Skyjack Articulating Booms SJ63AJ Parts Manual 170948AL 2022
Brand: Skyjack
Type of Machine: Articulating Booms
Model: Skyjack SJ63AJ Articulating Booms
Serial Number: 95300481 to 95399999
Part Number: 170948AL
Publication Date: 2022
Number of Pages: 328 Pages
Foreword
General
Parts Ordering Information
Method of Listing
Quantities
How To Order Repair Parts
Recommended Service Parts
Section 1 – Platform
1.1 Platform with Drop Bars
1.2 Platform with Swing Gate
1.3 Railings
1.4 Platform Base - CE & AS
1.5 Swing Gate
1.6 Drop Bar
1.7 Footswitch
1.8 Platform Control Box
1.9 Boom / Turret Controller
1.10 Drive / Steer Controller
1.11 Riser Controller
1.12 Platform Terminal Strip
Section 2 – Boom
2.1 Riser
2.2 Main and Fly Boom
2.3 Fly Boom
2.4 Upper Pivot
2.5 Cable Track
2.6 Jib
2.7 Limit Switches
2.8 Rotary Actuator
Section 3 – Cylinders
3.1 Riser Lift Assembly
3.2 Riser Cylinder
3.3 Lift Cylinder
3.4 Master Cylinder
3.5 Slave Cylinder
3.6 Axle Lock Cylinder
3.7 Extension Cylinder
3.8 Jib Cylinder
Section 4 – Turret
4.1 Turret
4.2 Cowling Mounting - Engine Side
4.3 Cowling Mounting - Controls Side
4.4 Cowling - Engine Side
4.5 Cowling - Controls Side
4.6 Counterweight
4.7 Additional Counterweight
4.8 Engine Tray
4.9 Main Manifold
4.10 Brake Manifold
4.11 Fuel Tank - Diesel
4.12 Fuel Tank - Gasoline
4.13 Hydraulic Tank
4.14 High Pressure Filter
4.15 Swing Drive
4.16 Base Controls
4.17 Base Terminal Strip - ANSI/CSA & AS
4.18 Base Terminal Strip - CE
4.19 Emergency Power Unit
4.20 Battery
4.21 High Pressure Shuttle Valve
4.22 Grease Line
Section 5 – Base
5.1 Base
5.2 Axle Hardware - Front
5.3 Axle Hardware - Rear
5.4 Front Axle
5.5 Differential - Front
5.6 Central Housing - Front
5.7 Steering
5.8 Trunnion - Front
5.9 Drive Shaft
5.10 Rear Axle
5.11 Differential - Rear
5.12 Central Housing - Rear
5.13 Gear Box
5.14 Brakes
5.15 Rotary Manifold
5.16 Propane Tank
5.17 Tires
Section 6 – Engines
6.1 Engine - Deutz TD2.9L
6.2 Radiator - Deutz TD2.9L
6.3 Air Intake - Deutz TD2.9L
6.4 Engine - Deutz TCD2.2
6.5 Radiator - Deutz TCD2.2
6.6 Air Intake - Deutz TCD2.2
6.7 Engine - Deutz D2011
6.8 Engine - Perkins 2.2TA
6.9 Air Intake - Perkins 2.2TA
6.10 Radiator - Perkins 2.2TA
6.11 Engine - GM 3.0L
6.12 Engine - Kubota WG2503
6.13 Radiator & Air Intake - Kubota WG2503
6.14 Drive & System Pumps
6.15 Engine Coupling - Deutz
6.16 Engine Coupling - Kubota
6.17 Engine Coupling - Perkins
Section 7 – Electrical Harnesses
7.1 Main Electrical and Fuel Level Switch Harnesses
7.2 Lowering Throttle Valve Harness
7.3 Rotate Select Harness
7.4 Cable Harnesses
7.5 Control Cables
7.6 Outlet - 110/220 V
7.7 ECU Harness - Deutz
7.8 Glow Plug Harness - Deutz TD2.9L
7.9 Glow Plug Harness - Deutz TCD2.2
7.10 Glow Plug Harness - Deutz D2011
7.11 Engine Interface Harness - GM
7.12 Engine Interface Harness - Kubota WG2503
7.13 Engine Interface Harness - Deutz TD2.9L
7.14 Engine Interface Harness - Deutz TCD2.2
7.15 Fuse Box - Perkins 2.2TA
7.16 Differential Lock Valve Harness
Section 8 – Hose Connections
8.1 Hose Numbering System
8.2 Hydraulic Hoses - Turret
8.3 Hydraulic Hoses - Chassis
8.4 Hydraulic Hoses - Drive & System Pumps
8.5 Hydraulic Hoses - Booms
8.6 Fuel Lines - Deutz TD2.9L
8.7 Fuel Lines - Deutz D2011
8.8 Fuel Lines - Perkins 2.2TA
8.9 Fuel Lines - GM 3.0L
