Skyjack DC Electric Scissors SJIII3220 to SJIII4632 Parts Manual 143910AE 2018
Brand: Skyjack
Type of Machine: DC Electric Scissors
Model: Skyjack SJIII3220, SJIII3226, SJIII4620, SJIII4626, SJIII4632
Serial Number:
ANSI/CSA & AS
SJIII3220 60001523 to 60002258
SJIII3226 27004500 to 27006431
SJIII46xx 70004720 to 70007138
CE
SJIII3220 60001523 to 60002031
SJIII3226 27004500 to 27005500
SJIII46xx 70004720 to 70006052
Part Number: 143910AE
Publication Date: 2018
Number of Pages: 154 Pages
1.0 Platform Related Parts
Figure 1.1. Entrance Gates and Chains
Figure 1.2. Gate Latch Assembly
Figure 1.3. Side Railing - Rigid Railings
Figure 1.4. Side Railing - Hinged Railings
Figure 1.5. Extension Platform Railing
Figure 1.6. Extension Slide Railing
Figure 1.7. Quick Release Pins
Figure 1.8. Main Platform Assembly
Figure 1.9. Extension Platform Assembly
Figure 1.10. Extension Cylinder Mounting Hardware
Figure 1.11. Extension Cylinder Assembly
Figure 1.12. Hydraulic Hose and Fittings - Extension Cylinder
Figure 1.13a. Platform Control Console Assembly (Toggle Switch)
Figure 1.13b. Platform Control Console Assembly (Rotary switch)
Figure 1.14. Enable Controller Assembly
Figure 1.15. Platform Control Console - Powered Extension Platform Cables
Figure 1.16. Extension Platform Control Console
Figure 1.17. Extension Platform Harness
Figure 1.18. Platform AC Outlet
Figure 1.19. Control Cable Assemblies
2.0 Scissor Related Parts
Figure 2.1. Scissor Arm Assembly (Model 3220/4620)
Figure 2.2. Scissor Arm Assembly (Model 3226/4626)
Figure 2.3. Scissor Arm Assembly (Model 4632)
Figure 2.4. Angle Transducer & Beeper/Light Assembly (CE)
Figure 2.5. Scissor Stack Assembly Mounting
Figure 2.6. Scissor Arm Assembly Connecting Hardware
Figure 2.7. Scissor Arm Limit Switch Assembly
Figure 2.8. Lift Cylinder and Mounting Hardware
Figure 2.9. Holding Valve Assembly (ANSI/CSA - Model 3220/4620)
Figure 2.10. Holding Valve Assembly without Transducer (Model 3226/4626/4632)
Figure 2.11. Holding Valve Assembly (CE - Model 3220/4620)
Figure 2.12. Holding Valve Assembly with Transducer (CE - Model 3226/4626/4632)
3.0 Base Related Parts
Figure 3.1. Base, Axle, & Wheels
Figure 3.2. Pothole Protection Device
Figure 3.3. Control Module Assembly
Figure 3.4. Brake Reference
Figure 3.5. Tie Rod Assembly
Figure 3.6. Steer Cylinder Assembly
Figure 3.7. Pin Brake Cylinder Assembly
Figure 3.8. Rear Drive Manifold Assembly
Figure 3.9. Wheel Assembly
Figure 3.10. Front Hub & Spindle Assembly
Figure 3.11. Hydraulic Hose Connections - Pin Brake (Model 32XX)
Figure 3.12. Hydraulic Hose Connections - Disc Brake (Model 46XX)
Figure 3.13. Base Control Console
4.0 Hydraulic Tray Related Parts
Figure 4.1. Hydraulic/Electrical Assembly
Figure 4.2. Main Manifold Assembly
Figure 4.3. Pump and Motor Assembly (All Models, included EE rated)
