery Charger - Signet
6.0 Electrical Related Parts
6.1 Electrical Panel Hardware Assembly
6.2 Electrical Panel Hardware Assembly (ANSI/CSA EE Rated)
6.3 Main Manifold Harness
6.4 Rear Manifold Harness
6.5 Horn/Flashing Light and Tilt Switch Harnesses
6.6 Holding Valve, Charger Cutout, and Pressure Switch Harnesses
6.7 Elevate Telematics Harness
7.0 Optional Equipment
7.1 24VDC Inverter and Hardware
7.2 Inverter Assembly
7.3 Labels - Inverter
7.4 Air Hose to Platform Assembly
7.5 Work Light Option (ANSI/CSA)
7.6 Flashing Amber Light Option
7.7 Dual Flashing Amber Light Option (Diagonal)
7.8 Platform Control Console - Long Cable Option (ANSI/CSA)
7.9 Pipe Rack Assembly (ANSI/CSA)
7.10 Black Logo Labels Option (Model SJIII 4626)
7.11 Tool Caddy
7.12 Elevate Telematics
7.13 Secondary Guarding Lift Enable Kit
8.0 Labels
8.1 Label Kit
8.2 Labels - Platform Control Console
8.3 Labels - Miscellaneous
8.4 Labels - Left & Right Sides (Chassis)
8.5 Labels - Chassis (Front & Top)
8.6 Labels - Rear (Scissor and Platform)
9.0 Tables
9.0 Fluid Table
Brand: Skyjack
Serial Number:
3.1 Base Assembly
3.3 Brake Assembly
7.11 Tool Caddy
8.0 Labels
8.1 Label Kit
9.0 Tables
9.0 Fluid Table
- Skyjack Rough Terrain Scissors SJ6826RT SJ6832RT Service Manual 157951AF 2023
- Skyjack Rough Terrain Scissors SJ6826RT SJ6832RT Service Manual 167955AGA 2023
- Skyjack Rough Terrain Scissors SJ6826RT SJ6832RT Service Manual 213560ADA 2023
- Skyjack Rough Terrain Scissors SJ6832RTE Operating Manual 159176AE-A 2022
- Skyjack Rough Terrain Scissors SJ6832RTE Operating Manual 194419AFA 2022
- Skyjack Rough Terrain Scissors SJ6832RTE Parts Manual 167571AE 2023
- Skyjack Rough Terrain Scissors SJ6832RTE Parts Manual 194373AF 2023
- Skyjack Rough Terrain Scissors SJ6832RTE Service Manual 167574AGA 2023
- Skyjack Rough Terrain Scissors SJ7127RT to SJ9250RT Operating Manual 129922AE-A 2006
- Skyjack Rough Terrain Scissors SJ7127RT to SJ9250RT Operating Manual 143861AB-A 2008
- Skyjack Rough Terrain Scissors SJ7127RT to SJ9250RT Operating Manual 143884AC-A 2010
- Skyjack Rough Terrain Scissors SJ7127RT to SJ9250RT Operating Manual 157949AB-A 2022
- Skyjack Rough Terrain Scissors SJ7127RT to SJ9250RT Operating Manual 158009AP-A 2013
- Skyjack Rough Terrain Scissors SJ7127RT to SJ9250RT Operating Manual 159148AC-A 2022
- Skyjack Rough Terrain Scissors SJ7127RT to SJ9250RT Operating Manual 159166AC-A 2014
