118
6,911
Skyjack Articulating Booms SJ63AJ+ SJ63AJ Parts Manual 229036AFA 2023
Brand: Skyjack
Type of Machine: Articulating Booms
Model: Skyjack SJ63AJ+, SJ63AJ Articulating Booms
Serial Number:
SJ63AJ+ A302000001 - A302099999
SJ63AJ A302000001 - A302099999
Part Number: 229036AFA
Publication Date: 2023
Number of Pages: 320 Pages
Foreword
General
Parts Ordering Information
Method of Listing
Quantities
How To Order Repair Parts
Recommended Service Parts
Section 1 – Platform
1.1 Platform with Drop Bars
1.2 Platform with Swing Gate
1.3 Railings
1.4 Platform Base
1.5 Swing Gate
1.6 Drop Bar
1.7 Footswitch
1.8 Platform Control Box - CE & AS
1.9 Platform Control Box - ANSI/CSA
1.10 Boom / Turret Controller
1.11 Drive / Steer Controller
1.12 Riser Controller
1.13 SGE
1.14 Platform Terminal Strip - ANSI/CSA
1.15 Platform Terminal Strip - CE
1.16 Platform Terminal Strip - AS
1.17 Outlet 110 V - ANSI/CSA
1.18 Power to Platform - Outlet and Plugs - CE
Section 2 – Boom
2.1 Riser
2.2 Main and Fly Boom
2.3 Fly
2.4 Upper Pivot
2.5 Cable Track
2.6 Jib
2.7 Jib Manifold
2.8 Limit Switches
2.9 Rotary Actuator
Section 3 – Cylinders
3.1 Riser Lift
3.2 Riser
3.3 Lift Cylinder
3.4 Master Cylinder
3.5 Slave Cylinder
3.6 Axle Lock Cylinder
3.7 Extension Cylinder
3.8 Jib Cylinder
Section 4 – Turret
4.1 Turret
4.2 Cowling Mounting - Engine Side
4.3 Cowling Mounting - Controls Side
4.4 Cowling - Engine Side
4.5 Cowling - Controls Side
4.6 Counterweight
4.7 Engine Tray
4.8 Main Manifold - ANSI/CSA
4.9 Main Manifold - CE & AS
4.10 Brake Manifold
4.11 Fuel Tank - Diesel
4.12 Fuel Tank - Gasoline
4.13 Hydraulic Tank
4.14 High Pressure Filter
4.15 Swing Drive
4.16 Base Controls - ANSI/CSA
4.17 Base Controls - CE & AS
4.18 Base Terminal Strip - ANSI/CSA
4.19 Base Terminal Strip - CE
4.20 Base Terminal Strip - AS
4.21 Emergency Power Unit
4.22 Battery
4.23 High Pressure Shuttle Valve
4.24 Grease Line
Section 5 – Base
5.1 Base
5.2 Axle Hardware - Front
5.3 Axle Hardware - Rear
5.4 Front Axle
5.5 Central Housing - Front Axle
5.6 Differential - Front Axle
5.7 Steering - Front Axle
5.8 Trunnion - Front Axle
5.9 Drive Shaft
5.10 Rear Axle
5.11 Differential - Rear
5.12 Central Housing - Rear
5.13 Gear Box
5.14 Brakes
5.15 Rotary Manifold
5.16 Propane Tank
5.17 Tires
Section 6 – Engines
6.1 Engine - Deutz TD2.9L
6.2 Radiator - Deutz TD2.9L
6.3 Air Intake - Deutz TD2.9L
6.4 Engine - Deutz TCD2.2
6.5 Radiator - Deutz TCD2.2
6.6 Air Intake - Deutz TCD2.2
6.7 Engine - Deutz D2011
6.8 Engine - Kubota WG2503
6.9 Radiator & Air Intake - Kubota WG2503
6.10 Drive & System Pumps
6.11 Engine Coupling - Deutz
6.12 Engine Coupling - Kubota
Section 7 – Electrical Harnesses
7.1 Main Electrical and Fuel Level Switch Harnesses
7.2 Lowering Throttle Valve Harness
7.3 Rotate Select Harness
7.4 Cable Harnesses
7.5 Control and CANbus Cables - ANSI/CSA
7.6 Control Cables - CE & AS
7.7 Differential Lock Valve Harness
7.8 Glow Plug Harness - Deutz TD2.9L
7.9 Glow Plug Harness - Deutz TCD2.2
7.10 Glow Plug Harness - Deutz D2011
7.11 Engine Interface Harness - Kubota WG2503
7.12 Engine Interface Harness - Deutz TD2.9L
7.13 Engine Interface Harness - Deutz TCD2.2
7.14 ECU Harness - Deutz D2011
Section 8 – Hose Connections
8.1 Hose Numbering System
8.2 Hydraulic Hoses - Turret
8.3 Hydraulic Hoses - Chassis
8.4 Hydraulic Hoses - Drive & System Pumps
8.5 Hydraulic Hoses - Boom - ANSI/CSA
8.6 Hydraulic Hoses - Boom - CE & AS
8.7 Fuel Lines - Deutz TD2.9L
8.8 Fuel Lines - Deutz D2011
8.9 Fuel Lines - Kubota WG2503
Section 9 – Optional Equipment
9.1 Diesel Scrubber
9.2 All Motion Alarm
9.3 Air Hose to Platform
9.4 Hostile Environment Kit
9.5 Control Box Cover
9.6 Hydraulic Oil Cooler
9.7 Hoses - Hydraulic Oil Cooler
9.8 Oil Cooler Wiring
9.9 Generator - 3.5 kW
9.10 Generator - 12 kW
9.11 Generator - 7.5 kW
9.12 Hoses - 3.5 kW Generator
9.13 Hoses - 12 kW Generator
9.14 Hoses - 7.5 kW Generator
9.15 Generator Wiring
9.16 Welder & Mount
9.17 Cold Start
9.18 Arctic Package
9.19 Load Circuit
9.20 Glazier Package
9.21 External Railing
9.22 Pipe Rack
9.23 Tool Caddy
9.24 Half-Height Platform Mesh
9.25 Positive Air Shut-off Valve - Deutz TD2.9L
9.26 Positive Air Shutt-off Valve - Deutz D2011
9.27 Residual Current Device (RCD)
9.28 Oil Quick Drain
9.29 Elevate Telematics - ANSI/CSA
9.30 Elevate Telematics - CE & AS
9.31 Elevate Telematics Subscription
9.32 Flashing Light
Section 10 – Labels
10.1 Label Kits
10.2 Labels - Engine Side
10.3 Labels - Controls Side
10.4 Labels - Controls Compartment
10.5 Labels - Engine Compartment
10.6 Labels - Platform
10.7 Labels - Front & Back
