118
6,911
Skyjack Articulating Booms SJ63AJ Parts Manual 159762AH 2022
Brand: Skyjack
Type of Machine: Articulating Booms
Model: Skyjack SJ63AJ Articulating Booms
Serial Number: 95300001 to 95300267
Part Number: 159762AH
Publication Date: 2022
Number of Pages: 222 Pages
1.0 Platform Related Parts
1.1 Platform
1.2 Railings
1.3 Platform Base (Ansi/Csa)
1.4 Platform Base (Ce & As)
1.4 Gate Assembly - Swing
1.5 Drop Bar Gate
1.7 Railing Extension (No Gate)
1.8 Platform Control Console Assembly
1.9 Boom / Turret Controller Assembly
1.10 Drive / Steer Controller Assembly
1.11 Riser Boom Controller Assembly (Single Axis)
1.12 Platform Terminal Strip
2.0 Boom Related Parts
2.1 Riser Boom Assembly
2.2 Main And Fly Boom Assembly
2.3 Jib Boom Assembly
2.4 Limit Switch Assemblies
2.5 Rotary Actuator Assembly
3.0 Cylinder Related Parts
3.1 Riser Lift Assembly
3.2 Riser Boom Cylinder Assembly
3.3 Main Boom Lift Cylinder Assembly
3.4 Master Cylinder Assembly
3.5 Slave Cylinder Assembly
3.6 Axle Lock Cylinder Assembly
3.7 Fly Boom Extension Cylinder Assembly
3.8 Jib Boom Cylinder Assembly
4.0 Turret Related Parts
4.1 Turret Assembly
4.2 Cowling Assembly Mounting - Engine Side
4.3 Cowling Assembly Mounting - Controls Side
4.4 Cowling Assembly - Engine Side
4.5 Cowling Assembly - Controls Side
4.6 Counterweight Assembly
4.7 Additional Counterweight Assembly
4.8 Engine Tray Assembly
4.9 High Pressure Shuttle Valve Assembly
4.10 Main Manifold Assembly
4.11 Brake Manifold Assembly
4.12 Fuel Tank Assembly - Deutz Engine
4.13 Fuel Tank Assembly - Dual Fuel Engine
4.14 Hydraulic Tank Assembly
4.15 High Pressure Filter Assembly
4.16 Turret Swing Drive Assembly
4.17 Base Control Console Assembly
4.18 Base Terminal Strip
4.19 Emergency Power Unit
4.20 Battery Assembly
4.21 Grease Line Hose Assembly
5.0 Electrical Harness Related Parts
5.1 Main Electrical Harness And Fuel Level Switch Harness
5.2 Lowering Throttle Valve Harness
5.3 Deutz Ecu Harness
5.4 Cable Harnesses
5.5 Control Cable Harnesses
5.6 Glow Plug Harness - Deutz Engine
5.7 110/220v Outlet Assembly
5.8 Engine Interface Harness - Dual Fuel Engine
5.9 Rotate Select Harness
6.0 Base Related Parts
6.1 Base Assembly
6.2 Axle Assembly Hardware - Front
6.3 Axle Assembly Hardware - Rear
6.4 Front Axle Assembly
6.5 Differential Assembly - Front Axle
6.6 Central Housing Assembly - Front Axle
6.7 Steering Assembly - Front Axle
6.8 Trunnion Assembly - Front Axle
6.9 Axle Drive Shaft
6.10 Rear Axle Assembly (With Gear Box)
6.11 Differential Assembly - Rear Axle (With Gear Box)
6.12 Central Housing Assembly - Rear Axle (With Gear Box)
6.13 Gear Box - Rear Axle
6.14 Brakes Assembly - Front And Rear Axle
6.15 Rotary Manifold Assembly
6.16 Propane Tank Assembly
6.17 Tire Assemblies
7.0 Engine Related Parts
7.1 Engine Assembly - Deutz Engine
7.2 Engine Assembly - Gm Engine
7.3 Drive Pump And System Pump Assembly
7.4 Engine Coupling Assembly
8.0 Hose Connection Related Parts
8.1 Standard Hose Numbering System
8.2 Hydraulic Hose Connection - Turret
8.3 Hydraulic Hose Connection - Chassis
8.4 Hydraulic Hose Connection - Drive Pump And System Pump
8.5 Hydraulic Hose Connection - Boom
8.6 Fuel Line Connection - Deutz Engine
8.7 Fuel Line Connection - Dual Fuel Engine
9.0 Optional Equipment
9.1 Diesel Scrubber
9.2 All Motion Alarm
9.3 Air Hose To Platform
9.4 Hostile Environment Kit
9.5 Platform Control Box Cover
9.6 Hydraulic Oil Cooler Assembly
9.7 Hydraulic Hose Connection - Hydraulic Oil Cooler Assembly
9.8 Hydraulic Oil Cooler Wiring
9.9 Generator Assembly (3,500w)
9.10 Generator Assembly (12,000w)
9.11 Hydraulic Hose Connection - Generator Assembly (3,500w)
9.12 Hydraulic Hose Connection - Generator Assembly (12,000w)
9.13 Generator Wiring
9.14 Welder And Mounting Assembly
9.15 Glazier Package Assembly
9.16 Cold Start Assembly
9.17 Arctic Package Assembly
9.18 Working Lights Assembly
9.19 External Platform Railing Assembly
9.20 Pipe Rack Assembly
9.21 Flashing Amber Light Assembly
9.22 Sgm Assembly
9.23 Sge Assembly
10.0 Labels
10.1 Label Kits
10.2 Labels - Platform Control Console
10.3 Labels - Front And Back
10.4 Labels - Engine Side
10.5 Labels - Controls Side
10.6 Labels - Engine Compartment
10.7 Labels - Controls Compartment
10.8 Labels - Operator Platform
11.0 Tables
11.1 Boom Fluids Table
11.2 Boom Grease Locations - Axle Grease Table
11.3 Boom Grease Locations - Gear Grease Table
