Martin Welker
104
230,310
Sany Hydraulic Excavator SY215C9M2K Part Book 10SY0216C0778
Language: English, Chinese
Brand: Sany
Type of Manual: Part Manual
Model: Sany SY215C9M2K Hydraulic Excavator
Part Number: 10SY0216C0778
Number of Pages: 328 Pages
第1章 SY215C9液压挖掘机(Hydraulic Excavator)
10669503 SY215C9液压挖掘机(Hydraulic Excavator)
第2章 回转装置(Slewing device)
10675356 回转装置(Slewing device)
11543882 先导管路(Pipeline AS, pilot)
11543868 PPC管路(Pipeline AS, PPC)
B220401001302 手动先导阀(Valve, pilot, manual)
60004101 脚踏阀(Valve, foot)
11543879 电磁阀管路(Pipeline AS, solenoid valve)
11543876 主阀管路(Pipeline AS, main valve)
11543874 主泵管路(Pipeline, main pump)
11239284 驾驶室(Cab)
10684525 遮阳罩总成(Visor AS)
11237129 座椅及操纵箱(Seat and control console AS)
11239270 底板架(Support, bottom plate)
10898021 行走操纵机构(Lever, travel)
10473822 回转支承总成(Bearing AS, swing)
11383751 液压主管路(Pipeline, main, hydraulic)
B229900003821 减速机总成(Reducer GP)
A810201010243 液压油箱总成(Tank GP, hydraulic)
11566113 空调系统(Air conditioning system)
10473304 空调电气系统(Electrical system, air conditioner)
11556103 覆盖件总装(Cover GP)
A810502990126 装饰盖(Cover, ornament)
A810502010196 右门总成(Door GP, right)
A810502017020 电瓶箱总成(Box GP, battery)
A810502012314 柴油机左隔板(Partition, left, engine)
10680137 左上后盖板(Coverplate, rear, upper left)
A810502019117 连接板(Board, connecting)
A810599000260 扶手(Handhold)
A810502015338 托架(Bracket)
A810502010371 左门总成(Door GP)
11120781 机顶罩总成(Engine hood GP)
11120051 机顶罩主体(Cover, engine hood)
11504969 空滤隔板(Partition, air cleaner)
A810502010655 柴油机右隔板(Plate)
10139935 动力系统(Power system)
A810102060152 减震及传动系统(Damping & drive system)
A810102070274 排气系统(Exhaust system)
A810102090182 冷却系统(Cooling system)
A810102070275 进气系统(Air inlet system)
A810102020228 燃油系统(Fuel System)
10667238 燃油箱总成(Tank GP, fuel)
11469942 油门控制系统(Control system, throttle)
60028482 缸体(Cylinder Block AS)
60028480 缸盖(Cylinder Head AS)
60028481 缸盖罩(Cover GP, Valve Mechanism)
60028490 曲轴总成(Crankshaft AS)
60028496 四配套(Kits, Piston & Rod)
60028488 气缸总成(Cylinder Block GP)
60028487 气缸盖总成(Cylinder Head GP)
60028464 柴油机主体(Engine body, diesel)
60028476 油底壳及过滤器(Pan GP & Filter, Engine Oil)
60028478 飞轮组件(Flywheel GP)
60028489 曲轴活塞组(Crankshaft & Piston GP)
60028497 凸轮轴与气门(Camshaft & Valve Mechanism)
60028472 正时齿轮(Gear, timing)
60028479 附件(Accessories)
60028463 柴油机安装(Diesel Engine MTG)
60028473 机油泵及过滤器(Oil Pump & Filter)
60028474 机油滤清器(Filter, Oil)
60028469 油冷却器(Cooler GP, Engine Oil)
60028483 机油管路(Lines GP, Engine Oil)
60028477 油水分离器(Separator, water & fuel)
60028492 燃油滤器及油管(Filter, Fuel & Tube)
60028468 喷油泵(Pump GP, Fuel Injection)
60028486 喷油管及喷油器(Tube, Injection & Injector)
60028491 燃油回油管(Lines, Return (Fuel))
60028465 散热器(Radiator)
60028493 散热器水管(Hose, Water (Radiator))
60028494 水泵及风扇(Pump, Water & Fan)
60028495 水管及节温器(Pipe, Water & Thermostat)
60028475 空滤器(Air Cleaner)
60028499 中冷器(Intercooler)
60028484 进气管(Pipe, air inlet)
60028500 排气管(Manifold GP, Exhaust)
60028467 涡轮增压器(Turbocharger)
60028485 排气管路(Lines GP, Exhaust)
60028466 消声器(Muffler)
60028471 起动电机(Starting Motor)
60028470 发电机(Alternator)
60028498 油泵座(Base, Pump, Fuel Injection)
60028503 电源开关(Switch, Power Supply)
60028501 保险丝及继电器(Fuse & Relay)
60028502 电线护套(Sleeve, Wire)
第3章 行走装置(Travel device)
11507574 行走装置(Travel device)
10398371 密封组件(Shield, grease)
B220501000267 减速机总成(Motor, travel)
A229900001758 回转接头(Joint, swivel)
第4章 工作装置(Work equipment)
11446501 工作装置(Work equipment)
11552513 工作装置液压管路(Pipeline, hydraulic, work equipment AS)
11450130 工作装置润滑管路(Pipeline, lubricating, work equipment AS)
10143975 齿销(Pin, bucket teeth)
第5章 电气系统(Electrical system)
10680160 电气系统(Electrical system)
第6章 涂装(Painting)
10680411 涂装(Painting)
第7章 其他配置(Other Fittings)
11347703 动臂油缸总成(Cylinder AS, boom)
11350816 斗杆油缸(Cylinder, arm)
11350784 铲斗油缸总成(Cylinder GP, bucket)
