Sinoboom Scissor Lift 4389RE Schematic Maintenance Manual
Brand: Sinoboom
Type of Machine: Scissor Lift
Type of Manual: Maintenance Manual, Error Code, Electrical Schematic, Hydraulic Schematic
Model: Sinoboom 4389RE Scissor Lift
List of Files:
1323RE 1623RE 4389RE 5389RE Maintenance Manual 515006110002 2021 Rev A.pdf (106 Pages)
Index
MaintenanceManual
Introduction
1 Specifications
2 Safety
3 System Descriptions
4 Service and Guidelines
5 Maintenance
6 Repair
Appendix 1: Prepare the Work Record Before Delivery
Appendix 2: Repair & Inspection Report
Appendix 3: Major Modification and Repair Record
1323RE 1623RE 4389RE 5389RE Maintenance Manual 515008110002 2024 Rev B.pdf (127 Pages)
Index
To Users
Manual Revision History
Applicable Models
Safety Warning Symbols and Signs
Maintenance Safety Precautions
General
Instructions before Maintenance
Maintenance Safety
Considerations After Maintenance
Technical Characteristics
Machine Specifications
Specifications of Major Components
Function Speed
Weight of Major Components
Pressure Settings
Oil Specifications
Torque Specifications
Maintenance Instructions
Inspection and Preventative Maintenance Schedule
General Maintenance Instructions
Platform Components
Platform Controller
Platform Assembly
Platform Extension
Scissor Arms Components
Disassembly and Installation
Safety Arm
Lift Cylinder
Scissor Arms Wear Pads
Chassis Component
Travel Drive and Steering Device
Tire Assembly
Battery
Power System
Auxiliary Power System
Range Extender Control System
Kubota Engine Z482-E4 Series
Layout of Hydraulic Elements
Function Valves
Hydraulic Oil
Hydraulic Tank
Hydraulic Oil High-pressure Filter
Bleeding the Oscillating Cylinder
Oscillation Function Check
Lubricating Oil Cylinder
Inspecting Cylinder Drift
Hydraulic Symbols
Hydraulic Schematic Diagram
Battery
Electrical Symbols
Electrical Schematic Diagram
Troubleshooting Guide
Charging Faults and Solutions
Fault Codes Description
Basic Trouble Shooting
Functions and Controls
Machine Positions
Drive Function
Braking Function
Tilt Protection Function
Overload Limit Function
Platform Staged Lowering Function
Emergency Lowering Function
Control System
Sinoboom Main Control System
DTC-K120 Main Control System
Appendix
Inspection and Preventive Maintenance Schedule
Brand: Sinoboom
List of Files:
Index
MaintenanceManual
Introduction
1 Specifications
2 Safety
5 Maintenance
6 Repair
Index
To Users
Applicable Models
General
Maintenance Safety
Function Speed
Pressure Settings
Oil Specifications
Platform Components
Platform Controller
Platform Assembly
Platform Extension
Safety Arm
Lift Cylinder
Chassis Component
Tire Assembly
Battery
Power System
Function Valves
Hydraulic Oil
Hydraulic Tank
Hydraulic Symbols
Battery
Electrical Symbols
Machine Positions
Drive Function
Braking Function
Control System
Appendix
- Sinoboom Scissor Lift 1532ME Schematic Parts Manual
- Sinoboom Scissor Lift 1530S Operation Manual
- Sinoboom Scissor Lift 1930S Schematic Parts Manual
- Sinoboom Scissor Lift 1530SE 0407SE-1 Operation Manual
- Sinoboom Scissor Lift 1930SE Schematic Parts Manual
- Sinoboom Scissor Lift 1530SE 0408SE Operation Manual
- Sinoboom Scissor Lift 1932M Schematic Parts Manual
- Sinoboom Scissor Lift 1532M Operation Manual
- Sinoboom Scissor Lift 1932ME Schematic Parts Manual
- Sinoboom Scissor Lift 1532ME Operation Manual
- Sinoboom Scissor Lift 1932SE Schematic Parts Manual
- Sinoboom Scissor Lift 1930S Operation Manual
- Sinoboom Scissor Lift 2132 Schematic Parts Manual
- Sinoboom Scissor Lift 1930SE Operation Manual
- Sinoboom Scissor Lift 2132E Schematic Parts Manual
