118
6,911
Skyjack Articulating Booms SJ85AJ Service Manual 210341AK 2023
Brand: Skyjack
Type of Machine: Articulating Booms
Type of Manual: Service Manual, Electrical Schematic, Hydraulic Schematic
Model: Skyjack SJ85AJ Articulating Booms
Serial Number: 95400001 to 95499999
Part Number: 210341AK
Publication Date: 2023
Number of Pages: 210 Pages
Section 1 – Scheduled Maintenance
1.1 Read and Heed
1.2 Maintenance and Service
1.3 Scheduled Maintenance
1.4 Owner’s Annual Inspection Record
1.5 Pre-Delivery/Maintenance Inspection Checklist
1.6 Scheduled Maintenance Inspections
1.7 Function Tests
Section 2 – Maintenance Tables and Diagrams
2.1 Standard Hose Numbering System
2.2 Torque Specifications for Fasteners (US)
2.3 Torque Specifications for Fasteners (Metric)
2.4 Torque Specifications for Hydraulic Couplings & Hoses
2.5 Axle Torque Specifications
2.6 Axle Maintenance Intervals
2.7 MEWP Torque Specifications
2.8 Tire Specifications
2.9 Floor Loading Pressure
2.10 Specifications & Features - Dimensional Data
2.11 Specifications and Features - Performance & Speeds
2.12 Hydraulic Specifications
2.13 Specifications and Features - Engines & Fluids
2.14 Reach
2.15 Dimensions
2.16 Axle Oscillation Zones
Section 3 – System Component Identification and Schematics
3.1 Electrical Symbol Chart
3.2 Hydraulic Symbol Chart
3.3 Wire Number and Color Code
3.4 Wire Numbers and Color Codes - Additional
3.5 Hydraulic Parts List
3.6 Electrical Parts List
3.7 Brake Manifold Port Identification
3.8 Jib Manifold Port Identification
3.9 Main Manifold - Hose Port Identification
3.10 Main Manifold - Hydraulic Components
3.11 Main Manifold - Electrical Components
3.12 SGE Harness Connection
3.13 Platform & Jib Harness Connection
3.14 Footswitch Harness Connection
3.15 Main Manifold Harness
3.16 Platform to Base Control Cables
3.17 Limit Switch Connections - Base Control Box
3.18 Engine Control Wiring - Deutz TD2.9L
3.19 Engine Control Wiring - Deutz D2011
3.20 Engine Control Wiring - Kubota WG3800
3.21 Engine Control Wiring - Perkins 2.2TA
3.22 Anti-Overrising Limit Switch Harnesses - KC
3.23 Deutz EDC-F Harness
3.24 Load Cell Wiring
3.25 Hydraulic Schematic
3.26 Electrical Schematic - ANSI/CSA & AS (serial number 95400457 and below)
3.27 Electrical Schematic - ANSI/CSA & AS (serial number 95400458 and above)
3.28 Electrical Schematic - CE (serial number 95400457 and below)
3.29 Electrical Schematic - CE (serial number 95400458 and above)
3.30 Electrical Schematic - KC (serial number 95400457 and below)
3.31 Electrical Schematic - KC (serial number 95400458 and above)
3.32 Platform Controls Wiring
3.33 Platform Controls - Harness View
3.34 Platform Controls - Schematic View
3.35 Base Controls Wiring - ANSI/CSA & AS
3.36 Base Controls Wiring - ANSI/CSA with Positive Air Shut-off Option
3.37 Base Controls Wiring - CE
3.38 Base Controls Wiring - KC
3.39 Engine Schematic - Deutz TD2.9L
3.40 Engine Schematic - Deutz D2011
3.41 Engine Schematic - Perkins 2.2TA
3.42 Engine Schematic - Kubota WG3800
3.43 Engine Harness - Deutz TD2.9L
3.44 Engine Harness - Perkins 2.2TA
3.45 Engine Harness - Kubota WG3800
Section 4 – Troubleshooting Information
4.1 Introduction
4.2 Electrical System
4.3 Hydraulic System
Section 5 – Procedures
5.1 General
5.2 Platform
5.3 Boom
5.4 Turret
5.5 Deutz Diesel Engines
5.6 Hydraulic Tank
5.7 Manifolds and Hydraulic Pumps
5.8 Axles
5.9 Grease Points
5.10 Load Sensing System
