118
6,911
Skyjack Articulating Booms SJ46AJ+ Operating Manual 213208ADA 2022
Brand: Skyjack
Type of Machine: Articulating Booms
Type of Manual: Operating Manual
Model: Skyjack SJ46AJ+ Articulating Booms
Serial Number: A301000001 - A301099999
Part Number: 213208ADA
Publication Date: 2022
Number of Pages: 122 Pages
Section 1 – About this Mobile Elevating Work Platform (MEWP)
1.1 Read and heed
1.2 Primary assemblies
1.3 Serial number nameplate
1.4 Maintenance responsibility
Section 2 – General Safety Precautions
2.1 Electrocution hazards
2.2 Safety instructions
2.3 Fall-protection
2.4 Worksite inspection
Section 3 – Familiarization
3.1 Overview of the MEWP
3.2 Manual storage box
3.3 Control functions
3.4 Features and devices
3.5 Optional equipment and attachments
Section 4 – Inspections Before Operation
4.1 Operator’s responsibility
4.2 Visual and daily maintenance inspections
4.3 Function tests
4.4 Operator’s checklist
Section 5 – Operation
5.1 Energize the base control console
5.2 Rotate the platform with the base control console
5.3 Rotate the turret with the base control console
5.4 Move the jib up and down with the base control console
5.5 Raise or lower the riser with the base control console
5.6 Raise or lower the main boom with the base control console
5.7 Extend or retract the boom with the base control console
5.8 Make the platform level with the base control console
5.9 Operate with the emergency power switch at the base control console
5.10 Energize the platform control console
5.11 Drive forward or rearward
5.12 Steer
5.13 Move the jib up and down with the platform control console
5.14 Move the riser up and down with the platform control console
5.15 Extend or retract the boom with the platform control console
5.16 Make the platform level with the platform control console
5.17 Rotate the platform with the platform control console
5.18 Raise or lower the main boom with the platform control console
5.19 Operate the horn
5.20 Rotate the turret with the platform control console
5.21 Operate with the emergency power switch at the platform control console
5.22 Engage or disengage the differential lock switch
5.23 MEWP shutdown
5.24 Generator (optional equipment)
5.25 Glazier tray (optional equipment)
5.26 Pipe rack (optional equipment)
5.27 Cold or arctic weather package (optional equipment)
Section 6 – Additional Procedures
6.1 Use the emergency-lowering function
6.2 Chassis tilt recovery
6.3 Release the brakes manually
6.4 Winch and tow the MEWP
6.5 Refuel
6.6 Move the MEWP for transport
Section 7 – Technical Diagrams and Specifications
7.1 Technical diagrams
7.2 Standard and optional equipment
7.3 Owner’s annual inspection record
7.4 Specifications
7.5 Environment
7.6 Tire/wheel specifications
7.7 Maximum platform capacities (evenly distributed)
7.8 Floor loading pressure
Section 8 – Labels
8.1 Engine side
8.2 Engine compartment
8.3 Front and rear sides
8.4 Controls side
8.5 Control compartment
8.6 Platform
8.7 Platform control console
Section 9 – Unique Skyjack Features
