Skyjack Articulating Booms SJ46AJ SJ51AJ Parts Manual 166873AI 2022
Brand: Skyjack
Type of Machine: Articulating Booms
Model: Skyjack SJ46AJ, SJ51AJ Articulating Booms
Serial Number: 95000657 - 95000852
Part Number: 166873AI
Publication Date: 2022
Number of Pages: 246 Pages
1.0 Platform Related Parts
1.1 Platform
1.2 Railings
1.3 Swing Gate
1.4 Drop Gate
1.5 Platform Base Assembly
1.6 Load Cell (Ce & As)
1.7 Footswitch
1.8 Platform Control Console
1.9 Boom / Turret Controller Assembly (Dual Axis)
1.10 Drive / Steer Controller Assembly (Single Axis)
1.11 Riser Boom Controller Assembly (Single Axis)
1.12 Platform Terminal Strip
2.0 Boom Related Parts
2.1 Main Boom Assembly
2.2 Main & Riser Boom Limit Switches
2.3 Fly Boom Assembly
2.4 Riser Boom Assembly
2.5 Power Track Carrier Assembly
2.6 Jib Boom Assembly
2.7 Jib Lift / Platform Rotate Valve Assemblies
2.8 Rotary Actuator
3.0 Cylinder Related Parts
3.1 Fly Boom Extension Cylinder Assembly
3.2 Main Boom Lift Cylinder Assembly
3.3 Riser Lift Assembly
3.4 Riser Cylinder Assembly
3.5 Master Cylinder Assembly
3.6 Slave Cylinder Assembly
3.7 Jib Cylinder Assembly
3.8 Axle Lock Cylinder Assembly
4.0 Turret Related Parts
4.1 Turret Assembly
4.2 Cowling Assembly - Engine Side
4.3 Cowling Assembly - Controls Side
4.4 Counterweight Assembly
4.5 Engine Tray Assembly
4.6 Main Manifold Assembly
4.7 Brake Manifold Assembly
4.8 Rotary Manifold Assembly
4.9 Turret Swing Drive Assembly
4.10 Fuel Tank Assembly (Deutz D2.9l Engine)
4.11 Fuel Tank Assembly (Deutz D2011 Engine)
4.12 Fuel Tank Assembly (Gm Dual Fuel Engine)
4.13 Hydraulic Tank Assembly
4.14 High Pressure Filter Assembly
4.15 Grease Line Hose Assembly
4.16 Emergency Power Unit
4.17 Battery Assembly (Deutz D2.9l)
4.18 Battery Assembly (Gm & Deutz D2011)
4.19 Base Control Console Assembly (Deutz D2.9l)
4.20 Base Control Console Assembly (Deutz D2011)
4.21 Base Control Console Assembly (Gm)
4.22 Base Terminal Strip - Deutz D2.9l
4.23 Base Terminal Strip - Gm & Deutz D2011
5.0 Electrical Harness Related Parts
5.1 Main Electrical Harness And Fuel Level Switch Harness
5.2 Cable Harnesses
5.3 Control Cable Harnesses
5.4 Valve Harnesses
5.5 110/220v Outlet Assembly
5.6 Glow Plug Harness (Deutz D2.9l Diesel Engine)
5.7 Ecu Harnesses (Deutz D2011 Engine)
5.8 Engine Interface Harness (Gm Dual Fuel Engine)
5.9 Engine Interface Harness (Deutz D2.9l)
6.0 Base Related Parts
6.1 Base Assembly
6.2 Axle Assembly Hardware
6.3 Rear Axle Assembly With Gear Box
6.4 Differential Assembly - Rear Axle Assembly With Gear Box
6.5 Brakes Assembly - Rear Axle
6.6 Central Housing Assembly - Rear Axle Assembly With Gear Box
6.7 Gear Box - Rear Axle
6.8 Hydraulic Drive Motor
6.9 Front Axle Assembly
6.10 Differential Assembly - Front Axle
6.11 Central Housing Assembly - Front Axle
6.12 Steering Assembly
6.13 Trunnion Assembly - Front Axle
6.14 Axle Drive Shaft (4wd)
6.15 Propane Tank Assembly
6.16 Tires
7.0 Engine Related Parts
7.1 Engine Assembly (Deutz D2.9l)
7.2 Engine Assembly (Deutz D2011)
7.3 Engine Coupling Assembly
7.4 Engine Assembly (Gm Dual Fuel)
7.5 Drive And System Pump Assembly
7.6 Drive And System Pump Assembly (With Welder Option)
8.0 Hose Connection Related Parts
8.1 Standard Hose Numbering System
