Skyjack Articulating Booms SJ85AJ Parts Manual 229037AHA 2023
SkyjackArticulating Booms SJ85AJ Parts Manual 229037AHA 2023
Brand: Skyjack
Type of Machine: Articulating Booms
Model: Skyjack SJ85AJ Articulating Booms
Serial Number: A303000001 - A303999999
Part Number: 229037AHA
Publication Date: 2023
Number of Pages: 310 Pages
Foreword
General
Parts Ordering Information
Method of Listing
Quantities
How To Order Repair Parts
Recommended Service Parts
Section 1 – Platform
1.1 Platform with Three Drop Bars
1.2 Platform with Swing Gate
1.3 Platform Base
1.4 Railings
1.5 Swing Gate
1.6 Drop Bar Gate
1.7 Footswitch
1.8 Platform Control Box
1.9 Boom/Turret Controller
1.10 Drive/Steer Controller
1.11 Riser Boom Controller
1.12 Platform Terminal Strip
1.13 SGE
1.14 Platform Outlet - ANSI/CSA
1.15 Power to Platform - Outlet and Plugs - CE
Section 2 – Boom
2.1 Jib
2.2 Jib Manifold
2.3 Cable Track
2.4 Fly Boom
2.5 Main Boom
2.6 Upper Pivot
2.7 Upper Riser Arm
2.8 3rd Riser Arm
2.9 Lower Pivot
2.10 Link Arm
2.11 2nd Riser Arm
2.12 Lower Riser Arm
2.13 Limit Switches
Section 3 – Cylinders
3.1 Jib Cylinder
3.2 Slave Cylinder
3.3 Extension Cylinder
3.4 Master Cylinder
3.5 Main Lift Cylinder
3.6 Riser Cylinder
3.7 Axle Lock Cylinder
Section 4 – Turret
4.1 Turret
4.2 Engine Tray
4.3 Cowling - Engine Side
4.4 Cowling - Controls Side
4.5 Hydraulic Tank
4.6 Fuel Tank - Diesel
4.7 Fuel Tank - Gasoline
4.8 Swing Drive
4.9 Main & Brake Manifold Hardware
4.10 Main Manifold
4.11 Brake Manifold
4.12 Emergency Pump
4.13 Batteries
4.14 Battery Cables
4.15 Base Controls
4.16 Base Terminal Strip - ANSI/CSA & AS
4.17 Base Terminal Strip - CE
4.18 Counterweight - Turret
Section 5 – Base
5.1 Chassis
5.2 Rotary Manifold
5.3 Front Axle
5.4 Rear Axle
5.5 Differential - Front Axle
5.6 Hub Reduction - Front Axle
5.7 Brakes - Front Axle
5.8 Central Housing - Front Axle
5.9 Steering Assembly - Front Axle
5.10 Trunnion - Front Axle
5.11 Driveshaft
5.12 Differential - Rear Axle
5.13 Hub Reduction - Rear Axle
5.14 Central Housing - Rear Axle
5.15 Brakes - Rear Axle
5.16 Gear Box & Motors
5.17 Gear Box
5.18 Tires
5.19 Counterweight - Base
5.20 Propane Tanks
Section 6 – Engines
6.1 Engine - Deutz TD2.9L
6.2 Air Intake - Deutz TD2.9L
6.3 Radiator - Deutz TD2.9L
6.4 Engine - Deutz TCD2.2
6.5 Radiator - Deutz TCD2.2 - S/N A303 000 553 & above
6.6 Radiator - Deutz TCD2.2 - S/N A303 000 552 & below
6.7 Air Intake - Deutz TCD2.2
6.8 Engine - Deutz D2011
6.9 Air Intake - Deutz D2011
6.10 Engine - Kubota WG3800
6.11 Air Intake - Kubota WG3800
6.12 Radiator - Kubota WG3800
6.13 Exhaust - Kubota WG3800
6.14 Engine Coupling - Deutz
6.15 Engine Coupling - Kubota
6.16 Drive & System Pumps
6.17 Engine Controls
6.18 Terminal Strip - Engine Controls
Section 7 – Electrical Harnesses
7.1 Main Harness
7.2 Jib and Platform Rotate Harness
7.3 Control Cables
7.4 Engine Harness - Deutz TD2.9L
7.5 Engine Harness - Deutz TCD2.2
7.6 Engine Harness - Kubota WG3800
7.7 Glow Plug Harness - Deutz TCD2.2
Section 8 – Hose Connections
8.1 Standard Hose Numbering System
8.2 Hydraulic Hoses – Boom
8.3 Hydraulic Hoses – Turret
8.4 Hydraulic Hoses – Drive & System Pumps
8.5 Hydraulic Hoses – Base
8.6 Fuel Lines – Deutz TD.9L & Deutz TCD2.2
8.7 Fuel Lines – Deutz D2011
