Hyundai
86
176,834
Sinotruck Engine MC11 Euro III Repair Manual
Brand: Sinotruck
Type of Manual: Repair Manual
Model: Sinotruck MC11 Euro III Engine
Number of Pages: 273 Pages
PREFACE
INTRODUCTION
SAFETY INSTRUCTIONS
ENGINE DESCRIPTION
CHARACTERISTIC DATA
ENGINE ELECTRICS
ELECTRIC CONTROL UNIT(EDC)
REMOVING AND INSTALLING THE ENGINE CONTROL UNIT
COOLING SYSTEM
FAN
REMOVING AND INSTALLING THE FAN
FAN DRIVE
REMOVING AND INSTALLING THE FAN DRIVE
COOLANT MANIFOLD
REMOVING AND INSTALLING THE COOLANT MANIFOLD
THERMOSTATS
REMOVING AND INSTALLING THE THERMOSTATS
THERMOSTAT HOUSING
REMOVING AND INSTALLING THE THERMOSTAT HOUSING
COOLANT PUMP
REMOVING AND INSTALLING THE COOLANT PUMP
DISTRIBUTOR HOUSING
REMOVING AND INSTALLING THE DISTRIBUTOR HOUSING
MOUNTED COMPONENTS
AIR COMPRESSOR
REMOVING AND INSTALLING THE 1-CYLINDER AIR COMPRESSOR
STARTER
REMOVING AND INSTALLING THE STARTER
BELT DRIVE
REMOVING AND INSTALLING THE BELT DRIVE
ALTERNATORS
REMOVING AND INSTALLING THE ALTERNATOR
INTAKE/EXHAUST SYSTEM
EXHAUST MANIFOLD
REMOVING AND INSTALLING THE EXHAUST MANIFOLD
CHARGE-AIR PIPES
REMOVING AND INSTALLING THE CHARGE-AIR PIPES
CHARGER-AIR MANIFOLD
REMOVING AND INSTALLING THE CHARGE-AIR MANIFOLD
TURBOCHARGER
REMOVING AND INSTALLING THE TURBOCHARGER
CYLINDER HEAD
REMOVING AND INSTALLING THE CYLINDER HEAD
CHECKING AND SETTING THE VALVE CLEARANCE
VALVE STEM SEALS
REMOVING AND INSTALLING THE VALVE STEM SEALS
VALVE TIMING
CAMSHAFT/CAMSHAFT BEARING
REMOVING AND INSTALLING THE CAMSHAFT/CAMSHAFT BEARING
VALVE TIMING
CHECKING THE VALVE TIMING
REAR TIMING GEARS
REMOVING AND INSTALLING THE REAR TIMING GEARS
COMMON-RAIL SYSTEM
REMOVING AND INSTALLING THE INJECTORS AND PRESSURE PIPE
HIGH-PRESSURE PUMP/HIGH-PRESSURE PUMP DRIVE
REMOVING AND INSTALLING THE HIGH-PRESSURE PUMP/HIGH-PRESSURE PUMP DRIVE
DISMANTLING AND ASSEMBLING THE FUEL SERVICE CENTRE
ENGINE LUBRICATION
OIL MODULE
REMOVING AND INSTALLING THE OIL MODULE
OIL SUMP AND OIL SUCTION PIPE
REMOVING AND INSTALLING THE OIL SUMP AND OIL SUCTION PIPE
OIL INJECTOR NOZZLES
REMOVING AND INSTALLING THE OIL INJECTOR NOZZLES
OIL PUMP
REMOVING AND INSTALLING THE OIL PUMP
CRANKSHAFT OIL SEALS
REMOVING AND INSTALLING THE FRONT CRANKSHAFT OIL SEAL
REMOVING AND INSTALLING THE REAR CRANKSHAFT OIL SEAL
ENGINE HOUSING
FLYWHEEL HOUSING/TIMING CASE
REMOVING AND INSTALLING THE FLYWHEEL HOUSING/TIMING CASE
COVER
REMOVING AND INSTALLING THE COVER
CYLINDER LINERS
REMOVING AND INSTALLING THE CYLINDER LINERS
PISTONS AND CONNECTING RODS
VIBRATION DAMPER
REMOVING AND INSTALLING THE VIBRATION DAMPER
FLYWHEEL
REMOVING AND INSTALLING THE PISTONS AND CONNECTING RODS
CRANKSHAFT
REMOVING AND INSTALLING THE CRANKSHAFT
FRONT DRIVE GEARS
REMOVING AND INSTALLING THE FRONT DRIVE GEARS
TECHNICAL DATA
