Hyundai
86
176,834
Sany Excavator SY215CA14K Shop Manual B06T03ENAN1-SY215CA14K
Brand: Sany
Type of Machine: Excavator
Type of Manual: Shop Manual, Electric and Hydraulic Diagrams
Model: Sany SY215CA14K Excavator
Documentation Number: B06T03ENAN1-SY215CA14K
Publication Date: 2014
Number of Pages: 655 Pages
1 Introduction
1.1 How to Read the Shop Manual​
1.2 Technical Terms for Maintenance Standard​
1.3 Handling Electrical or Hydraulic Components​
1.4 Hose Joint​
1.5 Standard Tightening Torque Table​
1.6 Type of Bolts​
1.7 Tightening Sequence​
1.8 Maintenance of Split Flanges​
1.9 Conversion Tables​
2 Shop Safety
2.1 Hazard Alert Information​
2.2 General Shop Safety​
2.3 Before Repair​
2.4 Repair Precautions​
2.5 Other Precautions​
3 Specifications
3.1 Dimensions​
3.2 Working Ranges​
3.3 Technical Specifications​
3.4 Weight Table​
3.5 Engine oil, fuel and coolant​
3.6 Engine Performance Curve​
4 Structure and Functions
4.1 Engine and Cooling System​
4.2 Power Train​
4.3 Undercarriage​
4.4 Hydraulic System (Part I)​
4.5 Hydraulic System (Part II)​
4.6 Hydraulic System (Part III)​
4.7 Work Equipment​
4.8 Air Conditioning System​
4.9 Engine Control​
4.10 Electrical Control System​
4.11 Monitoring System​
5 Table of Standard Values
5.1 Standard Values for Engine-related Parts​
5.2 Standard Values for Chassis-related Parts​
5.3 Machine Attitudes for Measuring Performance and Procedures​
6 Testing and Adjusting
6.1 Exhaust Gas Color - Test​
6.2 Valve Clearance - Adjust​
6.3 Compression Pressure - Measure​
6.4 Fuel Injection Timing - Test and Adjust​
6.5 Engine Oil Pressure - Check​
6.6 Engine Speed Sensor - Adjust​
6.7 A/C Compressor Belt Tension - Test and Adjust​
6.8 Swing Bearing Clearance - Measure​
6.9 Track Tensioning Device - Test and Adjust​
6.10 Pressure in Hydraulic Lines - Test and Adjust​
6.11 Control Circuit Oil Pressure - Test and Adjust​
6.12 Solenoid Valve Output Pressure - Measure​
6.13 Pilot Valve Output Pressure - Measure​
6.14 Pilot Valves (Work Equipment and Swing) - Adjust​
6.15 Work Equipment Hydraulic Drift - Check​
6.16 Residual Pressure in Hydraulic Circuit - Release​
6.17 Oil Leakage - Measure​
6.18 Air in Each Component - Bleed​
7 Troubleshooting
7.1 Troubleshooting Precautions​
7.2 Checks Before Troubleshooting​
7.3 Troubleshooting Types and Steps​
7.4 Failure symptoms and troubleshooting numbers​
7.5 Troubleshooting the Electrical System​
7.6 Troubleshooting with an Event Code​
7.7 Troubleshooting the Electrical System (E-Mode)​
7.8 Troubleshooting the Hydraulic and Mechanical Systems (H-Mode)​
8 Disassembly and Assembly
8.1 How to Read This Manual​
8.2 Operating Precautions​
8.3 Start Motor AS - Remove and Install​
8.4 Injection Pump AS - Remove and Install​
8.5 Engine Front Oil Seal - Remove and Install​
8.6 Engine Rear Oil Seal - Remove and Install​
8.7 Cylinder Head AS - Remove and Install​
8.8 Radiator AS - Remove and Install​
8.9 Engine and Hydraulic Pump AS - Remove and Install​
8.10 Final Drive AS - Remove and Install​
8.11 Final Drive AS - Disassemble and Assemble​
8.12 Swing Motor and Swing Drive AS - Remove and Install​
8.13 Swing Motor and Swing Drive AS - Disassemble and Assemble​
8.14 Idler AS - Disassemble and Assemble​
8.15 Sprocket - Remove and Install​
8.16 Track AS - Remove and Install​
8.17 Swing Bearing AS - Remove and Install​
8.18 Swing Platform AS - Remove and Install​
8.19 Swivel Joint AS - Remove and Install​
8.20 Swivel Joint AS - Disassemble and Assemble​
8.21 Hydraulic Tank AS - Remove and Install​
8.22 Control Valve AS - Remove and Install​
8.23 Hydraulic Pump AS - Remove and Install​
8.24 Middle Oil Seal (Hydraulic Pump Input Shaft)- Remove and Install​
8.25 Pilot Valve AS (Work Equipment) - Disassemble and Assemble​
8.26 Pilot Valve AS (Travel) - Disassemble and Assemble​
8.27 Hydraulic Cylinder AS - Disassemble and Assemble​
8.28 Work Equipment AS - Remove and Install​
8.29 Air Conditioner AS - Remove and Install​
8.30 Counterweight AS - Remove and Install​
8.31 Cab AS - Remove and Install​
8.32 Cab Window Glass – Disassemble and Assemble​
8.33 Front Window AS - Disassemble and Assemble​
8.34 Monitor - Remove and Install​
8.35 Controller AS - Remove and Install​
8.36 Radio​
8.37 Battery​
8.38 Start Switch​
8.39 Fuse Box​
8.40 Wiper​
8.41 Relay​
8.42 Sensor​
8.43 Connector Terminals - Insert and Remove​
9 System Schematics
9.1 Hydraulic System​
9.2 Air-Conditioning System​
9.3 Monitoring system​
9.4 Control switches​
9.5 Operator station​
9.6 Chassis Diagram​
