Martin Welker
104
230,310
Sany Motor Grader STG180C-8 STG190C-8 STG210C-8 Part Manual PY5819BH0289
Brand: Sany
Type of Machine: Motor Grader
Type of Manual: Part Manual
Model: Sany STG180C-8 STG190C-8 STG210C-8 Motor Grader
Part Number: PY5819BH0289
Number of Pages: 249 Pages
Group 1 STG190C-8 Sany Motor Grader
14004638 STG190C-8 Sany Motor Grader
Group 2 frame assembly STG190C-8.1
14055787 frame assembly STG190C-8.1
Group 3 Swing Support Assembly STG180C-8.8
14005346 Swing Support Assembly STG180C-8.8
13369615 Fork GP
Group 4 Hydraulic System STG210C-8W3(G).19
14144617 Hydraulic System STG210C-8W3(G).19
14011733 Oil Cylinder Assembly STG180C-8W3.19.22
A810201064583 Tilted cylinder,wheel,front
13134784 Steering cylinder,right
11723343 Installation,tube valve
A810201064586 Oil cylinder, locking pin
10331997 Oil cylinder, swing, shovel
10347328 Steel pipe GP, oil cylinder, swing, shovel
10333258 Oil cylinder, lift, shovel
11090314 Cylinder, Blade Tip
A810201064605 Steering Cylinder
13134743 Steering cylinder,left
14061880 Rotary motor assembly STG180C-8W3.19.1
14011993 left multi-way valve assem. STG180C-8W3.
13635656 Steering Gear Assembly SAG170.19.2
13411250 Brake Valve Assy
12419733 Mounting,valve,prefill
14061886 Accumulator component STG180C-8W3.19.13
13638192 oil return filter SAG170.19.5
B222100000151 Filter, oil
13723420 Working Pump SAG180.19.11
14061884 Prior valve installation STG180C-8W3.19.
14013509 system pipeline device STG180C-8W3.19.5
11725143 Swivel, Hydraulic
A810201069001 Swivel
Group 5 Control console assembly STG190C-8.10
14048228 Control console assembly STG190C-8.10
Group 6 Working operation device STG190C-8.27A
14049865 Working operation device STG190C-8.27A
11664438 Lever,Lift Control, Left
11664305 Lever, Blade Sideshift
11664246 Lever,Blade Tip
11664235 Lever,Blade Rotate
11664007 Lever,Blade Swing
11663971 Lever,Articulation Steering
11663799 Lever,Front Wheel Tilt
11662942 Lever, Lift Control, Right
Group 7 CAB ASSM STG180C-8.9
14002243 CAB ASSM STG180C-8.9
13246409 Ladder
14002314 install box STG180C-8.9.10
Group 8 hydraulic fuel tank assy. STG180C-8.26A
14052536 hydraulic fuel tank assy. STG180C-8.26A
Group 9 Power system assembly STG180C-8W3.11
14009529 Power system assembly STG180C-8W3.11
14009040 Intake system STG180C-8.11.1
14098718 cooling system STG190C-8W3.11.3
14008495 Fuel System STG180C-8W3.11.4
14008110 Engine Installation STG180C-8W3.11.5
Group 10 hood assem STG180C-8W3.13
14009971 hood assem STG180C-8W3.13
Group 11 motor grade electric system STG180C-8W3.
14004761 motor grade electric system STG180C-8W3.
14007109 front opreat plate STG1180C-8.29.3
14050269 cabel ass
14007499 system power STG180C-8.29.13
Group 12 fuel tank body STG180C-8.28B
14049876 fuel tank body STG180C-8.28B
Group 13 Shovel STG180C-8.5A
14004064 Shovel STG180C-8.5A
13863782 Shovel SMG230.5.2
Group 14 Axle-TM Assembly STG230C-8S3.16(A)
14057097 Axle-TM Assembly STG230C-8S3.16(A)
14057090 Double-variable assembly STG230C-8.16(A)
Group 15 Air conditioning STG190C-8W3.18
14056811 Air conditioning STG190C-8W3.18
14012769 CompressorBracket STG180C-8W3.18.1
Group 16 Wheel
A810304040010 Wheel
Group 17 rear axle assemble STG190C-8.15(B)
14118301 rear axle assemble STG190C-8.15(B)
Group 18 Operating device STG230C-8.2
14056274 Operating device STG230C-8.2
A229900006820 Clamp, Tube, Double
Group 19 Case,gear,worn
60199612 Case,gear,worn
Group 20 Axle GP, front
10772247 Axle GP, front
A810304040017 Hub, wheel
13051725 Hinge, ball
A810305030029 Rod, pull, slope
10885656 Linkages, steering
10659441 Left ball joint AS
10659957 Right ball joint AS
Group 21 rear decorating cover STG190C-8.45
14066424 rear decorating cover STG190C-8.45
