Skyjack DC Electric Scissors SJIII3215 SJIII3219 Parts Manual 165973AM 2022
Brand: Skyjack
Type of Machine: DC Electric Scissors
Model: Skyjack SJIII3215, SJIII3219 DC Electric Scissors
Serial Number: SJIII3215 10000996 to 10999999, SJIII3219 22057772 to 22999999
Part Number: 165973AM
Publication Date: 2022
Number of Pages: 162 Pages
Section 1 – Platform
1.1 Entrance Gates and Chains
1.2 Side Railing
1.3 Extension Platform Railing
1.4 Extension Slide Railing
1.6 Main Platform
1.7 Gate Latch
1.9 Platform Control Console (Hydraulically Proportional)
1.10 Platform Control Console (Motor Controller)
1.11 Platform Control Box (Motor Controller)
1.12 Enable Controller (Hydraulically Proportional)
1.13 Enable Controller (Motor Controller)
1.14 Platform AC Outlet
1.15 Control Cables (Hydraulically Proportional)
Section 2 – Scissors
2.1 Scissor Stack
2.2 Scissor Stack - Accessories and Hardware
2.3 Scissor Stack - Mounting Hardware
2.4 Scissor Stack - Connecting Hardware
2.5 Scissor Arm Limit Switch
2.6 Lift Cylinder and Mounting Hardware
2.7 Holding Valve
Section 3 – Base
3.1 Base
3.2 Pothole Protection
3.3 Wheel
3.4 Steer Mechanism
3.5 Steering Arm
3.6 Rear Axle
3.7 Free-Wheeling Manifold
3.9 Steer Cylinder
3.11 Base Control Console Hardware - A
3.12 Base Control Console Hardware - B
3.13 Base Control Harness and Switches - A
3.14 Base Control Harness and Switches - B
Section 4 – Hydraulic Tray
4.1 Hydraulic/Electrical Tray (Hydraulically Proportional)
4.2 Hydraulic/Electrical Tray - Steel Tank (Motor Controller)
4.3 Hydraulic/Electrical Tray - Plastic Tank (Motor Controller)
4.4 Hydraulic Tank - Plastic Tank (Motor Controller)
4.5 Hydraulic Tank Lid - Steel Tank
4.7 Hydraulic Tray Hose Connections (Motor Controller)
4.8 Main Manifold
4.9 Motor and Pump (Hydraulically Proportional)
4.10 Motor and Pump - Steel Tank (Motor Controller)
4.11 Motor and Pump - Plastic Tank (Motor Controller)
4.12 Emergency Lowering Manifold
4.14 Hinged Hydraulic/Electrical Cover (EE-Rated)
Section 5 – Battery Tray
5.1 Battery Tray
5.2 Battery Charger - Delta-Q
5.3 Battery Charger - Signet
Section 6 – Electrical Panel
6.1 Electrical Panel and Hardware (Hydraulically Proportional)
6.2 Electrical Panel, Hardware and Wire Kit (Motor Controller)
6.3 Electrical Panel and Hardware (EE-Rated)
6.4 Main Manifold Harness (Hydraulically Proportional)
6.5 Main Manifold Harness (Motor Controller)
6.6 Rear Manifold Harness (Hydraulically Proportional)
6.8 Elevate Telematics Harness
6.9 Horn/Flashing Light, Holding Valve, Tilt & Pressure Switch
Section 7 – Options
7.1 24VDC Inverter and Hardware
7.2 Inverter
7.3 Air Hose to Platform
7.5 Light Duty Pipe Rack
7.7 Dual Flashing Amber Light (Diagonal)
7.8 Board Carrier (SJIII 3219)
7.9 Heavy Duty Pipe Rack
7.11 Tool Caddy
7.12 Elevate Telematics
7.13 Secondary Guarding Lift Enable Kit
Section 8 – Labels
8.1 Label Kit
8.3 Labels - Miscellaneous
8.4 Labels - Sides
8.6 Labels - Front & Back
Brand: Skyjack
1.2 Side Railing
1.6 Main Platform
1.7 Gate Latch
2.1 Scissor Stack
2.7 Holding Valve
Section 3 – Base
3.1 Base
3.3 Wheel
3.4 Steer Mechanism
3.5 Steering Arm
3.6 Rear Axle
3.9 Steer Cylinder
4.8 Main Manifold
5.1 Battery Tray
Section 7 – Options
7.2 Inverter
7.11 Tool Caddy
Section 8 – Labels
8.1 Label Kit
8.4 Labels - Sides
- Skyjack Rough Terrain Scissors SJ6826RT SJ6832RT Service Manual 157951AF 2023
- Skyjack Rough Terrain Scissors SJ6826RT SJ6832RT Service Manual 167955AGA 2023
- Skyjack Rough Terrain Scissors SJ6826RT SJ6832RT Service Manual 213560ADA 2023
- Skyjack Rough Terrain Scissors SJ6832RTE Operating Manual 159176AE-A 2022
- Skyjack Rough Terrain Scissors SJ6832RTE Operating Manual 194419AFA 2022
- Skyjack Rough Terrain Scissors SJ6832RTE Parts Manual 167571AE 2023
- Skyjack Rough Terrain Scissors SJ6832RTE Parts Manual 194373AF 2023
- Skyjack Rough Terrain Scissors SJ6832RTE Service Manual 167574AGA 2023
- Skyjack Rough Terrain Scissors SJ7127RT to SJ9250RT Operating Manual 129922AE-A 2006
- Skyjack Rough Terrain Scissors SJ7127RT to SJ9250RT Operating Manual 143861AB-A 2008
- Skyjack Rough Terrain Scissors SJ7127RT to SJ9250RT Operating Manual 143884AC-A 2010
- Skyjack Rough Terrain Scissors SJ7127RT to SJ9250RT Operating Manual 157949AB-A 2022
- Skyjack Rough Terrain Scissors SJ7127RT to SJ9250RT Operating Manual 158009AP-A 2013
- Skyjack Rough Terrain Scissors SJ7127RT to SJ9250RT Operating Manual 159148AC-A 2022
- Skyjack Rough Terrain Scissors SJ7127RT to SJ9250RT Operating Manual 159166AC-A 2014
