Skyjack Articulating Booms SJ46AJ SJ51AJ Parts Manual 170947AL 2022
Brand: Skyjack
Type of Machine: Articulating Booms
Model: Skyjack SJ46AJ, SJ51AJ Articulating Booms
Serial Number: 95001105 to 95299999
Part Number: 170947AL
Publication Date: 2022
Number of Pages: 354 Pages
Foreword
General
Parts Ordering Information
Method of Listing
Quantities
How To Order Repair Parts
Recommended Service Parts
Section 1 – Platform
1.1 Platform
1.2 Railings & Base
1.3 Swing Gate
1.4 Drop Bar
1.5 Load Cell - CE & AS
1.6 Footswitch
1.7 Platform Control Box
1.8 Boom / Turret Controller
1.9 Drive / Steer Controller
1.10 Riser Controller
1.11 Platform Terminal Strip
Section 2 – Boom
2.1 Main & Fly Boom Assembly
2.2 Boom Limit Switches
2.3 Fly Boom
2.4 Riser
2.5 Cable Track
2.6 Jib
2.7 Jib Manifold
2.8 Rotary Actuator
Section 3 – Cylinders
3.1 Extension Cylinder
3.2 Lift Cylinder
3.3 Riser Cylinder Mounting
3.4 Riser Cylinder
3.5 Master Cylinder
3.6 Slave Cylinder
3.7 Jib Cylinder
3.8 Axle Lock Cylinder
Section 4 – Turret
4.1 Turret
4.2 Cowling - Engine Side
4.3 Cowling - Controls Side
4.4 Counterweight
4.5 Engine Tray
4.6 Manifold Hardware
4.7 Main Manifold
4.8 Brake Manifold (S/N 95 001 717 and above)
4.9 Brake Manifold (S/N 95 001 716 and below)
4.10 Pressure Reducing Manifold
4.11 Swing Drive
4.12 Fuel Tank - Deutz D2.9L & Perkins 2.2T
4.13 Fuel Tank - Deutz D2011
4.14 Fuel Tank - GM & Kubota
4.15 Hydraulic Tank
4.16 High Pressure Filter
4.17 Auxiliary Pump
4.18 Battery Assembly
4.19 Base Control Box - Deutz D2.9L & Perkins 2.2T
4.20 Base Control Box - Deutz D2011, GM & Kubota
4.21 Base Terminal Strip - ANSI/CSA & AS
4.22 Base Terminal Strip - CE
4.23 Grease Line
Section 5 – Electrical Harnesses
5.1 Main Electrical and Fuel Level Switch Harnesses
5.2 Battery Cables
5.3 Control Cables
5.4 Jib/Rotate Valve Harness
5.5 AC Outlet - 110/220V
5.6 Glow Plug Harness - Deutz D2.9L
5.7 Glow Plug Harness - Deutz D2011 Engine
5.8 ECU Harnesses - Deutz D2011 Engine
5.9 Engine Interface Harness - Deutz D2.9L
5.10 Engine Interface Harness - Kubota WG2503
5.11 Engine Interface Harness - Perkins 2.2T
5.12 Fuse Box - Perkins 2.2T
5.13 Engine Interface Harness - GM
Section 6 – Base
6.1 Base
6.2 Rotary Manifold
6.3 Axle Hardware
6.4 Rear Axle
6.5 Differential - Rear Axle
6.6 Brake - Rear Axle
6.7 Central Housing - Rear Axle
6.8 Gear Box - Rear Axle
6.9 Drive Motor
6.10 Front Axle
6.11 Differential - Front Axle
6.12 Central Housing - Front Axle
6.13 Steering Assembly
6.14 Trunnion - Front Axle
6.15 Drive Shaft
6.16 Propane Tank
6.17 Tires
Section 7 – Engines
7.1 Deutz D2.9L Engine
7.2 Radiator - Deutz D2.9L
7.3 Air Intake - Deutz D2.9L
7.4 Deutz D2011 Engine
7.5 Perkins 2.2T Engine
7.6 Radiator - Perkins 2.2T
7.7 Air Intake - Perkins 2.2T
7.8 GM Engine
7.9 Kubota WG2503 Engine
7.10 Radiator & Air Intake - Kubota WG2503
7.11 Drive and System Pump
7.12 Drive and System Pump with 7.5 kW Generator
7.13 Drive and System Pump with 12 kW Generator
7.14 Engine Coupling - Deutz
7.15 Engine Coupling - Kubota
7.16 Engine Coupling - Perkins
Section 8 – Hose Connections
8.1 Standard Hose Numbering System
8.2 Hydraulic Hoses - Boom
8.3 Hoses - Manifolds & Swing Drive (S/N 95 002 084 & below)
8.4 Hydraulic Hoses - Pumps (S/N 95 002 084 & below)
8.5 Hydraulic Hoses - Turret (S/N 95 002 085 & above)
8.6 Hydraulic Hoses - Base (S/N 95 002 084 & below)
8.7 Hydraulic Hoses - Base (S/N 95 002 085 & above)
8.8 Fuel Lines - Deutz D2.9L
8.9 Fuel Lines - Deutz D2011
8.10 Fuel Lines - Perkins 2.2T
8.11 Fuel Lines - GM
8.12 Fuel Lines - Kubota WG2503
8.13 Propane Lines - Kubota WG2503
Section 9 – Optional Equipment
9.1 All Motion Alarm
9.2 Air Hose To Platform
9.3 Flashing Light
9.4 Oil Quick Drain
9.5 Diesel Scrubber
9.6 Block Heater
9.7 Cold Start
9.8 Arctic Package
