7,392
Skyjack DC Electric Scissors SJ3220 to SJ4732 Parts Manual 223197AEA 2023
Brand: Skyjack
Type of Machine: DC Electric Scissors
Model: Skyjack SJ3220, SJ3226, SJ4720, SJ4726, SJ4732 DC Electric Scissors
Serial Number:
SJ3220 A101000001 - A101999999, SJ3226 A101000001 - A101999999,
SJ4720 A102000001 - A102999999, SJ4726 A102000001 - A102999999,
SJ4732 A102000001 - A102999999
Part Number: 223197AEA
Publication Date: 2023
Number of Pages: 228 Pages
Foreword
General
Parts Ordering Information
Method of Listing
Quantities
How To Order Repair Parts
Recommended Service Parts
Section 1 – Platform
1.1 Main Platform - SJ3220/26
1.2 Main Platform - SJ4720/26/32
1.3 Main Platform - SJ4726 with Aircraft Option
1.4 Extension Platform
1.5 Main Railings
1.6 Main Railings - SJ4726 Aircraft Option
1.7 Extension Railing
1.8 Extension Railing and Front Gate - Aircraft Option
1.9 Rear Gates - SJ3220/26
1.10 Rear Gates - SJ4720/26/32
1.11 Full Rear Gate - Aircraft Option
1.12 Gate Latch
1.13 Powerdeck Cylinder
1.14 Platform Control Box
1.15 Control Box Cover
1.16 Joystick
1.17 Powerdeck Controls
1.18 Platform A/C Outlet
1.19 Platform Protection - Aircraft Protection
1.20 Outdoor Switch - SJ3226 ANSI/CSA
Section 2 – Scissors
2.1 Scissors - SJ3220, SJ4720
2.2 Scissors - SJ3226, SJ4726
2.3 Scissors - SJ4732
2.4 Scissors Hardware
2.5 Lift Cylinder
2.6 Cylinder Manifold - SJ3220, SJ4720
2.7 Cylinder Manifold - SJ3226, SJ4726/32
2.8 Pressure Transducer
2.9 Flashing Light
2.10 Horn
2.11 Angle Transducer
2.12 Beeper
Section 3 – Base
3.1 Base - SJ3220/3226
3.2 Base - SJ4720/4726/4732
3.3 Counterweight - SJ3220/26
3.4 Counterweight - SJ4720/26/32
3.5 Pin Brakes (ANSI/CSA)
3.6 Wheel Motor (ANSI/CSA)
3.7 Wheel Motor/Disc Brake (CE, AS & KC)
3.8 Steering
3.9 Tie Rod
3.10 Steer Cylinder
3.11 Pothole Protection
3.12 Wheels
3.13 Drive Manifold - SJ3220/26, SJ4726/32 ANSI/CSA
3.14 Drive Manifold - SJ3220/26 CE, AS & KC
3.15 Drive Manifold - SJ4720/26/32 CE, AS & KC
3.16 Base Control - Plastic Box
3.17 Base Control - Metal Box
3.18 Ladder
3.19 Skycoded Control Module
Section 4 – Hydraulic Tray
4.1 Hydraulic Tray
4.2 Hydraulic Tank
4.3 Hydraulic Tank - EE-Rated/Aircraft Protection
4.4 Main Manifold
4.5 Powerdeck Manifold (Option)
4.6 Counterweight
4.7 Motor, Pump and Contactor
4.8 Skycoded Display Module
4.9 Emergency Lowering Switch
Section 5 – Battery Tray
5.1 Battery Tray
5.2 Batteries
5.3 Battery Charger
Section 6 – Electrical Harnesses
6.1 Main Harness - SJ3220/26
6.2 Main Harness - SJ4720/26/32
6.3 Platform Control Cable
6.4 Platform Control Cable - SGLE
6.5 Platform Control Cable - Aircraft Protection
6.6 Holding Valve Harness
6.7 Prop Lowering Valve Harness (CE Only)
6.8 Control Cable - Base to Platform
6.9 Dual Flashing Light Harness
6.10 Base Control Harness - Plastic Box
6.11 Base Control Harness - Metal Box
6.12 Powerdeck Harnesses
6.13 Power Cables
6.14 Power Cables - Aircraft Protection
6.15 Interlocks - SJ4726 Aircraft Protection
6.16 Anti-Overrising Posts Limit Switches (KC Only)
6.17 Anti-Overrising Posts Harnesses (KC Only)
6.18 Elevate Telematics Harness
6.19 Outdoor Switch Harness
Section 7 – Hose Connections
7.1 Standard Hose Numbering System
7.2 Hose Connections - SJ3220/26 (ANSI/CSA)
7.3 Hose Connections - SJ3220/26 (CE, AS & KC)
7.4 Hose Connections - SJ4726/32 (ANSI/CSA)
7.5 Hose Connections - SJ4720/26/32 (CE, AS & KC)
7.6 Hose Connections - Hydraulic Tray
7.7 Air Hose - Aircraft Protection
Section 8 – Options
8.1 Inverter Group (ANSI/CSA Only)
8.2 Inverter (ANSI/CSA Only)
8.3 White Noise Alarm
8.4 Dual Flashing Light Group
8.5 Light Duty Pipe Racks
8.6 Universal Heavy-Duty Pipe Rack
8.7 Universal Board Carrier
8.8 Elevate Telematics, Keypad & BMS
8.9 Residual Current Device (CE Only)
8.10 Anti-Overrising Posts (KC Only)
8.11 Wire Locking Pin
8.12 Tray Locking Plates
8.13 Tool Caddy
8.14 ECOTray (SJ3226 Only)
8.15 ECOTray (SJ4720/26/32 Only)
8.16 Perimeter Lights
8.17 ACPP Black Logos (SJ4726 Only)
Section 9 – Labels
9.1 Label Kits
9.2 Labels - Platform Controls
9.3 Labels - Miscellaneous
9.4 Labels - Sides (SJ3220/26)
9.5 Labels - Sides (SJ4720/26/32)
9.6 Labels - Front, Back & Top (SJ3220/26)
9.7 Labels - Front, Back & Top (SJ4720/26/32)
9.8 Labels - Base Control Console
9.9 Labels - SJ4726 Aircraft Protection
9.10 Labels - Lift Here (SJ4726 Aircraft Protection)
9.11 Labels - Hose Layout (KC Only)
9.12 Labels - Anti-Overrising Posts (KC Only)
