Sany Hydraulic Excavator SY550H Shop Manual
Brand: Sany
Type of Machine: Crawler Hydraulic Excavator
Type of Manual: Shop Manual, Hydraulic Diagram, Wiring Diagram
Model: Sany SY550H Hydraulic Excavator
Publication Date: 2019
Number of Pages: 636 Pages
1 Preface
1.1 Reading Method of Maintenance Manual
1.2 Explanation on Terms for Maintenance Standards
1.3 Handling of Electrical Component and Hydraulic Components
1.4 Pipe joint
1.5 Bolt and nut
1.6 Maintenance of Split Flange
1.7 Conversion Table
2 Safety
2.1 Instructions on Safety Signs
2.2 General Notices
2.3 Preparatory Work before Maintenance
2.4 Notices for Maintenance/Repair
2.5 Other Notices
3 Technical Specification
3.1 Specified size
3.2 Technical Specification
3.3 Table of Weight
3.4 Engine oil, fuel and coolant
3.5 Feature curve of engine
4 Structure, function and maintenance standard
4.1 Engine and Cooling System
4.2 Transmission Train
4.3 Lower travelling device
4.4 Hydraulic system (Part 1)
4.5 Hydraulic system (Part 2)
4.6 Hydraulic system, Part 3
4.7 Working Device
4.8 Air conditioning system
4.9 Engine control
4.10 Electrical Control System
4.11 Display system
5 Standard value of components
5.1 Table of standard values for engine-related parts
5.2 Table for standard value of body-related parts
6 Trouble diagnosis and troubleshooting
6.1 Precautions during Trouble Diagnosis
6.2 Work Procedure for Trouble Diagnosis
6.3 Inspection before Trouble Diagnosis
6.4 Category and steps of trouble diagnosis
6.5 Connector
6.6 Trouble diagnosis when current trouble code is displayed
6.7 Trouble Diagnosis for Electrical System (Mode E)
6.8 Trouble diagnosis for hydraulic and mechanical systems (mode H)
7 Testing and Adjustment
7.1 Measurement of Color of Exhaust Gas
7.2 Adjust the valve clearance
7.3 Measurement of compression pressure
7.4 Inspection and adjustment of injection timing
7.5 Measurement of engine oil pressure
7.6 Adjustment of engine speed sensor
7.7 Inspection and adjustment of A/C compressor belt tensioning device
7.8 Measurement of clearance of slewing support bearing
7.9 Inspection and adjustment of crawler plate tensioning device
7.10 Inspection and adjustment of hydraulic pressure in hydraulic oil ways for working device, slewing and travelling
7.11 Inspection and adjustment of control oil way pressure
7.12 Measurement of output pressure of electromagnetic valve
7.13 Measurement of output pressure of pilot valve
7.14 Adjustment of working device and slewing PPC valve
7.15 Inspection of hydraulic settlement of working device
7.16 Release of residual pressure in hydraulic oil way
7.17 Measurement of oil leakage
7.18 Air Bleeding for Every Device
7.19 Inspection on sensor
8 Disassembling and Assembling
8.1 Notices for Operation
8.2 Dismantlement and installation of start motor assembly
8.3 Dismantlement and installation of fuel injection pump assembly
8.4 Dismantlement and installation of rear oil seal of engine
8.5 Dismantlement and installation of cylinder head assembly
8.6 Disassembling and assembling of cylinder head assembly
8.7 Dismantlement and installation of radiator assembly
8.8 Dismantlement and installation of engine and hydraulic pump assembly
8.9 Dismantlement and installation of final transmission assembly
8.10 Disassembling and assembling of final transmission assembly
8.11 Dismantlement and installation of slewing motor and slewing mechanism assembly
8.12 Disassembling and assembling of slewing motor and slewing mechanism assembly
8.13 Disassembling and assembling of guiding wheel assembly
8.14 Dismantlement and installation of sprocket
8.15 Dismantlement and installation of crawler assembly
8.16 Dismantlement and Installation of Back slewing Bearing Assembly
8.17 Dismantlement and installation of slewing table assembly
8.18 Dismantlement and installation of central slewing joint assembly
8.19 Disassembling and assembling of Central Back slewing Joint Assembly
8.20 Dismantlement and Installation of Hydraulic Oil Tank Assembly
8.21 Dismantlement and Installation of Control Valve Assembly
8.22 Dismantlement and installation of hydraulic pump assembly
8.23 Dismantlement and installation of oil seal in hydraulic pump input shaft
8.24 Dismantlement and installation of independent oil disperser
8.25 Disassembling and assembling of working device pilot valve assembly
8.26 Disassembling and assembling of travelling pilot valve assembly
8.27 Disassembling and assembling of hydraulic cylinder assembly
8.28 Dismantlement and Installation of Working Device Assembly
8.29 Dismantlement and installation of A/C device assembly
8.30 Dismantlement and installation of balance weight assembly
8.31 Dismantlement and installation of cab assembly
8.32 Dismantlement and installation of display screen
8.33 Dismantlement and installation of controller assembly
8.34 Dismantlement and installation of radio
8.35 Removal and Installation of Storage Battery
8.36 Dismantlement and installation of key switch
8.37 Dismantlement and installation of fuse box
8.38 Dismantlement and installation of wiper
8.39 Dismantlement and installation of relay
8.40 Installation and dismantlement methods for terminal of plug-in part
9 Hydraulic & Electrical Diagram
9.1 Hydraulic schematic diagram
9.2 Electrical schematic diagram
9.3 Schematic diagram of wiring harness
Brand: Sany
1 Preface
1.4 Pipe joint
1.5 Bolt and nut
2 Safety
2.2 General Notices
2.5 Other Notices
3.1 Specified size
3.3 Table of Weight
4.7 Working Device
4.9 Engine control
4.11 Display system
6.5 Connector
- Sany Container Reach Stacker RSC45C2 Operation & Maintenance Manual
- SANY Hydraulic Crawler Crane SCC500E COMPLETE MANUAL
- Sany Hydraulic Excavator SY215C9M2K Parts Book
- Sany Container Reach Stacker Safety, Operation & Maintenance Manual
- Sany Body Container Reach Stacker SRSC45C2 Parts Book
- Sany SY205-215C9M2K Electrical Schematics
- SANY Crawler Hydraulic Excavator SY215C Shop Manual
- Sany SY65C-SY135C-8 Electric Hydraulic Schematics
- Sany SCC500E-R1 Crawler Crane Assembly Part Book
- SANY SCC8500 500-ton crawler crane offers multiple configurations
- SANY SY230C8E Electrical Schematics
- Sany QY50C Truck Crane Parts Book
- Earthdrill SANY SR220C hydraulic diaphram
- Sany SY200C1-Electrical Schematics
- Sany SY230C6B-1 Electrical Schematics
