Darylxd
3
22,058
Scania XCOM 2.30.0 Diagnostic & Programmer Tool
Scania XCOM 2.30.0
Region: All regions
Type of software: Diagnostic & Programmer Software TOOL
Type of Machine: Trucks and Buses
Interface & Database Languages: English
VCI Interface: Kvaser
OS: Tested on Window 11 64 bit and Window 10 64 bit
Instruction: Present
High-Speed Link Download
After downloading send to email "gallons@autorepairmanuals.ws, admin@autorepairmanuals.ws" to get the password
Scania XCOM is a software diagnostic tool designed for diagnosis and maintenance of trucks, other heavy vehicles or heavy-duty engines made by Scania. Scania XCOM allows you to read, save and modify data (DTC trouble codes, parameters, statistics and other types of data) from various supported ECU on Scania trucks. Scania XCOM is designed to be compatible with both Scania VCI2 and with latest Scania VCI3 diagnostic devices (CAN protocol supported, so there will be no any compatibility issues at all). Despite most common functions of Scania XCOM diagnostic software, there are some exciting features available for XCOM user. First of all, you have the option to turn off SCR catalytic system. You can turn this off so Selective Catalytic System will stop consuming DEF – Diesel Exhaust Liquid). Also, you can turn off or disable EGR (Exhaust Gas Recirculation), immobilizer system, etc. For more advanced users there are options for ECU recovery, reset or unlocking without a PIN code. XCOM Access Level utility allows you to switch between XCOM levels (XCOM High, XCOM Industry & Marine and XCOM Internal). The software shipped with USB HASP license key. Also, you’ll need PC (with Windows XP/Vista/7 32bit version) and VCI diagnostic interface (Scania VCI2 or Scania VCI3) to use this software.
Scania XCOM supported ECU
  • Engine management system (EMS)
  • Gearbox management system (GMS)
  • Retarder system (RET)
  • All wheel drive system (AWD)
  • Clutch Control (CLS)
  • Exhaust Emission Control (EEC)
  • Coordinator (COO – COO7)
  • Bodywork system (BWS – BCI1)
Scania XCOM supported DTC
  • EMS (S6, S7, S8)
  • GMS (OPC4, OPC5)
  • RET (RET1, RET2)
  • AWD (AWD1)
  • EEC (SCR1, EEC3)
  • COO (COO6, COO7)
  • HMS (HMS1)
Other Scania XCOM functions
  • SCR turning ON/OFF
  • EGR turning ON/OFF
  • Immobilizer Enable/Disable
  • Truck power increase
  • ECU recovery
  • ECU reset
  • ECU unlock without PIN
Darylxd
3
22,058
#2
The SCANIA VCI 3 interface is a highly advanced diagnostic tool for Scania trucks, buses, and other heavy vehicles. It offers several highlighted features that make it a perfect replacement for the Scania VCI 2 interface.
Firstly, it comes with software versions V2.53.5/V2.60.1.7, which can be updated easily via a download link. Additionally, the VCI firmware is upgradeable, ensuring that you always have the latest software.
The interface supports both WiFi and USB connections, providing flexibility in how you connect to your vehicle. You can now work without the hassle of wired connections, eliminating problems such as damaged data cables.
The recommended operating system for the SCANIA VCI 3 is WIN10, ensuring smooth and efficient performance. It also offers language support in English, German, Spanish, French, Japanese, Dutch, Polish, Portuguese, Swedish, Norwegian, Suomi, Turkish, Italian, Czech, Russian, and Chinese.
The VCI 3 interface is specifically designed to support all Scania diagnostic systems based on the CAN network. It is extremely fast and compact, making it a convenient tool for diagnostics.
One of the most exciting new features of the VCI 3 interface is its WiFi wireless connection capability. This allows you to work without being tethered to your truck, avoiding the limitations of wired connections.
To use the VCI 3, you will need the Scania SDP3 2.18 version or later. This software provides the necessary support for the VCI 3 functionality.
It's important to note that the VCI 3 adapter is designed for use with trucks and engines manufactured from 2004 onwards. It may not be compatible with older vehicles.
Overall, the SCANIA VCI 3 interface offers a range of impressive features, allowing for efficient and convenient diagnostic work on Scania trucks, buses, and other heavy vehicles.
