Momed80
150
35,046
Sany Hydraulic Excavator SY215C9M2K Parts Catalog SANSY216LDE103528 ZH EN
Language: Chinese, English
Brand: Sany
Model: Sany SY215C9M2K(SKD) Hydraulic Excavator
Part Number: SANSY216LDE103528
Number of Pages: 442 Pages
第1章 SY215C9液压挖掘机(Hydraulic Excavator)
12380319 SY215C9液压挖掘机(Hydraulic Excavator)
第2章 回转装置(Slewing device)
12395020 回转装置(Slewing device)
12392761 先导管路(Pipeline, pilot)
12392388 PPC管路(Pipeline, PPC)
60004101 脚踏阀(Valve, foot)
B220401001302 手动先导阀(Valve, pilot, manual)
12392583 电磁阀管路(Lines, solenoid valve)
12392728 主阀管路(Pipeline, main valve)
12392663 主泵管路(Pipeline, main pump)
B229900000063 压油过滤器(Filter, oil)
12380481 驾驶室(Cab)
12302648 车身总成(Body AS, machine)
11654149 车身主体(Body, machine)
11646101 内饰件总成(Plate GP,protect,decoration,inner)
12302091 中挖驾驶室GPS电气总成(Elctric systerm)
A222200000147 锁体(Lock AS)
12380014 座椅及操纵箱(Seat and control console)
B229900000265 机械悬浮式驾驶座椅(Seat, cab, mechanical suspension)
12076176 行走操纵机构(Control mechanism, travel)
12380266 底板架(Support, bottom plate)
12387111 回转支承总成(Bearing AS, swing)
12450407 液压主管路(Pipeline, main, hydraulic)
B229900003821 减速机总成(Reducer GP)
60180836 回转马达(Rotary motor)
60010554 减速机(Reducer)
60008123 多路阀(Valve, main control)
60008122 柱塞泵(Pump, plunger)
60081915 柱塞泵组件(Pump GP, plunger)
60000735 先导齿轮泵(Pump, gear, pilot)
60119021 调节器(Regulator)
12450362 回油管路(Oil return pipelineSY215C9M2KSKD12A2)
A810201010243 液压油箱总成(Tank GP, hydraulic)
12380531 空调系统(Air conditioning system)
60168171 空调单元总成(Air conditioner unit AS)
10473304 空调电气系统(Electrical system, air conditioner)
12451573 覆盖件总装(Cover GP)
A810502017020 电瓶箱总成(Box GP, battery)
A810502017021 工具箱主体(Body, toolbox)
A810502020139 扶手(Handhold)
12169042 机顶罩总成(Engine hood GP)
11616245 托架(Bracket)
11770216 空滤隔板总成(Partition GP,filter,air)
A810502010196 右门总成(Door GP, right)
A810502019117 连接板(Board, connecting)
A810502012314 柴油机左隔板(Partition, left, engine)
A810502014136 架(Bracket)
12395986 左门总成(Door GP, left)
11616300 转角板(Plate, angle)
11616259 柴油机右隔板(Partition, right, engine)
12378692 动力系统(Power system)
12377308 减震及传动系统(Damping and transmission systemSY215C9M2)
12377890 排气系统(Exhaust systemSY215C9M2K(SKD)132)
12450863 冷却系统(Cooling systemSY215C9M2KSKD133)
60182015 散热器(Radiator)
12450844 进气系统(Intake SystemSY215C9M2KSKD134)
B222100000436 空气滤清器(Air cleaner)
12378152 燃油系统(Fuel SystemSY215C9M2K(SKD)135)
11861794 燃油箱总成(Tank GP, fuel)
60033344 燃油预滤总成(Fuel prefilter GP)
12378340 油门控制系统(Control mechanism of throttleSY215C9M2K()
60126312 熄火装置SY-3776852 防水型(Extinction device)
B220502000001 控制马达(Motor GP, Throttle)
60028480 缸盖(Cylinder Head AS)
60028481 缸盖罩(Cover GP, Valve Mechanism)
60028496 四配套(Kits, Piston & Rod)
60028488 气缸总成(Cylinder Block GP)
60028487 气缸盖总成(Cylinder Head GP)
60028464 柴油机主体(Engine body, diesel)
60028476 油底壳及过滤器(Pan GP & Filter, Engine Oil)
60028478 飞轮组件(Flywheel GP)
60028489 曲轴活塞组(Crankshaft & Piston GP)
60028497 凸轮轴与气门(Camshaft & Valve Mechanism)
60028472 正时齿轮(Gear, timing)
60028473 机油泵及过滤器(Oil Pump & Filter)
60028469 油冷却器(Cooler GP, Engine Oil)
60028483 机油管路(Lines GP, Engine Oil)
60028468 喷油泵(Pump GP, Fuel Injection)
60028486 喷油管及喷油器(Tube, Injection & Injector)
60028491 燃油回油管(Lines, Return (Fuel))
60028494 水泵及风扇(Pump, Water & Fan)
60028495 水管及节温器(Pipe, Water & Thermostat)
60028484 进气管(Pipe, air inlet)
60028500 排气管(Manifold GP, Exhaust)
60028467 涡轮增压器(Turbocharger)
60028471 起动电机(Starting Motor)
60028470 发电机(Alternator)
60028498 油泵座(Base, Pump, Fuel Injection)
60028474 机油滤清器(Filter, Oil)
60028492 燃油滤器及油管(Filter, Fuel & Tube)
60028475 空滤器(Air Cleaner)
12441061 配重总成(Counterweight GP)
第3章 行走装置(Travel device)
12390338 行走装置(Travel device)
10398371 密封组件(Seal AS)
A229900008843 引导轮(Idler)
A229900006383 张紧装置(Tensioner)
12168856 托链轮总成(Roller As, carrier)
B229900000149 减速机总成(Reducer GP)
60181097 液压马达(HYDRAULIC MOTOR ASSEMBLY)
60181096 减速机(REDUCTION GEAR)
10999958 支重轮总成(Roller AS, track)
A229900001758 回转接头(Joint, swivel)
第4章 工作装置(Work equipment)
12391212 工作装置(Work equipment)
12391134 工作装置液压管路(Work device TubeSY215C9M2K(SKD)31C)
60011369 铲斗油缸(Cylinder, bucket)
60011373 斗杆油缸(Cylinder, arm)
11347703 动臂油缸总成(Cylinder AS, boom)
11777805 工作装置润滑管路(Pipeline, greasing, work equipment)
第5章 电气系统(Electrical system)
12398043 电气系统(Electrical system)
第6章 涂装(Painting)
12378882 涂装(Painting)
第7章 随机附件(Accessory)
11557250 随机附件(Accessory)
10442741 随机工具(Tool, attached)
A229900007607 万向接头(Joint, universal)
A290000000155 手提工具箱(Toolbox, portable)
第8章 其他配置(Other Fittings)
11436729 铲斗(Bucket)
