Support
Cleaner
181
99,324,774
Scania XCOM 2.31 Diagnostic Tool Remote Installation Service
Scania XCOM 2.31.0 Diagnostic & Programmer Install Remote
Region: All regions
Type of software: Diagnostic & Programmer Software TOOL
Type of Machine: Trucks and Buses
Interface & Database Languages: English
VCI Interface: Kvaser
OS: Tested on Windows 11 64 bit, Windows 10 64 bit
High-Speed Link Download
*** NOTE: Contact us to get more information before you download this tool
After downloading send to email "gallons@autorepairmanuals.ws, admin@autorepairmanuals.ws" to get the password
Scania XCOM 2.31.0 is a software diagnostic tool designed for the diagnosis and maintenance of trucks, other heavy vehicles or heavy-duty engines made by Scania. Scania XCOM allows you to read, save and modify data (DTC trouble codes, parameters, statistics and other types of data) from various supported ECUs on Scania trucks. Scania XCOM is designed to be compatible with both Scania VCI2 and the latest Scania VCI3 diagnostic devices (CAN protocol supported, so there will be no compatibility issues at all). Despite the most common functions of Scania XCOM diagnostic software, there are some exciting features available for XCOM users. First of all, you have the option to turn off the SCR catalytic system. You can turn this off so the Selective Catalytic System will stop consuming DEF – Diesel Exhaust Liquid). Also, you can turn off or disable EGR (Exhaust Gas Recirculation), immobilizer system, etc. For more advanced users there are options for ECU recovery, reset or unlocking without a PIN code. XCOM Access Level utility allows you to switch between XCOM levels (XCOM High, XCOM Industry & Marine and XCOM Internal). The software shipped with a USB HASP license key. Also, you’ll need a PC (with Windows XP/Vista/7 32bit version) and a VCI diagnostic interface (Scania VCI2 or Scania VCI3) to use this software.
Scania XCOM 2.31 supported ECU:
  • Engine management system (EMS)
  • Gearbox management system (GMS)
  • Retarder system (RET)
  • All-wheel drive system (AWD)
  • Clutch Control (CLS)
  • Exhaust Emission Control (EEC)
  • Coordinator (COO – COO7)
  • Bodywork system (BWS – BCI1)
Scania XCOM 2.31 supported DTC
  • EMS (S6, S7, S8)
  • GMS (OPC4, OPC5)
  • RET (RET1, RET2)
  • AWD (AWD1)
  • EEC (SCR1, EEC3)
  • COO (COO6, COO7)
  • HMS (HMS1)
Other Scania XCOM 2.31 functions
  • SCR turning ON/OFF
  • EGR turning ON/OFF
  • Immobilizer Enable/Disable
  • Truck power increase
  • ECU recovery
  • ECU reset
  • ECU unlock without PIN
Driver
512
1,821,862
#2
Checkout was easy, absolutely perfect. Customer service provided by your team is amazing, they helped remotely to get my manual started for me without any hitches, I for sure will purchase again from them.