8.8 Fuel Lines – Gasoline - Kubota WG3800
8.9 Fuel Lines – Propane - Kubota WG3800
8.10 Grease Line
Section 9 – Optional Equipment
9.1 Oil Cooler with No Generator
9.2 Oil Cooler
9.3 Generator and Cooler Assembly - 3.5 kW
9.4 Generator - 3.5 kW
9.5 Generator and Cooler Assembly - 7.5 kW
9.6 Generator - 7.5 kW
9.7 Generator and Cooler Assembly - 12 kW
9.8 Generator - 12 kW
9.9 Generator and Oil Cooler Wiring
9.10 Welder
9.11 Pipe Rack
9.12 External Railing
9.13 Control Box Cover
9.14 Tool Caddy
9.15 Work Lights
9.16 Flashing Light
9.17 All Motion Alarm
9.18 Residual Current Device (RCD)
9.19 Diesel Scrubber
9.20 Positive Air Shut-off Option
9.21 Hostile Environment
9.22 Cold Start Package
9.23 Arctic Package
9.24 Load Circuit
9.25 Block Heater
9.26 Air Line to Platform
9.27 Half-Height Platform Mesh
9.28 Elevate Telematics
9.29 Elevate Telematics Subscription
Section 10 – Labels
10.1 Label Kits
10.2 Labels - Controls Side
10.3 Labels - Engine Side
10.4 Labels - Platform
Brand: Skyjack
Foreword
General
Method of Listing
Quantities
1.3 Platform Base
1.4 Railings
1.5 Swing Gate
1.6 Drop Bar Gate
1.7 Footswitch
1.13 SGE
Section 2 – Boom
2.1 Jib
2.2 Jib Manifold
2.3 Cable Track
2.4 Fly Boom
2.5 Main Boom
2.6 Upper Pivot
2.7 Upper Riser Arm
2.8 3rd Riser Arm
2.9 Lower Pivot
2.10 Link Arm
2.11 2nd Riser Arm
2.13 Limit Switches
3.1 Jib Cylinder
3.2 Slave Cylinder
3.4 Master Cylinder
3.6 Riser Cylinder
Section 4 – Turret
4.1 Turret
4.2 Engine Tray
4.5 Hydraulic Tank
4.8 Swing Drive
4.10 Main Manifold
4.11 Brake Manifold
4.12 Emergency Pump
4.13 Batteries
4.14 Battery Cables
4.15 Base Controls
Section 5 – Base
5.1 Chassis
5.2 Rotary Manifold
5.3 Front Axle
5.4 Rear Axle
5.11 Driveshaft
5.17 Gear Box
5.18 Tires
5.20 Propane Tanks
Section 6 – Engines
7.1 Main Harness
7.3 Control Cables
8.10 Grease Line
9.2 Oil Cooler
9.10 Welder
9.11 Pipe Rack
9.14 Tool Caddy
9.15 Work Lights
9.16 Flashing Light
9.23 Arctic Package
9.24 Load Circuit
9.25 Block Heater
Section 10 – Labels
10.1 Label Kits
- Skyjack Rough Terrain Scissors SJ6826RT SJ6832RT Service Manual 157951AF 2023
- Skyjack Rough Terrain Scissors SJ6826RT SJ6832RT Service Manual 167955AGA 2023
- Skyjack Rough Terrain Scissors SJ6826RT SJ6832RT Service Manual 213560ADA 2023
- Skyjack Rough Terrain Scissors SJ6832RTE Operating Manual 159176AE-A 2022
- Skyjack Rough Terrain Scissors SJ6832RTE Operating Manual 194419AFA 2022
- Skyjack Rough Terrain Scissors SJ6832RTE Parts Manual 167571AE 2023
- Skyjack Rough Terrain Scissors SJ6832RTE Parts Manual 194373AF 2023
- Skyjack Rough Terrain Scissors SJ6832RTE Service Manual 167574AGA 2023
- Skyjack Rough Terrain Scissors SJ7127RT to SJ9250RT Operating Manual 129922AE-A 2006
- Skyjack Rough Terrain Scissors SJ7127RT to SJ9250RT Operating Manual 143861AB-A 2008
- Skyjack Rough Terrain Scissors SJ7127RT to SJ9250RT Operating Manual 143884AC-A 2010
- Skyjack Rough Terrain Scissors SJ7127RT to SJ9250RT Operating Manual 157949AB-A 2022
- Skyjack Rough Terrain Scissors SJ7127RT to SJ9250RT Operating Manual 158009AP-A 2013
- Skyjack Rough Terrain Scissors SJ7127RT to SJ9250RT Operating Manual 159148AC-A 2022
- Skyjack Rough Terrain Scissors SJ7127RT to SJ9250RT Operating Manual 159166AC-A 2014
