118
7,392
Skyjack Articulating Booms SJ45AJ+ Parts Manual 238271AEA 2023
Brand: Skyjack
Type of Machine: Articulating Booms
Model: Skyjack SJ45AJ+ Articulating Booms
Serial Number: A301100001 - A301199999
Part Number: 238271AEA
Publication Date: 2023
Number of Pages: 234 Pages
Foreword
General
Parts Ordering Information
Method of Listing
Quantities
How To Order Repair Parts
Recommended Service Parts
Section 1 – Platform
1.1 Platform with Drop Bars
1.2 Platform with Swing Gate
1.3 Railings
1.4 Platform Base
1.5 Drop Bar Gate
1.6 Swing Gate
1.7 Platform Control Box
1.8 Boom / Turret Controller
1.9 Drive / Steer Controller
1.10 Riser Controller
1.11 Platform Terminal Strip
1.12 SGE
1.13 Footswitch
1.14 Power to Platform - CE & AS
1.15 Power to Platform - ANSI/CSA
Section 2 – Boom
2.1 Main & Fly Boom Assembly
2.2 Boom Limit Switches
2.3 Fly Boom
2.4 Riser
2.5 Cable Track
2.6 Jib
2.7 Jib Manifold
2.8 Rotary Actuator
Section 3 – Cylinders
3.1 Extension Cylinder
3.2 Lift Cylinder
3.3 Riser Cylinder Mounting
3.4 Riser Cylinder
3.5 Master Cylinder
3.6 Slave Cylinder
3.7 Jib Cylinder
3.8 Axle Lock Cylinder
Section 4 – Turret
4.1 Turret
4.2 Engine Tray
4.3 Grease Line
4.4 Cowling - Engine Side
4.5 Cowling - Controls Side
4.6 Cowling - Front
4.7 Manifold Hardware
4.8 Main Manifold
4.9 Brake Manifold
4.10 Fuel Tank - Kubota D1305
4.11 Fuel Tank - Kubota WG972
4.12 Hydraulic Tank
4.13 High Pressure Filter
4.14 Auxiliary Pump
4.15 Battery
4.16 Base Control Box
4.17 Base Terminal Strip
Section 5 – Base
5.1 Base
5.2 Axles
5.3 Hub Reduction - Front Axle - S/N A301 100 090 & above
5.4 Hub Reduction - Front Axle - S/N A301 100 089 & below
5.5 Differential - Front Axle
5.6 Central Housing - Front Axle
5.7 Steering Assembly
5.8 Trunnion
5.9 Drive Shaft
5.10 Hub Reduction - Rear Axle
5.11 Differential - Rear Axle
5.12 Brake - Rear Axle
5.13 Central Housing - Rear Axle
5.14 Gear Box - Rear Axle
5.15 Drive Motor
5.16 Tires
Section 6 – Engines
6.1 Kubota D1305 Engine
6.2 Air Intake & Exhaust - Kubota D1305
6.3 Fuel Lines - Kubota D1305
6.4 Flywheel Housing - D1305
6.5 Flywheel Housing - WG972
6.6 Kubota WG972 Engine
6.7 Air Intake & Exhaust - Kubota WG972
6.8 Regulator/Vaporizer Mount and Hoses
6.9 Propane Tank & Lines - Kubota WG972
6.10 Fuel Lines - Kubota WG972
6.11 Drive & System Pumps
Section 7 – Electrical Harnesses
7.1 Main Electrical & Fuel Level Switch Harnesses
7.2 Engine Harness - Kubota D1305
7.3 Engine Fuse Box - Kubota D1305
7.4 Engine Harness - Kubota WG972
7.5 ECU Power Harness - Kubota WG972
7.6 Fuel Pump Harness - Kubota WG972
7.7 Battery Cables
7.8 Control & CANbus Cables
7.9 Jib & Platform Rotate Valve Harnesses
Section 8 – Hydraulic Hoses
8.1 Standard Hose Numbering System
8.2 Boom Hoses
8.3 Turret Hoses
8.4 Base Hoses
Section 9 – Optional Equipment
9.1 Flashing Light
9.2 Oil Quick Drain
9.3 Welder & Mount
9.4 Generator - 3.5 kW
9.5 Generator - 7.5 kW
9.6 Glazier Tray
9.7 Control Box Cover
9.8 Pipe Rack
9.9 Tool Caddy
9.10 Half-Height Platform Mesh
9.11 External Railing
9.12 Positive Air Shut-off
9.13 White Noise Alarm
9.14 Elevate Telematics
9.15 Elevate Telematics Subscription
9.16 Residual Current Device (RCD)
Section 10 – Labels
10.1 Label Kit
10.2 Labels - Front and Back
10.3 Labels - Left & Right Sides
10.4 Labels - Platform
10.5 Labels - Controls Compartment
10.6 Labels - Engine Compartment