9.9 Load Circuit Manifold - Deutz D2.9L
9.10 Load Circuit Hose Kit - Deutz D2.9L
9.11 Oil Cooler (No Generator) - SJ46AJ
9.12 Oil Cooler (No Generator) - SJ51AJ
9.13 Hydraulic Hoses - Oil Cooler (No Generator)
9.14 Oil Cooler Wiring
9.15 Generator & Oil Cooler - 3.5kW - SJ46AJ
9.16 Generator & Oil Cooler - 3.5kW - SJ51AJ
9.17 Generator - 3.5 kW
9.18 Hydraulic Hoses - 3.5 kW Generator & Oil Cooler
9.19 Generator Wiring - 3.5kW
9.20 Generator & Oil Cooler Assembly - SJ46AJ - 7.5 kW
9.21 Generator & Oil Cooler - SJ46AJ - 7.5 kW & 12kW
9.22 Generator & Oil Cooler Assembly - SJ51AJ - 7.5 kW
9.23 Generator & Oil Cooler - SJ51AJ - 7.5 kW
9.24 Generator - 7.5 kW
9.25 Generator Manifold - 7.5 kW & 12 kW
9.26 Generator & Oil Cooler Assembly - 12 kW
9.27 Generator - 12 kW
9.28 Circuit Breaker - 12kW Generator
9.29 Hydraulic Hoses - 7.5 kW & 12 kW Generator & Oil Cooler
9.30 Generator Wiring - 7.5 kW and 12 kW
9.31 Welder & Mount
9.32 Glazier Tray
9.33 SGM
9.34 SGE
9.35 Control Box Cover
9.36 Positive Air Shutoff - Deutz D2.9L
9.37 Positive Air Shutoff - Deutz D2011
9.38 Pipe Rack
9.39 Work Lights
9.40 Tool Caddy
9.41 Half-Height Platform Mesh
9.42 Elevate Telematics
9.43 Elevate Telematics Subscription
9.44 Residual Current Device (RCD)
9.45 EcoStart
9.46 External Railing
Section 10 – Labels
10.1 Label Kits
10.2 Labels - Platform Control Box
10.3 Labels - Front and Back
10.4 Labels - Engine Side
10.5 Labels - Controls Side
10.6 Labels - Controls Compartment
10.7 Labels - Engine Compartment
10.8 Labels - Platform
10.9 Labels - Fuel
Brand: Skyjack
Foreword
General
Method of Listing
Quantities
1.1 Platform
1.2 Railings & Base
1.3 Swing Gate
1.4 Drop Bar
1.6 Footswitch
Section 2 – Boom
2.3 Fly Boom
2.4 Riser
2.5 Cable Track
2.6 Jib
2.7 Jib Manifold
2.8 Rotary Actuator
3.2 Lift Cylinder
3.4 Riser Cylinder
3.5 Master Cylinder
3.6 Slave Cylinder
3.7 Jib Cylinder
Section 4 – Turret
4.1 Turret
4.4 Counterweight
4.5 Engine Tray
4.7 Main Manifold
4.11 Swing Drive
4.15 Hydraulic Tank
4.17 Auxiliary Pump
4.23 Grease Line
5.2 Battery Cables
5.3 Control Cables
Section 6 – Base
6.1 Base
6.2 Rotary Manifold
6.3 Axle Hardware
6.4 Rear Axle
6.9 Drive Motor
6.10 Front Axle
6.15 Drive Shaft
6.16 Propane Tank
6.17 Tires
Section 7 – Engines
7.8 GM Engine
9.3 Flashing Light
9.4 Oil Quick Drain
9.5 Diesel Scrubber
9.6 Block Heater
9.7 Cold Start
9.8 Arctic Package
9.31 Welder & Mount
9.32 Glazier Tray
9.33 SGM
9.34 SGE
9.38 Pipe Rack
9.39 Work Lights
9.40 Tool Caddy
9.45 EcoStart
Section 10 – Labels
10.1 Label Kits
10.9 Labels - Fuel
- Skyjack Rough Terrain Scissors SJ6826RT SJ6832RT Service Manual 157951AF 2023
- Skyjack Rough Terrain Scissors SJ6826RT SJ6832RT Service Manual 167955AGA 2023
- Skyjack Rough Terrain Scissors SJ6826RT SJ6832RT Service Manual 213560ADA 2023
- Skyjack Rough Terrain Scissors SJ6832RTE Operating Manual 159176AE-A 2022
- Skyjack Rough Terrain Scissors SJ6832RTE Operating Manual 194419AFA 2022
- Skyjack Rough Terrain Scissors SJ6832RTE Parts Manual 167571AE 2023
- Skyjack Rough Terrain Scissors SJ6832RTE Parts Manual 194373AF 2023
- Skyjack Rough Terrain Scissors SJ6832RTE Service Manual 167574AGA 2023
- Skyjack Rough Terrain Scissors SJ7127RT to SJ9250RT Operating Manual 129922AE-A 2006
- Skyjack Rough Terrain Scissors SJ7127RT to SJ9250RT Operating Manual 143861AB-A 2008
- Skyjack Rough Terrain Scissors SJ7127RT to SJ9250RT Operating Manual 143884AC-A 2010
- Skyjack Rough Terrain Scissors SJ7127RT to SJ9250RT Operating Manual 157949AB-A 2022
- Skyjack Rough Terrain Scissors SJ7127RT to SJ9250RT Operating Manual 158009AP-A 2013
- Skyjack Rough Terrain Scissors SJ7127RT to SJ9250RT Operating Manual 159148AC-A 2022
- Skyjack Rough Terrain Scissors SJ7127RT to SJ9250RT Operating Manual 159166AC-A 2014
