7,392
Skyjack DC Electric Scissors SJIII3215 SJIII3219 Parts Manual 155180AE 2018
Brand: Skyjack
Type of Machine: DC Electric Scissors
Model: Skyjack SJIII3215, SJIII3219 DC Electric Scissors
Serial Number:
SJIII3215 10000631 to 10000838
SJIII3219 22022793 to 22037436 (excluding 22032963, 22032964 and 22035881)
Part Number: 155180AE
Publication Date: 2018
Number of Pages: 134 Pages
1.0 Platform Related Parts
1.1 Entrance Gates and Chains
1.2 Gate Latch Assembly
1.3 Side Railing Assembly
1.4 Extension Platform Railing Assembly
1.5 Extension Slide Railing
1.6 Quick Release Pins
1.7 Main Platform Assembly
1.8 Extension Platform Assembly
1.9 Platform Control Console Assembly
1.10a Enable Controller Assembly
1.10b Enable Controller Assembly
1.11 Platform AC Outlet Assembly
1.12 Control Cable Assemblies
2.0 Scissor Related Parts
2.1 Scissor Stack Assembly
2.2 Scissor Stack Assembly - Accessories and Hardware
2.3 Scissor Stack Assembly - Mounting Hardware
2.4 Scissor Stack Assembly - Connecting Hardware
2.5a Scissor Arm Limit Switch Assemblies
2.5b Scissor Arm Limit Switch Assemblies
2.6 Lift Cylinder Assembly and Mounting Hardware
2.7 Holding Valve Assembly
3.0 Base Related Parts
3.1 Base Assembly
3.1 Base Assembly
3.2 Pothole Protection Device
3.3 Free-Wheeling Manifold Assembly
3.4 Tire Assembly
3.5 Steer Mechanism
3.6 Steer Assembly
3.7 Rear Axle Assembly
3.8 Brake Cylinder Assembly
3.9 Steer Cylinder Assembly
3.10 Hydraulic Hose Connections - Drive/Steer
3.11 Base Control Console Hardware
3.12 Base Control Harness and Switches
4.0 Hydraulic Tray Related Parts
4.1 Hydraulic/Electrical Tray Assembly
4.2 Main Manifold Assembly
4.3 Motor and Pump Assembly
4.4 Emergency Lowering Manifold Assembly
4.5 Proportional Manifold Assembly
4.6 Hydraulic Tank Lid Assembly
4.7 Hydraulic Hose Connections - Controls
5.0 Battery Tray Related Parts
5.1 Battery Tray Assembly
5.2 Battery Charger
6.0 Electrical Related Parts
6.1 Electrical Panel and Hardware Assembly
6.2 Electrical Panel and Hardware Assembly (ANSI/CSA EE rated)
6.3 Main Manifold Harness
6.4 Rear Manifold Harness
6.5 Horn/Flashing Light, Holding Valve, Tilt & Pressure Switch Harnesses
7.0 Optional Equipment
7.1 24VDC Inverter and Hardware (ANSI/CSA)
7.2 Inverter Assembly (ANSI/CSA)
7.3 Inverter Label Placement
7.4 Platform Air Supply Hose
7.5 Slate Grey Label Option
7.6 Flashing Amber Light Option
7.7 Dual Flashing Amber Light Option (Diagonal)
7.8 Platform Control Console - Long Cable Option (ANSI/CSA)
7.9 Gel Battery and Charger Option
7.10 Pipe Rack Assembly (ANSI/CSA)
7.11 Tool Caddy
7.12 Elevate Telematics
7.13 Secondary Guarding Lift Enable Kit
8.0 Labels
8.0 Labels
8.1 Label Kit
8.2 Label - Platform Control Console
8.3 Labels - Miscellaneous
8.4 Labels - Sides
8.5 Labels - Front & Back
8.5 Labels - Front & Back (Continued)
8.6 Labels - Chassis Top
9.0 Fluid Table
9.1 Fluid Table