8.2 Hydraulic Hose Connection - Boom Cylinders
8.3 Hydraulic Hose Connection - Control Compartment
8.4 Hydraulic Hose Connection - Engine Compartment
8.5 Fuel Line Hose Connection - Deutz D2.9l
8.6 Fuel Line Hose Connection - Deutz D2011
8.7 Fuel Line Hose Connection - Gm Dual Fuel Engine
8.8 Hydraulic Hose Connection - Base And Axles
9.0 Optional Equipment
9.1 All Motion Alarm Assembly
9.2 Air Hose To Platform Option
9.3 Flashing Amber Light Option
9.4 External Platform Railing Assembly
9.5 Cold Start Option - Ansi/Csa
9.6 Arctic Package Option - Deutz D2.9l Engine (Ansi/Csa)
9.7 Arctic Package Option - Deutz D2011 Engine (Ansi/Csa)
9.8 Arctic Package Option - Gm Dual Fuel Engine (Ansi/Csa)
9.9 Cold & Arctic Package Load Circuit - Deutz D2.9l
9.10 Welder Option (Sj 46aj)
9.11 Generator With Oil Cooler Option -12kw (Sj 46aj With Welder Option)
9.12 Circuit Breaker Assembly - 12kw Generator
9.13 12kw Generator Wiring
9.14 Hydraulic Hose Connections - 12kw Generator & Oil Cooler (Sj 46aj)
9.15 Generator With Oil Cooler Option - 3500w (Sj46aj)
9.16 Diesel Scrubber Option
9.17 Hydraulic Hose Connection - Generator (Sj 46aj)
9.18 Generator With Oil Cooler Option - 3500w (Sj51aj)
9.19 Hydraulic Hose Connection - 3500w Generator (Sj 51aj)
9.20 Generator Wiring (3500w)
9.21 Oil Cooler Wiring
9.22 Glazier Package Assembly
9.23 Sgm Assembly
9.24 Sge Assembly
10.0 Labels
10.1 Label Kits
10.2 Labels - Platform Control Console
10.3 Labels - Front And Back
10.4 Labels - Engine Side
10.5 Labels - Controls Side
10.6 Labels - Controls Compartment
10.7 Labels - Engine Compartment
10.8 Labels - Operator Platform
10.9 Labels - Fuel
11.0 Tables
11.1 Boom Fluids Table
11.2 Boom Grease Locations - Axle Grease Table
11.3 Boom Grease Locations - Gear Grease Table
Brand: Skyjack
1.1 Platform
1.2 Railings
1.3 Swing Gate
1.4 Drop Gate
1.7 Footswitch
2.8 Rotary Actuator
4.1 Turret Assembly
5.2 Cable Harnesses
5.4 Valve Harnesses
6.1 Base Assembly
6.16 Tires
9.23 Sgm Assembly
9.24 Sge Assembly
10.0 Labels
10.1 Label Kits
10.9 Labels - Fuel
11.0 Tables
- Skyjack Rough Terrain Scissors SJ6826RT SJ6832RT Service Manual 157951AF 2023
- Skyjack Rough Terrain Scissors SJ6826RT SJ6832RT Service Manual 167955AGA 2023
- Skyjack Rough Terrain Scissors SJ6826RT SJ6832RT Service Manual 213560ADA 2023
- Skyjack Rough Terrain Scissors SJ6832RTE Operating Manual 159176AE-A 2022
- Skyjack Rough Terrain Scissors SJ6832RTE Operating Manual 194419AFA 2022
- Skyjack Rough Terrain Scissors SJ6832RTE Parts Manual 167571AE 2023
- Skyjack Rough Terrain Scissors SJ6832RTE Parts Manual 194373AF 2023
- Skyjack Rough Terrain Scissors SJ6832RTE Service Manual 167574AGA 2023
- Skyjack Rough Terrain Scissors SJ7127RT to SJ9250RT Operating Manual 129922AE-A 2006
- Skyjack Rough Terrain Scissors SJ7127RT to SJ9250RT Operating Manual 143861AB-A 2008
- Skyjack Rough Terrain Scissors SJ7127RT to SJ9250RT Operating Manual 143884AC-A 2010
- Skyjack Rough Terrain Scissors SJ7127RT to SJ9250RT Operating Manual 157949AB-A 2022
- Skyjack Rough Terrain Scissors SJ7127RT to SJ9250RT Operating Manual 158009AP-A 2013
- Skyjack Rough Terrain Scissors SJ7127RT to SJ9250RT Operating Manual 159148AC-A 2022
- Skyjack Rough Terrain Scissors SJ7127RT to SJ9250RT Operating Manual 159166AC-A 2014
