Skyjack Articulating Booms SJ46AJ SJ51AJ Parts Manual 168893AH 2022
Brand: Skyjack
Type of Machine: Articulating Booms
Model: Skyjack SJ46AJ, SJ51AJ Articulating Booms
Serial Number: 95000853 - 95001104
Part Number: 168893AH
Publication Date: 2022
Number of Pages: 252 Pages
1.0 Platform
1.1 Platform
1.2 Railings & Base
1.3 Swing Gate
1.4 Drop Gate
1.5 Load Cell (Ce & As)
1.6 Footswitch
1.7 Platform Control Console
1.8 Boom / Turret Controller Assembly (Dual Axis)
1.9 Drive / Steer Controller Assembly (Single Axis)
1.10 Riser Boom Controller Assembly (Single Axis)
1.11 Platform Terminal Strip
2.0 Boom
2.1 Main & Fly Boom Assembly
2.2 Main & Riser Boom Limit Switches
2.3 Fly Boom Assembly
2.4 Riser Boom Assembly
2.5 E-Chain Assembly
2.6 Jib Boom Assembly
2.7 Jib Manifold
2.8 Rotary Actuator
3.0 Cylinders
3.1 Extension Cylinder
3.2 Main Boom Lift Cylinder
3.3 Riser Cylinder Mounting
3.4 Riser Cylinder
3.5 Master Cylinder
3.6 Slave Cylinder
3.7 Jib Cylinder
3.8 Axle Lock Cylinder
4.0 Turret
4.1 Turret Assembly
4.2 Cowling Assembly - Engine Side
4.3 Cowling Assembly - Controls Side
4.4 Counterweight Assembly
4.5 Engine Tray Assembly
4.6 Manifold Assembly With Hardware
4.7 Main Manifold
4.8 Brake Manifold
4.9 Pressure Reducing Manifold
4.10 Rotary Manifold Assembly
4.11 Turret Swing Drive Assembly
4.12 Fuel Tank Assembly (Deutz D2.9l Engine)
4.13 Fuel Tank Assembly (Deutz D2011 Engine)
4.14 Fuel Tank Assembly (Gm Dual Fuel Engine)
4.15 Hydraulic Tank Assembly
4.16 High Pressure Filter Assembly
4.17 Auxiliary Pump
4.18 Battery Assembly
4.19 Base Control Console Assembly - Deutz D2.9l
4.20 Base Control Console Assembly - Deutz D2011 & Gm
4.21 Base Terminal Strip - Deutz D2.9l
4.22 Base Terminal Strip - Gm & Deutz D2011
4.23 Grease Line Hose Assembly
5.0 Electrical Harnesses
5.1 Main Electrical Harness And Fuel Level Switch Harness
5.2 Battery Cables
5.3 Control Cable Harnesses
5.4 Jib/Rotate Valve Harness
5.5 110/220v Outlet Assembly
5.6 Glow Plug Harness (Deutz D2.9l Diesel Engine)
5.7 Glow Plug Harness (Deutz D2011 Engine)
5.8 Ecu Harnesses (Deutz D2011 Engine)
5.9 Engine Interface Harness (Deutz D2.9l)
5.10 Engine Interface Harness (Gm Dual Fuel Engine)
6.0 Base
6.1 Base Assembly
6.2 Axle Hardware
6.3 Rear Axle Assembly
6.4 Differential Assembly - Rear Axle
6.5 Brake Assembly - Rear Axle
6.6 Central Housing Assembly - Rear Axle
6.7 Gear Box - Rear Axle
6.8 Hydraulic Drive Motor
6.9 Front Axle Assembly
6.10 Differential Assembly - Front Axle
6.11 Central Housing Assembly - Front Axle
6.12 Steering Assembly
6.13 Trunnion Assembly - Front Axle
6.14 Drive Shaft
6.15 Propane Tank Assembly
6.16 Tires
7.0 Engines
7.1 Deutz D2.9l Diesel Engine
7.2 Deutz D2011 Diesel Engine
7.3 Engine Coupling - Deutz
7.4 Gm Dual Fuel Engine
7.5 Drive And System Pump Assembly
7.6 Drive And System Pump Assembly (With Welder Option)
8.0 Hose Connections
8.1 Standard Hose Numbering System
8.2 Hydraulic Hose Connection - Boom
8.3 Hydraulic Hose Connection - Manifolds & Swing Drive
8.4 Hydraulic Hose Connection - Pumps
8.5 Hydraulic Hose Connection - Base And Axles
8.6 Fuel Line Hose Connection - Deutz D2.9l
8.7 Fuel Line Hose Connection - Deutz D2011
8.8 Fuel Line Hose Connection - Gm Dual Fuel Engine