8.10 Fuel Lines - Kubota WG2503
Section 9 – Optional Equipment
9.1 Diesel Scrubber
9.2 All Motion Alarm
9.3 Air Hose to Platform
9.4 Hostile Environment Kit
9.5 Control Box Cover
9.6 Hydraulic Oil Cooler
9.7 Hoses - Hydraulic Oil Cooler
9.8 Oil Cooler Wiring
9.9 Generator - 3.5 kW
9.10 Generator - 12 kW
9.11 Generator - 7.5 kW
9.12 Hoses - 3.5 kW Generator
9.13 Hoses - 12 kW Generator
9.14 Hoses - 7.5 kW Generator
9.15 Generator Wiring
9.16 Welder & Mount
9.17 Cold Start
9.18 Block Heater
9.19 Arctic Package
9.20 Load Circuit
9.21 Glazier Package
9.22 External Railing
9.23 Pipe Rack
9.24 SGM
9.25 SGE
9.26 Tool Caddy
9.27 Work Lights
9.28 Half-Height Platform Mesh
9.29 Positive Air Shut-off Valve - Deutz TD2.9L
9.30 Positive Air Shutt-off Valve - Deutz D2011
9.31 Residual Current Device (RCD)
9.32 Oil Quick Drain
9.33 Elevate Telematics
9.34 Elevate Telematics Subscription
9.35 Flashing Light
Section 10 – Labels
10.1 Label Kits
10.2 Labels - Platform Control Box
10.3 Labels - Engine Side
10.4 Labels - Controls Side
10.5 Labels - Controls Compartment
10.6 Labels - Engine Compartment
10.7 Labels - Platform
10.8 Labels - Front & Back
Brand: Skyjack
Foreword
General
Method of Listing
Quantities
1.3 Railings
1.5 Swing Gate
1.6 Drop Bar
1.7 Footswitch
Section 2 – Boom
2.1 Riser
2.3 Fly Boom
2.4 Upper Pivot
2.5 Cable Track
2.6 Jib
2.7 Limit Switches
2.8 Rotary Actuator
3.2 Riser Cylinder
3.3 Lift Cylinder
3.4 Master Cylinder
3.5 Slave Cylinder
3.8 Jib Cylinder
Section 4 – Turret
4.1 Turret
4.6 Counterweight
4.8 Engine Tray
4.9 Main Manifold
4.10 Brake Manifold
4.13 Hydraulic Tank
4.15 Swing Drive
4.16 Base Controls
4.20 Battery
4.22 Grease Line
Section 5 – Base
5.1 Base
5.4 Front Axle
5.7 Steering
5.9 Drive Shaft
5.10 Rear Axle
5.13 Gear Box
5.14 Brakes
5.16 Propane Tank
5.17 Tires
Section 6 – Engines
7.4 Cable Harnesses
7.5 Control Cables
9.1 Diesel Scrubber
9.16 Welder & Mount
9.17 Cold Start
9.18 Block Heater
9.19 Arctic Package
9.20 Load Circuit
9.23 Pipe Rack
9.24 SGM
9.25 SGE
9.26 Tool Caddy
9.27 Work Lights
9.35 Flashing Light
Section 10 – Labels
10.1 Label Kits
- Skyjack Rough Terrain Scissors SJ6826RT SJ6832RT Service Manual 157951AF 2023
- Skyjack Rough Terrain Scissors SJ6826RT SJ6832RT Service Manual 167955AGA 2023
- Skyjack Rough Terrain Scissors SJ6826RT SJ6832RT Service Manual 213560ADA 2023
- Skyjack Rough Terrain Scissors SJ6832RTE Operating Manual 159176AE-A 2022
- Skyjack Rough Terrain Scissors SJ6832RTE Operating Manual 194419AFA 2022
- Skyjack Rough Terrain Scissors SJ6832RTE Parts Manual 167571AE 2023
- Skyjack Rough Terrain Scissors SJ6832RTE Parts Manual 194373AF 2023
- Skyjack Rough Terrain Scissors SJ6832RTE Service Manual 167574AGA 2023
- Skyjack Rough Terrain Scissors SJ7127RT to SJ9250RT Operating Manual 129922AE-A 2006
- Skyjack Rough Terrain Scissors SJ7127RT to SJ9250RT Operating Manual 143861AB-A 2008
- Skyjack Rough Terrain Scissors SJ7127RT to SJ9250RT Operating Manual 143884AC-A 2010
- Skyjack Rough Terrain Scissors SJ7127RT to SJ9250RT Operating Manual 157949AB-A 2022
- Skyjack Rough Terrain Scissors SJ7127RT to SJ9250RT Operating Manual 158009AP-A 2013
- Skyjack Rough Terrain Scissors SJ7127RT to SJ9250RT Operating Manual 159148AC-A 2022
- Skyjack Rough Terrain Scissors SJ7127RT to SJ9250RT Operating Manual 159166AC-A 2014
