Skyjack Articulating Booms SJ63AJ Parts Manual 167274AI 2022
Brand: Skyjack
Type of Machine: Articulating Booms
Model: Skyjack SJ63AJ Articulating Booms
Serial Number: 95300268 through 95300480
Part Number: 167274AI
Publication Date: 2022
Number of Pages: 232 Pages
1.0 Platform
1.1 Platform
1.2 Railings
1.3 Platform Base (Ansi/Csa)
1.4 Platform Base (Ce & As)
1.5 Swing Gate
1.6 Drop Bar Gate
1.7 Railing Extension (No Gate)
1.8 Platform Terminal Strip
1.9 Platform Control Console
1.10 Boom / Turret Controller Assembly
1.11 Drive / Steer Controller Assembly
1.12 Riser Boom Controller Assembly (Single Axis)
2.0 Boom
2.1 Riser Boom
2.2 Main And Fly Boom
2.3 Jib Boom
2.4 Limit Switch Assemblies
2.5 Rotary Actuator Assembly
3.0 Cylinders
3.1 Riser Lift Assembly
3.2 Riser Boom Cylinder Assembly
3.3 Main Boom Lift Cylinder Assembly
3.4 Master Cylinder Assembly
3.5 Slave Cylinder Assembly
3.6 Axle Lock Cylinder Assembly
3.7 Fly Boom Extension Cylinder Assembly
3.8 Jib Boom Cylinder Assembly
4.0 Turret
4.1 Turret Assembly
4.2 Cowling Mounting - Engine Side
4.3 Cowling Mounting - Controls Side
4.4 Cowling - Engine Side
4.5 Cowling - Controls Side
4.6 Counterweight
4.7 Additional Counterweight
4.8 Engine Tray
4.9 High Pressure Shuttle Valve
4.10 Main Manifold
4.11 Brake Manifold
4.12 Fuel Tank - Deutz Diesel Engines
4.13 Fuel Tank Assembly - Gm Dual Fuel Engine
4.14 Hydraulic Tank
4.15 High Pressure Filter
4.16 Turret Swing Drive
4.17 Base Control Box
4.18 Base Terminal Strip
4.19 Battery Assembly
4.20 Emergency Power Unit
4.21 Grease Line
5.0 Electrical Harnesses
5.1 Main Electrical Harness And Fuel Level Switch Harness
5.2 Lowering Throttle Valve Harness
5.3 Rotate Select Harness
5.4 Cable Harnesses
5.5 Control Cables
5.6 110/220v Outlet Assembly
5.7 Deutz Ecu Harness
5.8 Glow Plug Harness - Deutz Td2.9l Engine
5.9 Glow Plug Harness - Deutz D2011 Engine
5.10 Engine Interface Harness - Gm Engine
6.0 Base
6.1 Base Assembly
6.2 Axle Assembly Hardware - Front
6.3 Axle Assembly Hardware - Rear
6.4 Front Axle Assembly
6.5 Differential Assembly - Front Axle
6.6 Central Housing Assembly - Front Axle
6.7 Steering Assembly - Front Axle
6.8 Trunnion Assembly - Front Axle
6.9 Axle Drive Shaft
6.10 Rear Axle Assembly
6.11 Differential Assembly - Rear Axle
6.12 Central Housing Assembly - Rear Axle
6.13 Gear Box - Rear Axle
6.14 Brake Assembly
6.14 Brake Assembly
6.15 Rotary Manifold
6.16 Propane Tank
6.17 Tires
7.0 Engines
7.1 Engine Assembly - Deutz Td2.9l
7.2 Radiator Assembly - Deutz Td2.9l
7.3 Engine Assembly - Deutz D2011
7.4 Engine Assembly - Gm 3.0l
7.5 Drive Pump And System Pump Assembly
7.6 Engine Coupling Assembly - Deutz
8.0 Hose Connections
8.1 Standard Hose Numbering System
8.2 Hydraulic Hose Connection - Turret
8.3 Hydraulic Hose Connection - Chassis
8.4 Hydraulic Hose Connection - Drive Pump And System Pump
8.5 Hydraulic Hose Connection - Boom
8.6 Fuel Line Connection - Deutz Td2.9 Engine
8.7 Fuel Line Connection - Deutz D2011 Engine
