Hyundai
86
176,834
Sany Telehandler STH844A Parts Catalog
Brand: Sany
Type of Machine: Telehandler
Model: Sany STH844A Telehandler
Number of Pages: 372 Pages
Group 1 Telehandler
STH100000020 Telehandler​
Group 2 Assembly, A3 Cab
STH005777600 Assembly, A3 Cab​
STH005046938 Cab Fitting Attachments​
STH006073510 Gasket Assembly, Fuel Tank​
14443569 System, Air Conditioner​
141501000021A Assembly, Air Conditioner​
60030991 Evaporator​
160499000112A Fuel Tank​
230901000024A Assembly, Cab​
230902000012A Cab​
JSS004600259 Cab Body​
14472194 Assembly, Sheet-metal Inner-decoration​
14471870 Assembly, Armrest Box​
14470791 Assembly, IP​
JSS004588565 Assembly, Outer Decoration​
JSS004912075 Assembly, Electrical​
130907000081A Assembly, Front Windscreen Wiper​
STH006107960 System, Control​
130903000093A Driver Seat​
131199000014A Adjustable Steering Column Assembly​
STH006608614 Installation components for chart load​
Group 3 chassis assembly
STH006996911 chassis assembly​
STH006928966 Power assembly​
STH006942107 Engine and transmission assembly​
160102040028A Engine​
130202000047A Transmission​
130202000041A004 Group-Converter Housing​
130202000047A192 Group-Transmission Case​
130202000041A005 Group-Torque Converter​
130202000041A006 Group-Gear​
130202000041A007 Group-Pump Drive​
130202000041A008 Group-Charging Pump Sae B​
130202000047A090 Reverse Idler Set​
130202000041A010 Group-Forward & Reverse Shaft​
130202000041A011 Group-3Rd Shaft​
130202000047A012 Level-1/2 Shaft Set​
130202000047A020 Output shaft Subassembly​
130202000047A187 Low Speed Transmission Set​
130202000041A015 Group-Control​
130202000047A082 Regulating Valve Assembly Set​
130202000041A017 Group-Drive Plate​
STH007961248 intake system​
B222100000368 Air Filter​
STH006943079 Exhausted system​
STH005656315 Radiator assembly​
14442848 Fuel System​
STH007801906 driving system​
131401010003A Rear Axle​
14263369 Frame Leveling Cylinder​
STH006995661 fitting attachments​
STH004933301 assembly​
130907000181A Left Fender​
130907000182A Right Fender​
STH004942017 Covering parts assembly​
STH004942473 protect​
STH004941989 countweight assembly​
A222200000036 Latch​
Group 4 Fork Assembly
14288237 Fork Assembly​
Group 5 Whole booom assembly
STH004825306 Whole booom assembly​
STH004818292 1st-section boom assembly​
STH004733103 Subassembly, Sliding Block​
STH004733115 Subassembly, Side Sliding Block​
STH005034445 Subassembly, Sliding Block​
STH004820063 2nd-section boom assembly​
STH004734045 Subassembly, Sliding Block​
STH004733190 Subassembly, Sliding Block​
STH004735397 Subassembly, Sliding Block​
STH004823225 4th section boom assembly​
STH004825287 Telescopic system​
STH005216907 attachments​
150901040821A Outrigger Cylinder​
Group 6 hydraulic system
STH004861422 hydraulic system​
STH004861406 pump and main valve system​
60154165 Open Piston Pump​
13639883 Flange Subassembly​
STH004817025 braking valve group​
STH004816986 Priority Valve Group​
STH004816929 Valve Group, Multi-way​
STH004876805 Boom hydraulic system​
152301000239A Valve Group, Fork Balancing​
STH004817128 Valve Group, Telescopic Balancing​
152301000240A Valve Group, Slave Balancing​
STH004817118 Valve Group, Luffing Balancing​
STH004861427 Level adjustment hydraulic system​
STH005230538 valve block​
STH004864534 RAS hydraulic​
STH006246482 RAS Valve Group​
STH004865451 steering system​
STH004823091 Subassembly, Steering Gear​
SMH005915449 Steering Valve Set​
150401010053C Electromagnetic Change Valve​
STH004871339 cooling system​
STH004845614 hydraluic oil tank assem.​
STH004823985 Subassembly, Return Oil Radiator Three-way Joint​
STH004823550 Subassembly, One-way Valve​
STH004872991 braking system​
STH006482035 Subassembly, Single-circuit Brake Valve​
150599000059A Single-circuit Brake Valve​
Group 7 name plate assembly
STH004876528 name plate assembly​
Group 8 Electrical System
STH006892175 Electrical System​
STH005931655 engine components assembly diagram​
STH006893175 Cab electrical wiring harness component layout​
60218598 Ignition Switch​
STH005426323 Layout Diagram, Rocker Switches, Left Panel​
STH006084435 layout diagram of right panel rocker switch​
STH005427548 Layout Diagram, Controller Mounting Plate Components​
STH006898167 Boom electrical layout​
13275826 Fastening Clamp​
STH007154200 Frame Electrical Layout (General)​
12912575 Monotone Horn Assembly​
Group 9 Spare Parts
STH005881889 Spare Parts​