9.0 Optional Equipment
9.1 All Motion Alarm Assembly
9.2 Air Hose To Platform Option
9.3 Flashing Amber Light Option
9.4 External Platform Railing Assembly
9.5 Diesel Scrubber Option
9.6 Cold Start Option
9.7 Arctic Package Option
9.8 Cold & Arctic Package Load Circuit - Deutz D2.9l
9.9 Oil Cooler Assembly (No Generator) - 46aj
9.10 Oil Cooler Assembly (No Generator) - 51aj
9.11 Hydraulic Hose Connections - Oil Cooler (No Generator)
9.12 Oil Cooler Wiring
9.13 Generator & Oil Cooler Assembly - 3.5kw (Sj46aj)
9.14 Generator & Oil Cooler Assembly - 3.5 Kw (Sj1aj)
9.15 Hydraulic Hose Connection - 3.5 Kw Generator & Oil Cooler
9.16 Generator Wiring - 3.5 Kw
9.17 Generator & Oil Cooler Assembly - 12 Kw
9.18 Generator & Oil Cooler - 12 Kw
9.19 Circuit Breaker Assembly - 12 Kw Generator
9.20 Generator Wiring - 12 Kw
9.21 Hydraulic Hose Connections - 12 Kw Generator & Oil Cooler
9.22 Welder Option
9.23 Glazier Tray
9.24 Sgm Assembly
9.25 Sge Assembly
9.26 Platform Control Box Cover
9.27 Positive Air Shutoff Valve
9.28 Pipe Rack
9.29 Oil Quick Drain
10.0 Labels
10.1 Label Kits
10.2 Labels - Platform Control Box
10.3 Labels - Front And Back
10.4 Labels - Engine Side
10.5 Labels - Controls Side
10.6 Labels - Controls Compartment
10.7 Labels - Engine Compartment
10.8 Labels - Operator Platform
10.9 Labels - Fuel
11.0 Tables
11.1 Boom Fluids Table
11.2 Boom Grease Locations - Axle Grease Table
11.3 Boom Grease Locations - Gear Grease Table
Brand: Skyjack
1.0 Platform
1.1 Platform
1.2 Railings & Base
1.3 Swing Gate
1.4 Drop Gate
1.6 Footswitch
2.0 Boom
2.7 Jib Manifold
2.8 Rotary Actuator
3.0 Cylinders
3.4 Riser Cylinder
3.5 Master Cylinder
3.6 Slave Cylinder
3.7 Jib Cylinder
4.0 Turret
4.1 Turret Assembly
4.7 Main Manifold
4.8 Brake Manifold
4.17 Auxiliary Pump
5.2 Battery Cables
6.0 Base
6.1 Base Assembly
6.2 Axle Hardware
6.14 Drive Shaft
6.16 Tires
7.0 Engines
9.22 Welder Option
9.23 Glazier Tray
9.24 Sgm Assembly
9.25 Sge Assembly
9.28 Pipe Rack
10.0 Labels
10.1 Label Kits
10.9 Labels - Fuel
11.0 Tables
- Skyjack Rough Terrain Scissors SJ6826RT SJ6832RT Service Manual 157951AF 2023
- Skyjack Rough Terrain Scissors SJ6826RT SJ6832RT Service Manual 167955AGA 2023
- Skyjack Rough Terrain Scissors SJ6826RT SJ6832RT Service Manual 213560ADA 2023
- Skyjack Rough Terrain Scissors SJ6832RTE Operating Manual 159176AE-A 2022
- Skyjack Rough Terrain Scissors SJ6832RTE Operating Manual 194419AFA 2022
- Skyjack Rough Terrain Scissors SJ6832RTE Parts Manual 167571AE 2023
- Skyjack Rough Terrain Scissors SJ6832RTE Parts Manual 194373AF 2023
- Skyjack Rough Terrain Scissors SJ6832RTE Service Manual 167574AGA 2023
- Skyjack Rough Terrain Scissors SJ7127RT to SJ9250RT Operating Manual 129922AE-A 2006
- Skyjack Rough Terrain Scissors SJ7127RT to SJ9250RT Operating Manual 143861AB-A 2008
- Skyjack Rough Terrain Scissors SJ7127RT to SJ9250RT Operating Manual 143884AC-A 2010
- Skyjack Rough Terrain Scissors SJ7127RT to SJ9250RT Operating Manual 157949AB-A 2022
- Skyjack Rough Terrain Scissors SJ7127RT to SJ9250RT Operating Manual 158009AP-A 2013
- Skyjack Rough Terrain Scissors SJ7127RT to SJ9250RT Operating Manual 159148AC-A 2022
- Skyjack Rough Terrain Scissors SJ7127RT to SJ9250RT Operating Manual 159166AC-A 2014
