Skyjack Articulating Booms SJ63AJ Service Manual 194314AN 2023
Brand: Skyjack
Type of Machine: Articulating Booms
Type of Manual: Service Manual, Electrical Schematic, Hydraulic Schematic
Model: Skyjack SJ63AJ Articulating Booms
Serial Number: 95300481 to 95399999
Part Number: 194314AN
Publication Date: 2023
Number of Pages: 342 Pages
Section 1 – Scheduled Maintenance
1.1 Read and Heed
1.2 Maintenance and Service
1.3 Scheduled Maintenance
1.4 Owner’s Annual Inspection Record
1.5 Pre-Delivery/Maintenance Inspection Checklist
1.6 Scheduled Maintenance Inspections
1.7 Function Tests
Section 2 – Maintenance Tables and Diagrams
2.1 Standard Hose Numbering System
2.2 Torque Specifications for Fasteners (US Imperial)
2.3 Torque Specifications for Fasteners (Metric)
2.4 Torque Specifications for Hydraulic Couplings & Hoses
2.5 Axle Torque Specifications
2.6 Axles Maintenance Intervals
2.7 MEWP Torque Specifications
2.8 Maximum Platform Capacity
2.9 Tire Specifications
2.10 Floor Loading Pressure
2.11 Hydraulic Specifications & Gear Oil
2.12 Specifications & Features - Dimensions & Speeds
2.13 Engine Specifications
2.14 Dimension and Reach Diagrams - SJ63AJ
2.15 Axle Oscillation Diagrams
Section 3 – System Component Identification and Schematics
3.1 Electrical Symbol Chart
3.2 Hydraulic Symbol Chart
3.3 Wire Number and Color Code
3.4 Hydraulic Parts List
3.5 Electrical Component Parts List
3.6 Rotary Manifold Port Identification
3.7 Brake Manifold Port Identification
3.8 Drive and System Pump and Port Identifications
3.9 Drive Motor and Port Identifications
3.10 Jib Valve and Port Identifications
3.11 Main Manifold and Port Identifications
3.12 Main Manifold and Electrical Identifications
3.13 Main Manifold and Hydraulic Identifications
3.14 Main Electrical Harness and Fuel Level Switch Harness
3.15 ECU Engine Wiring Diagram - Deutz
3.16 Glow Plug Harnesses - Deutz D2011
3.17 Glow Plug Harnesses - Deutz TD2.9L
3.18 Engine Interface Harness - GM
3.19 Engine Interface Harness - Deutz TD2.9L
3.20 Lowering Throttle Valve Harness
3.21 Platform Harnesses
3.22 Platform Control Cables
3.23 Limit Switch Connections at the Base Control Box
3.24 Load Sensing Connections - CE & AS
3.25 All Motion Alarm Connections - CE & AS
3.26 SGE Schematics
3.27 SGE Platform Control Wiring Diagram
3.28 Hydraulic Generator and Oil Cooler Wiring - Base Control Box
3.29 Generator Wiring - Upper Control Box
3.30 Welder Wiring - ANSI/CSA
3.31 Load Circuit Wiring
3.32 Positive Air Shutoff Harness
3.33 Hydraulic Schematic
3.34 Platform Control Box Wiring - ANSI/CSA - GM & Kubota
3.35 Platform Control Box Wiring - ANSI/CSA - Deutz
3.36 Platform Conrol Box Wiring - CE - Deutz TCD2.2
3.37 Platform Control Box Wiring - CE - Deutz TD2.9L & D2011
3.38 Platform Control Box Wiring - CE - Kubota WG2503
3.39 Platform Control Box Wiring - AS - Deutz
3.40 Base Control Box Wiring - ANSI/CSA - GM
3.41 Base Control Box Wiring - ANSI/CSA - Deutz TD2.9L
3.42 Base Control Box Wiring - ANSI/CSA - Deutz TD2.9L with Positive Air Shutoff Option
3.43 Base Control Box Wiring - ANSI/CSA - Deutz D2011
3.44 Base Control Box Wiring - ANSI/CSA - Deutz D2011 with Positive Air Shut-Off
3.45 Base Control Box Wiring - Perkins 2.2TA
3.46 Base Control Box Wiring - CE - Deutz TCD2.2
3.47 Base Control Box Wiring - CE - Deutz TD2.9L
3.48 Base Control Box Wiring - CE - Deutz D2011
3.49 Base Control Box Wiring - CE - Kubota WG2503
3.50 Base Control Box Wiring - AS - Deutz D2011
3.51 Electrical Schematic - ANSI/CSA - GM
3.52 Electrical Schematic - ANSI/CSA - Kubota WG2503 (S/N 95301738 and below)
