118
6,911
Skyjack Articulating Booms SJ46AJ Operating Manual 143896AD-A 2018
Brand: Skyjack
Type of Machine: Articulating Booms
Type of Manual: Operating Manual
Model: Skyjack SJ46AJ Articulating Booms
Serial Number: 95000001 - 95000335, 95000337 - 95000340, 95000342
Part Number: 143896AD-A
Publication Date: 2018
Number of Pages: 86 Pages
Section 1 - About Your Aerial Platform
Read and Heed
Aerial Platform Definition
Purpose of Equipment
Use of Equipment
Manual
Operator
Service Policy and Warranty
Optional Accessories
Scope of this Manual
Safety Rules
Operator Safety Reminders
Electrocution Hazard
Safety Precautions
Section 2 - Operation
2.1 General
2.1-1 Operator Qualifications
2.1-2 Operator’s Responsibility for Maintenance
2.1-3 Maintenance and Inspection Schedule
2.1-4 Owner’s Inspections
2.2 Major Components
2.3 Major Assemblies
2.3-1 Base
2.3-2 Turret
2.3-3 Boom Assembly
2.3-4 Platform
2.4 Serial Number Nameplate
2.5 Component Identification
2.5-1 Main Power Disconnect Switch
2.5-2 Tilt Sensor
2.5-3 Drive Bypass Valve
2.5-4 Brake System
2.5-5 Differential Lock Switch
2.5-6 All Motion Alarm
2.5-7 AC Outlet on Platform (If Equipped)
2.5-8 Turret Transportation Lock
2.5-9 Footswitch
2.5-10 Manual Storage Box
2.5-11 Base Control Console
2.5-12 Platform Control Console
2.6 Special Options
2.6-1 Cold Weather Start (If Equipped)
2.6-2 Work Light (If Equipped)
2.6-3 Flashing Amber Light (If Equipped)
2.6-4 Tire Sealant Light (If Equipped)
2.6-5 Hydraulic Generator (If Equipped)
2.7 Operator’s Responsibility
2.8 Visual & Daily Maintenance Inspections
2.9 Function Tests
2.10 Start Operation
2.10-1 To Activate Base Control Console
2.10-2 To Rotate Platform Using Base Control Console
2.10-3 To Rotate Turret Using Base Control Console
2.10-4 To Move Jib Up and Down Using Base Control Console
2.10-5 To Move Riser Up and Down Using Base Control Console
2.10-6 To Raise or Lower Main Boom Using Base Control Console
2.10-7 To Extend or Retract Fly Boom Using Base Control Console
2.10-8 To Level Platform Manually Using Base Control Console
2.10-9 To Operate Using Emergency Power Switch at Base Control Console
2.10-10 To Activate Platform Control Console
2.10-11 To Drive Forward or Reverse
2.10-12 To Steer
2.10-13 To Move Jib Up and Down Using Platform Control Console
2.10-14 To Move Riser Up and Down Using Platform Control Console
2.10-15 To Extend or Retract Fly Boom Using Platform Control Console
2.10-16 To Rotate Platform Using Platform Control Console
2.10-17 To Level Platform Manually Using Platform Control Console
2.10-18 To Raise or Lower Main Boom Using Platform Control Console
2.10-19 To Sound Horn
2.10-20 To Rotate Turret Using Platform Control Console
2.10-21 To Operate Using Emergency Power Switch at Platform Control Console
2.10-22 Shutdown Procedure
2.11 Refueling Procedures
2.11-1 Regular Fuel
2.11-2 Propane
2.12 Loading/Unloading
2.12-1 Loading and Tie-down
2.12-2 Locking the Turret
2.12-3 Lifting
2.13 Winching and Towing Procedure
2.13-1 To Release Brakes Manually
2.14 Emergency Lowering Procedures
2.15 Chassis Tilt
2.16 Diagram
2.17 Tables
2.18 Labels
List of Tables
2.1 Standard and Optional Features
2.2 Specifications and Features
2.3 Owner’s Annual Inspection Record
2.4 Tire/Wheel Specifications
2.5 Maximum Platform Capacities
2.6 Floor Loading Pressure
2.7 Maintenance and Inspection Schedule
2.8 Operator’s Checklist