8.8 Fuel Line Connection - Gm Engine
9.0 Optional Equipment
9.1 Diesel Scrubber
9.2 All Motion Alarm
9.3 Air Hose To Platform
9.4 Hostile Environment Kit
9.5 Platform Control Box Cover
9.6 Hydraulic Oil Cooler Assembly
9.7 Hydraulic Hose Connection - Hydraulic Oil Cooler Assembly
9.8 Hydraulic Oil Cooler Wiring
9.9 Generator Assembly - 3.5 Kw
9.10 Generator Assembly - 12 Kw
9.11 Hydraulic Hose Connections - 3.5kw Generator
9.12 Hydraulic Hose Connections - 12kw Generator
9.13 Generator Wiring
9.14 Welder Option
9.15 Glazier Package Assembly
9.16 Cold Start Assembly
9.17 Arctic Package Assembly
9.18 Cold & Arctic Package Load Circuit - Deutz Td2.9l
9.19 External Platform Railing Assembly
9.20 Pipe Rack Assembly
9.21 Flashing Amber Light Assembly
9.22 Sgm Assembly
9.23 Sge Assembly
9.24 Positive Air Shutoff Valve
9.25 Oil Quick Drain
10.0 Labels
10.1 Label Kits
10.2 Labels - Platform Control Console
10.3 Labels - Front And Back
10.4 Labels - Engine Side
10.5 Labels - Controls Side
10.6 Labels - Controls Compartment
10.7 Labels - Engine Compartment
10.8 Labels - Platform
11.0 Tables
11.1 Boom Fluids Table
11.2 Boom Grease Locations - Axle
11.3 Boom Grease Locations - Gears
Brand: Skyjack
1.0 Platform
1.1 Platform
1.2 Railings
1.5 Swing Gate
1.6 Drop Bar Gate
2.0 Boom
2.1 Riser Boom
2.3 Jib Boom
3.0 Cylinders
4.0 Turret
4.1 Turret Assembly
4.6 Counterweight
4.8 Engine Tray
4.10 Main Manifold
4.11 Brake Manifold
4.14 Hydraulic Tank
4.21 Grease Line
5.4 Cable Harnesses
5.5 Control Cables
6.0 Base
6.1 Base Assembly
6.14 Brake Assembly
6.14 Brake Assembly
6.16 Propane Tank
6.17 Tires
7.0 Engines
9.1 Diesel Scrubber
9.14 Welder Option
9.22 Sgm Assembly
9.23 Sge Assembly
10.0 Labels
10.1 Label Kits
11.0 Tables
- Skyjack Rough Terrain Scissors SJ6826RT SJ6832RT Service Manual 157951AF 2023
- Skyjack Rough Terrain Scissors SJ6826RT SJ6832RT Service Manual 167955AGA 2023
- Skyjack Rough Terrain Scissors SJ6826RT SJ6832RT Service Manual 213560ADA 2023
- Skyjack Rough Terrain Scissors SJ6832RTE Operating Manual 159176AE-A 2022
- Skyjack Rough Terrain Scissors SJ6832RTE Operating Manual 194419AFA 2022
- Skyjack Rough Terrain Scissors SJ6832RTE Parts Manual 167571AE 2023
- Skyjack Rough Terrain Scissors SJ6832RTE Parts Manual 194373AF 2023
- Skyjack Rough Terrain Scissors SJ6832RTE Service Manual 167574AGA 2023
- Skyjack Rough Terrain Scissors SJ7127RT to SJ9250RT Operating Manual 129922AE-A 2006
- Skyjack Rough Terrain Scissors SJ7127RT to SJ9250RT Operating Manual 143861AB-A 2008
- Skyjack Rough Terrain Scissors SJ7127RT to SJ9250RT Operating Manual 143884AC-A 2010
- Skyjack Rough Terrain Scissors SJ7127RT to SJ9250RT Operating Manual 157949AB-A 2022
- Skyjack Rough Terrain Scissors SJ7127RT to SJ9250RT Operating Manual 158009AP-A 2013
- Skyjack Rough Terrain Scissors SJ7127RT to SJ9250RT Operating Manual 159148AC-A 2022
- Skyjack Rough Terrain Scissors SJ7127RT to SJ9250RT Operating Manual 159166AC-A 2014