Figure 4.4. Pump and Motor Assembly (ANSI/CSA EE rated)
Figure 4.5. Proportional Manifold Assembly
Figure 4.6. Hydraulic Hose Connections (Hydraulic/Electrical Tray)
5.0 Battery Tray Related Parts
Figure 5.1. Battery Tray Assembly (ANSI/CSA & CE)
Figure 5.2. Battery Tray Assembly (ANSI/CSA EE rated)
Figure 5.3. Battery Charger Assembly
6.0 Electrical Related Parts
Figure 6.1. Electrical Panel and hardware Assembly (ANSI/CSA & CE)
Figure 6.2. Electrical Panel Assembly (ANSI/CSA EE rated)
Figure 6.3. Main Manifold Harness
Figure 6.4. Rear Manifold Harness
Figure 6.5. Horn/Flashing Light and Tilt Switch Harnesses (ANSI/CSA & ANSI/CSA EE rated)
Figure 6.6. Holding Valve and Charger Cutout Harnesses
Figure 6.7. Horn & Control Module Harnesses (CE)
7.0 Optional Equipment
Figure 7.1. 24VDC Inverter and Hardware
Figure 7.2. Inverter Assembly
Figure 7.3. Inverter Label Placement
Figure 7.4. Platform Air Supply Hose
Figure 7.5. Work Light Option
Figure 7.6. Flashing Amber Light Option
Figure 7.7. Dual Flashing Amber Light Option (Diagonal) (ANSI/CSA)
Figure 7.8. Tool Caddy
7.9 Elevate Telematics
7.10 Secondary Guarding Lift Enable Kit
Figure 8.1. Label Kit
8.0 Label Kit
Figure 8.2. Label - Platform Control Console
Figure 8.3. Labels and Nameplates - Misc.
Figure 8.4. Labels and Nameplates - Chassis (Left & Right Sides)
Figure 8.5. Labels and Nameplates - Chassis (Front & Top)
Figure 8.6. Labels and Nameplates - Scissor & Platform (Rear)
Figure 8.7. Labels and Nameplates - Chassis (Rear)
Table 9.1. SJ3 Scissor Fluids - Hydraulic Oil
9.0 Fluid Table
Brand: Skyjack
Serial Number:
ANSI/CSA & AS
CE
8.0 Label Kit
9.0 Fluid Table
- Skyjack Rough Terrain Scissors SJ6826RT SJ6832RT Service Manual 157951AF 2023
- Skyjack Rough Terrain Scissors SJ6826RT SJ6832RT Service Manual 167955AGA 2023
- Skyjack Rough Terrain Scissors SJ6826RT SJ6832RT Service Manual 213560ADA 2023
- Skyjack Rough Terrain Scissors SJ6832RTE Operating Manual 159176AE-A 2022
- Skyjack Rough Terrain Scissors SJ6832RTE Operating Manual 194419AFA 2022
- Skyjack Rough Terrain Scissors SJ6832RTE Parts Manual 167571AE 2023
- Skyjack Rough Terrain Scissors SJ6832RTE Parts Manual 194373AF 2023
- Skyjack Rough Terrain Scissors SJ6832RTE Service Manual 167574AGA 2023
- Skyjack Rough Terrain Scissors SJ7127RT to SJ9250RT Operating Manual 129922AE-A 2006
- Skyjack Rough Terrain Scissors SJ7127RT to SJ9250RT Operating Manual 143861AB-A 2008
- Skyjack Rough Terrain Scissors SJ7127RT to SJ9250RT Operating Manual 143884AC-A 2010
- Skyjack Rough Terrain Scissors SJ7127RT to SJ9250RT Operating Manual 157949AB-A 2022
- Skyjack Rough Terrain Scissors SJ7127RT to SJ9250RT Operating Manual 158009AP-A 2013
- Skyjack Rough Terrain Scissors SJ7127RT to SJ9250RT Operating Manual 159148AC-A 2022
- Skyjack Rough Terrain Scissors SJ7127RT to SJ9250RT Operating Manual 159166AC-A 2014