3.53 Electrical Schematic - ANSI/CSA - Kubota WG2503 (S/N 95301739 and above)
3.54 Electrical Schematic - ANSI/CSA - Deutz TD2.9L (S/N 95301738 and below)
3.55 Electrical Schematic - ANSI/CSA - Deutz TD2.9L (S/N 95301739 and above)
3.56 Electrical Schematic - ANSI/CSA - Deutz D2011 (S/N 95301738 and below)
3.57 Electrical Schematic - ANSI/CSA - Deutz D2011 (S/N 95301739 and above)
3.58 Electrical Schematic - ANSI/CSA - Perkins 2.2TA (S/N 95301738 and below)
3.59 Electrical Schematic - ANSI/CSA - Perkins 2.2TA (S/N 95301739 and above)
3.60 Electrical Schematic - CE - Deutz TCD2.2
3.61 Electrical Schematic - CE - Deutz TD2.9L Diesel (S/N 95301738 and below)
3.62 Electrical Schematic - CE - Deutz TD2.9L Diesel (S/N 95301739 and above)
3.63 Electrical Schematic - CE - Deutz D2011 (S/N 95301738 and below)
3.64 Electrical Schematic - CE - Deutz D2011 (S/N 95301739 and above)
3.65 Electrical Schematic - CE - Kubota WG2503 (S/N 9530178 and below)
3.66 Electrical Schematic - CE - Kubota WG2503 (S/N 9530179 and above)
3.67 Electrical Schematic - AS - Deutz D2011 (S/N 95301738 and below)
3.68 Electrical Schematic - AS - Deutz D2011 (S/N 95301739 and above)
3.69 Engine Electrical Schematic - GM
3.70 Engine Electrical Schematic - Kubota WG2503
3.71 Engine Electrical Schematic - CE - Kubota WG2503
3.72 Engine Electrical Schematic - Deutz TD2.9L
3.73 Engine Electrical Schematic - CE - Deutz TD2.9L Diesel
3.74 Engine Interface Wiring - Deutz TD2.9L
3.75 Engine Interface Harness - Perkins 2.2TA
3.76 Engine OEM Harness - Perkins 2.2TA
3.77 Engine Component Harness - Perkins 2.2TA
3.78 Engine Electrical Schematic - Deutz TCD2.2
3.79 Engine Interface Harness - Deutz TCD2.2
Section 4 – Troubleshooting Information
4.1 Introduction
4.2 Electrical System (ANSI/CSA)
4.3 Electrical System (CE & AS)
4.4 Hydraulic System (ANSI/CSA)
4.5 Hydraulic System (CE & AS)
4.6 Load Sensing System (CE)
Section 5 – Procedures
5.1 General
5.2 Platform
5.3 Boom
5.4 Turret
5.5 Deutz Diesel Engine
5.6 Kubota WG2503 Dual Fuel Engine
5.7 Hydraulic Tank
5.8 Manifold and Hydraulic Pumps
5.9 Axles
5.10 Grease Points
5.11 Load Sensing System
5.12 Generator
Brand: Skyjack
1.1 Read and Heed
1.7 Function Tests
3.26 SGE Schematics
4.1 Introduction
5.1 General
5.2 Platform
5.3 Boom
5.4 Turret
5.7 Hydraulic Tank
5.9 Axles
5.10 Grease Points
5.12 Generator
- Skyjack Rough Terrain Scissors SJ6826RT SJ6832RT Service Manual 157951AF 2023
- Skyjack Rough Terrain Scissors SJ6826RT SJ6832RT Service Manual 167955AGA 2023
- Skyjack Rough Terrain Scissors SJ6826RT SJ6832RT Service Manual 213560ADA 2023
- Skyjack Rough Terrain Scissors SJ6832RTE Operating Manual 159176AE-A 2022
- Skyjack Rough Terrain Scissors SJ6832RTE Operating Manual 194419AFA 2022
- Skyjack Rough Terrain Scissors SJ6832RTE Parts Manual 167571AE 2023
- Skyjack Rough Terrain Scissors SJ6832RTE Parts Manual 194373AF 2023
- Skyjack Rough Terrain Scissors SJ6832RTE Service Manual 167574AGA 2023
- Skyjack Rough Terrain Scissors SJ7127RT to SJ9250RT Operating Manual 129922AE-A 2006
- Skyjack Rough Terrain Scissors SJ7127RT to SJ9250RT Operating Manual 143861AB-A 2008
- Skyjack Rough Terrain Scissors SJ7127RT to SJ9250RT Operating Manual 143884AC-A 2010
- Skyjack Rough Terrain Scissors SJ7127RT to SJ9250RT Operating Manual 157949AB-A 2022
- Skyjack Rough Terrain Scissors SJ7127RT to SJ9250RT Operating Manual 158009AP-A 2013
- Skyjack Rough Terrain Scissors SJ7127RT to SJ9250RT Operating Manual 159148AC-A 2022
- Skyjack Rough Terrain Scissors SJ7127RT to SJ9250RT Operating Manual 159166AC-A 2014
