Hyundai
86
176,684
SDLG Diesel Engine YN4EL089-33CR Service Manual
Brand: SDLG
Type of Machine: Diesel Engine
Type of Manual: Service Manual, Wiring Diagram
Model: SDLG YN4EL089-33CR Diesel Engine
Number of Pages: 113 Pages
Chapter I Main Technical Specification and Data for Electronic Control
(I) Main technical specifications
(II) Specification of main accessories
(III) Main technical data
(IV) Main part size, fit clearance and abrasion limit
Chapter II Disassembly of Diesel Engine
(I) Maintenance requirements and attentions for engine
(II) Disassembly of engine assembly
(III) Disassembly of engine assemblies
Chapter III Assembly of Diesel Engine
(I) Assembly of body
(III) Assembly of piston-connecting rod assembly
(IV) Assembly of camshaft and oil pump
(VI) Assembly of cylinder head part
(VII) Assembly of accessories
(VIII)Installation, use and maintenance of electronic control high-pressure common rail system
(IX) Assembly and adjustment of engine assembly
Chapter IV Maintenance and Check of Diesel Engine
(I) Body assembly
(II) Cylinder head part
(III) Valve mechanism
(IV) Crankshaft, flywheel and clutch parts
(V) Piston and connecting rod assembly
(VI) Driving wheel system
(VII) Lubrication system
(VIII) Cooling system
(IX) Electronic control common rail system
(X) Electrical system
(XI) Intake and supercharging and intercooling system
Chapter V Use of Diesel Engine
I. Diesel oil
II. Oil
IV. Starting of diesel engine
V. Breaking-in of diesel engine
VI. Running of diesel engine
VII. Stopping of diesel engine
Chapter VI Maintenance of Diesel Engine
1. First breaking-in mandatory maintenance
2. Regular mandatory maintenance
3. Routine maintenance
4. Technical maintenance for using in winter
Chapter VII Fault Diagnosis of Diesel Engine
Overall Connection Dimension Diagram for YN33CR
Schematic Wiring Diagram for ECU
YN4EL机型高压油泵安装图解
