Skyjack Articulating Booms SJ30AJE SJ30ARJE Parts Manual 196273AI 2023
Brand: Skyjack
Type of Machine: Articulating Booms
Model: Skyjack SJ30AJE, SJ30ARJE Articulating Booms
Serial Number: 90000001 to 90999999
Part Number: 196273AI
Publication Date: 2023
Number of Pages: 196 Pages
Foreword
General
Parts Ordering Information
Method of Listing
Quantities
How To Order Repair Parts
Recommended Service Parts
Section 1 – Platform
1.1 Platform Assembly
1.2 Platform
1.3 Drop Bar Gate
1.4 Swing Gate
1.5 Platform Limit Switches (KC)
1.6 Platform Control Box
1.7 Drive/Steer Controller (Single Axis)
1.8 Boom/Turret Contoller (Dual Axis)
1.9 Platform Terminal Strip
1.10 Footswitch
1.11 SGE (ANSI/CSA, CE & AS)
Section 2 – Boom
2.1 Riser Boom
2.2 Link Arm
2.3 Lower Riser Arm
2.4 2nd Riser Arm - Right
2.5 2nd Riser Arm - Left
2.6 3rd Riser Arm
2.7 Upper Riser Arm
2.8 Lower Knuckle
2.9 Upper Knuckle
2.10 Limit Switches
2.11 Main Boom
2.12 Fly Boom
2.13 Cable Track
2.14 Rotating Jib Manifold
2.15 Non Rotating Jib Manifold
2.16 Jib Arm Assembly
2.17 Rotating Jib
2.18 Non Rotating Jib
Section 3 – Cylinders
3.1 Riser Cylinder
3.2 Main Boom Cylinder
3.3 Extension Cylinder
3.4 Master Cylinder
3.5 Slave Cylinder
3.6 Jib Cylinder
3.7 Steering Cylinder
Section 4 – Turret
4.1 Turret
4.2 Left Side Subcomponents
4.3 Right Side Subcomponents
4.4 Lower Control Box
4.5 Terminal Block
4.6 Direction Sensing Switch
4.7 Main Pump
4.8 Emergency Pump
4.9 Main Manifold
4.10 Left Cowling
4.11 Right Cowling
4.12 Counterweights
4.13 Grease Line
Section 5 – Electrical Harnesses
5.1 Control Cables
5.2 Power Outlet Cable - 110/220 V
5.3 Motor Controller Harness "A"
5.4 Motor Controller Harness "B"
5.5 Main Manifold Harness
5.6 Platform Manifold Harness - SJ30 AJE
5.7 Platform Manifold Harness - SJ30 ARJE
5.8 Steering Sensor Harness
5.9 Charger Harness
5.10 Riser Cylinder Lowering Harness
5.11 Anti - Overrising Posts Harness (KC)
5.12 Upper Control Harness (KC)
5.13 Lower Control Harness (KC)
Section 6 – Base
6.1 Chassis
6.2 Steering
6.3 Steering Sensor
6.4 Swing Drive
6.5 Electrical Components
6.6 Battery Trays
6.7 Batteries
6.8 Battery Charger
6.9 Tires
Section 7 – Hose Connections
7.1 Standard Hose Numbering System
7.2 Hydraulic Hoses - Base
7.3 Hydraulic Hoses - Turret
7.4 Hydraulic Hoses - Boom
7.5 Hydraulic Hoses - Jib
Section 8 – Optional Equipment
8.1 Inverter
8.2 Inverter Shut-Off Timer
8.3 Pipe Rack
8.4 Work Lights
8.5 Flashing Light
8.6 Control Box Cover
8.7 Tool Caddy
8.8 Additional Anti-Overrising Posts (KC)
8.9 Seconday Guarding - Electrical (SGE - KC)
8.10 Air Line
8.11 Platform Mesh
8.12 Elevate Telematics
8.13 Elevate Telematics Subscription
Section 9 – Labels
9.1 Label Kit
9.2 Labels - Controls Side
9.3 Labels - Tank Side
9.4 Labels - Front, Back & Top
9.5 Labels - Platform
9.6 Labels - Hoses (KC)
Brand: Skyjack
Foreword
General
Method of Listing
Quantities
1.2 Platform
1.3 Drop Bar Gate
1.4 Swing Gate
1.10 Footswitch
Section 2 – Boom
2.1 Riser Boom
2.2 Link Arm
2.3 Lower Riser Arm
2.6 3rd Riser Arm
2.7 Upper Riser Arm
2.8 Lower Knuckle
2.9 Upper Knuckle
2.10 Limit Switches
2.11 Main Boom
2.12 Fly Boom
2.13 Cable Track
2.17 Rotating Jib
3.1 Riser Cylinder
3.4 Master Cylinder
3.5 Slave Cylinder
3.6 Jib Cylinder
Section 4 – Turret
4.1 Turret
4.5 Terminal Block
4.7 Main Pump
4.8 Emergency Pump
4.9 Main Manifold
4.10 Left Cowling
4.11 Right Cowling
4.12 Counterweights
4.13 Grease Line
5.1 Control Cables
5.9 Charger Harness
Section 6 – Base
6.1 Chassis
6.2 Steering
6.3 Steering Sensor
6.4 Swing Drive
6.6 Battery Trays
6.7 Batteries
6.8 Battery Charger
6.9 Tires
8.1 Inverter
8.3 Pipe Rack
8.4 Work Lights
8.5 Flashing Light
8.7 Tool Caddy
8.10 Air Line
8.11 Platform Mesh
Section 9 – Labels
9.1 Label Kit
- Skyjack Rough Terrain Scissors SJ6826RT SJ6832RT Service Manual 157951AF 2023
- Skyjack Rough Terrain Scissors SJ6826RT SJ6832RT Service Manual 167955AGA 2023
- Skyjack Rough Terrain Scissors SJ6826RT SJ6832RT Service Manual 213560ADA 2023
- Skyjack Rough Terrain Scissors SJ6832RTE Operating Manual 159176AE-A 2022
- Skyjack Rough Terrain Scissors SJ6832RTE Operating Manual 194419AFA 2022
- Skyjack Rough Terrain Scissors SJ6832RTE Parts Manual 167571AE 2023
- Skyjack Rough Terrain Scissors SJ6832RTE Parts Manual 194373AF 2023
- Skyjack Rough Terrain Scissors SJ6832RTE Service Manual 167574AGA 2023
- Skyjack Rough Terrain Scissors SJ7127RT to SJ9250RT Operating Manual 129922AE-A 2006
- Skyjack Rough Terrain Scissors SJ7127RT to SJ9250RT Operating Manual 143861AB-A 2008
- Skyjack Rough Terrain Scissors SJ7127RT to SJ9250RT Operating Manual 143884AC-A 2010
- Skyjack Rough Terrain Scissors SJ7127RT to SJ9250RT Operating Manual 157949AB-A 2022
- Skyjack Rough Terrain Scissors SJ7127RT to SJ9250RT Operating Manual 158009AP-A 2013
- Skyjack Rough Terrain Scissors SJ7127RT to SJ9250RT Operating Manual 159148AC-A 2022
- Skyjack Rough Terrain Scissors SJ7127RT to SJ9250RT Operating Manual 159166AC-A 2014
