7,392
Skyjack Articulating Booms SJ60AJ+ Parts Manual 238272AEA 2023
Brand: Skyjack
Type of Machine: Articulating Booms
Model: Skyjack SJ60AJ+ Articulating Booms
Serial Number: A302100001 - A302199999
Part Number: 238272AEA
Publication Date: 2023
Number of Pages: 244 Pages
Foreword
General
Parts Ordering Information
Method of Listing
Quantities
How To Order Repair Parts
Recommended Service Parts
Section 1 – Platform
1.1 Platform with Drop Bars
1.2 Platform with Swing Gate
1.3 Railings
1.4 Platform Base
1.5 Drop Bar Gate
1.6 Swing Gate
1.7 Platform Control Box
1.8 Boom / Turret Controller
1.9 Drive / Steer Controller
1.10 Riser Controller
1.11 Platform Terminal Strip
1.12 SGE
1.13 Footswitch
1.14 Power to Platform - CE & AS
1.15 Power to Platform - ANSI/CSA
Section 2 – Boom
2.1 Riser
2.2 Main and Fly Boom
2.3 Fly
2.4 Upper Pivot
2.5 Cable Track
2.6 Jib
2.7 Jib Manifold
2.8 Limit Switches
2.9 Rotary Actuator
Section 3 – Cylinders
3.1 Riser Cylinder
3.2 Lift Cylinder
3.3 Master Cylinder
3.4 Slave Cylinder
3.5 Extension Cylinder
3.6 Jib Cylinder
3.7 Axle Lock Cylinder
Section 4 – Turret
4.1 Turret
4.2 Engine Tray
4.3 Counterweight
4.4 Cowling Mounts - Engine Side
4.5 Cowling Mounts - Controls Side
4.6 Cowling - Engine Side
4.7 Cowling - Controls Side
4.8 Main Manifold
4.9 Brake Manifold
4.10 Fuel Tank - Diesel
4.11 Fuel Tank - Gasoline
4.12 Hydraulic Tank
4.13 High Pressure Filter
4.14 Swing Drive
4.15 Base Controls
4.16 Base Terminal Strip
4.17 Emergency Power Unit
4.18 Battery
4.19 High Pressure Shuttle Valve
4.20 Grease Line
Section 5 – Base
5.1 Base
5.2 Front Axle
5.3 Central Housing - Front Axle
5.4 Differential - Front Axle
5.5 Steering - Front Axle
5.6 Trunnion - Front Axle
5.7 Rear Axle
5.8 Hub Reduction - Rear Axle
5.9 Differential - Rear Axle
5.10 Central Housing - Rear Axle
5.11 Gear Box
5.12 Brakes
5.13 Drive Motor
5.14 Drive Shaft
5.15 Rotary Manifold
5.16 Tires
Section 6 – Engines
6.1 Kubota D1305 Engine
6.2 Air Intake & Exhaust - Kubota D1305
6.3 Fuel Lines - Kubota D1305
6.4 Flywheel Housing - D1305
6.5 Flywheel Housing - WG972
6.6 Kubota WG972 Engine
6.7 Air Intake & Exhaust - Kubota WG972
6.8 Regulator/Vaporizer Mount and Hoses - Kubota WG972
6.9 Propane Tanks & Lines - Kubota WG972
6.10 Fuel Lines - Kubota WG972
6.11 Drive & System Pumps
Section 7 – Electrical Harnesses
7.1 Main Electrical and Fuel Level Switch Harnesses
7.2 Engine Harness - D1305
7.3 Engine Fuse Box - Kubota D1305
7.4 Engine Harness - Kubota WG972
7.5 ECU Power Harness - Kubota WG972
7.6 Fuel Pump Harness - Kubota WG972
7.7 Lowering Throttle Valve Harness
7.8 Rotate Select Harness
7.9 Battery Cables
7.10 CANbus & Control Cables
7.11 Differential Lock Valve Harness
Section 8 – Hydraulic Hoses
8.1 Hose Numbering System
8.2 Turret Hoses
8.3 Chassis Hoses
8.4 Drive & System Pump Hoses
8.5 Boom Hoses
Section 9 – Optional Equipment
9.1 Hostile Environment Kit
9.2 Control Box Cover
9.3 Welder & Mount
9.4 Generator - 3.5 kW
9.5 Generator - 7.5 kW
9.6 Glazier Package
9.7 External Railing
9.8 Pipe Rack
9.9 Tool Caddy
9.10 Half-Height Platform Mesh
9.11 Residual Current Device (RCD)
9.12 Oil Quick Drain
9.13 Positive Air Shut-off
9.14 White Noise Alarm
9.15 Elevate Telematics
9.16 Elevate Telematics Subscription
9.17 Flashing Light
9.18 All Motion Alarm
Section 10 – Labels
10.1 Label Kits
10.2 Labels - Front & Back
10.3 Labels - Engine Side
10.4 Labels - Controls Side
10.5 Labels - Controls Compartment
10.6 Labels - Engine Compartment
10.7 Labels - Platform
