Skyjack Articulating Boom Lift SJ30AJE SJ30ARJE Parts Manual 196273AI 2023
Brand: Skyjack
Type of Machine: Articulating Boom Lift
Model: Skyjack SJ30AJE, SJ30ARJE Articulating Boom Lift
Serial Number: 90000001 to 90999999
Part Number: 196273AI
Publication Date: 2023
Number of Pages: 196 Pages
Recommended Service Parts
Foreword
General
Parts Ordering Information
Method of Listing
Quantities
How To Order Repair Parts
Section 1 – Platform
1.1 Platform Assembly
1.2 Platform
1.3 Drop Bar Gate
1.4 Swing Gate
1.5 Platform Limit Switches (KC)
1.6 Platform Control Box
1.7 Drive/Steer Controller (Single Axis)
1.8 Boom/Turret Contoller (Dual Axis)
1.9 Platform Terminal Strip
1.10 Footswitch
1.11 SGE (ANSI/CSA, CE & AS)
Section 2 – Boom
2.1 Riser Boom
2.2 Link Arm
2.3 Lower Riser Arm
2.4 2nd Riser Arm - Right
2.5 2nd Riser Arm - Left
2.6 3rd Riser Arm
2.7 Upper Riser Arm
2.8 Lower Knuckle
2.9 Upper Knuckle
2.10 Limit Switches
2.11 Main Boom
2.12 Fly Boom
2.13 Cable Track
2.14 Rotating Jib Manifold
2.15 Non Rotating Jib Manifold
2.16 Jib Arm Assembly
2.17 Rotating Jib
2.18 Non Rotating Jib
Section 3 – Cylinders
3.1 Riser Cylinder
3.2 Main Boom Cylinder
3.3 Extension Cylinder
3.4 Master Cylinder
3.5 Slave Cylinder
3.6 Jib Cylinder
3.7 Steering Cylinder
Section 4 – Turret
4.1 Turret
4.2 Left Side Subcomponents
4.3 Right Side Subcomponents
4.4 Lower Control Box
4.5 Terminal Block
4.6 Direction Sensing Switch
4.7 Main Pump
4.8 Emergency Pump
4.9 Main Manifold
4.10 Left Cowling
4.11 Right Cowling
4.12 Counterweights
4.13 Grease Line
Section 5 – Electrical Harnesses
5.1 Control Cables
5.2 Power Outlet Cable - 110/220 V
5.3 Motor Controller Harness "A"
5.4 Motor Controller Harness "B"
5.5 Main Manifold Harness
5.6 Platform Manifold Harness - SJ30 AJE
5.7 Platform Manifold Harness - SJ30 ARJE
5.8 Steering Sensor Harness
5.9 Charger Harness
5.10 Riser Cylinder Lowering Harness
5.11 Anti - Overrising Posts Harness (KC)
5.12 Upper Control Harness (KC)
5.13 Lower Control Harness (KC)
Section 6 – Base
6.1 Chassis
6.2 Steering
6.3 Steering Sensor
6.4 Swing Drive
6.5 Electrical Components
6.6 Battery Trays
6.7 Batteries
6.8 Battery Charger
6.9 Tires
Section 7 – Hose Connections
7.1 Standard Hose Numbering System
7.2 Hydraulic Hoses - Base
7.3 Hydraulic Hoses - Turret
7.4 Hydraulic Hoses - Boom
7.5 Hydraulic Hoses - Jib
Section 8 – Optional Equipment
8.1 Inverter
8.2 Inverter Shut-Off Timer
8.3 Pipe Rack
8.4 Work Lights
8.5 Flashing Light
8.6 Control Box Cover
8.7 Tool Caddy
8.8 Additional Anti-Overrising Posts (KC)
8.9 Seconday Guarding - Electrical (SGE - KC)
8.10 Air Line
8.11 Platform Mesh
8.12 Elevate Telematics
8.13 Elevate Telematics Subscription
Section 9 – Labels
9.1 Label Kit
9.2 Labels - Controls Side
9.3 Labels - Tank Side
9.4 Labels - Front, Back & Top
9.5 Labels - Platform
9.6 Labels - Hoses (KC)
