Sany Excavator SY215C LC SY225C LC Operation and Maintenance Manual SSY004846200
Brand: Sany
Type of Machine: Excavator
Type of Manual: Operation and Maintenance Manual
Model: Sany SY215C LC, SY225C LC Excavator
Part Number: SSY004846200
Number of Pages: 272 Pages
Introduction
Brand: Sany
Introduction
About This Manual
Documentation Package
Parts Manual
Maintenance Log
Organization of This Manual
Table of Contents
Introduction
Safety
Machine Controls
Machine Operation
Maintenance
Specifications
Optional Equipment
Machine Applications
Machine Directions
Serial Number Location
Product Identification Plate
SANY Contact Information
Record of Serial Number and Dealer Information
Correction Request Form
Glossary of Acronyms
SafetyGeneral Safety
Hazard Alerts in This Manual
Machine Decals
Operator Safety Information
Mount and Dismount the Machine
Machine Safety
Authorized Use of This Machine
Unauthorized Use of This Machine
Unauthorized Machine Modifications
Escape Tool
Fire Safety
Electrical Fires
Fire Extinguisher
In Case of Fire
Crushing Hazard
Diesel Engine Exhaust
Maintenance Safety
Lockout/Tagout Procedure
Cleaning the Machine
Fluid Systems
Job Safety
Personal Protective Equipment (PPE)
Hearing Protection
Travel and Operation Precautions
Avoid Backover Accidents
Dust and Chemical Hazards
Environmental Precautions
Precautions in High-Voltage Areas
Machine ControlsExterior Components
Cab Interior
Machine Controls
Seat and Seat Belt
Hydraulic Lockout Control Lever
Emergency Stop Switch
Left Control Console
Right Control Console
Joystick Controls
Travel Control Levers/Pedals
Batteries
24V Power Supply Socket
Battery Disconnect Switch
Fuses
Monitor
Home Screen
Main Menu Screen
Work Parameters Screens
Maintenance Info Screen
Error Codes Screen
System Setting Menu Screen
Machine Configuration Screen
Tool Select Screen
Machine OperationWork Area
General Job Safety
Operator Responsibilities
Seat Belt Usage
Operation and Maintenance Manual Check
Daily Maintenance Record Check
Cleaning the Machine Exterior
Cleaning the Cab Interior
Prestart Checks and Adjustments
Mirror Adjustment
Check Fluid Levels
Engine Coolant Level
Engine Oil Level
Fuel Level
Diesel Exhaust Fluid (DEF) Level
Primary Fuel Filter/Water Separator
Hydraulic Oil Level
Windshield Washer Fluid
Electrical Component Checks
Starting the Engine
Cold Weather Starting
Warm-up Operation
Idling the Engine
Jump-Start the Engine
New Machine Break-in
Engine Shutdown Procedure
Inspection After Engine Shutdown
Travel Operations
Machine Moving Precautions
Stopping the Machine
Forward Travel
Backward Travel
Right Turn
Left Turn
Spot Turning
Incline
Work Equipment Controls
Pattern Change (SAE/BHL) Valve Operation
Swing – SAE/BHL Mode
Arm – SAE Mode
Arm – BHL Mode
Boom – SAE Mode
Boom – BHL Mode
Bucket – SAE/BHL Mode
Restricted Operation
Never Operate with Bucket Force
Never Use Swing Force.
Never Use Traveling Force.
Never Operate Using Machine Weight.
Do Not Operate a Cylinder to the Stroke End
Avoid Dozer Blade Impact
Support Dozer Blade
Avoid Shifting Travel Direction Suddenly
Excavating Hard Ground
General Travel Instructions
Operations in Water
Precautions When Driving on an Incline
Engine Stalls on an Incline
Operating on Soft Ground
Removing a Stuck Machine
Towing the Machine
Towing Hole for a Light Load.
Recommended Operations
Backhoe Operation
Digging a Trench
Vehicle Loading
Leveling Operation
Operating Precautions
Cold Weather Operation
Engine Coolant in Cold Weather
Battery in Cold Weather
Track Cleaning in Cold Weather
After the Cold Season
Machine Storage in Cold Weather
After Daily Operation
Park and Store the Machine
Overnight Storage
End-of-Workday Checks
Short-Term Storage
Long-Term Storage
During Storage
Return to Service
Starting the Engine After Long-Term Storage
Transportation Information
Transportation Method
Loading and Unloading
Lifting the Machine
MaintenanceMaintenance Information
Checks Before Maintenance or Repairs
Checks After Maintenance or Repairs
Hour Meter Reading
Genuine SANY Replacement Parts
SANY-Approved Lubricants
Oil and Filter Inspection
Collect Oil Sample
Fuel Tank Strainer
Preventing Contamination
Installation of Hydraulic Hoses
Securing Access Covers and Compartment Doors
Weld, Drill, Cut, or Grind on the Machine
Inspection and Maintenance in Adverse Environments
Check the Maintenance Log
Daily Inspection and Maintenance
Recommended Lubricants, Fuel, and Engine Coolant
Hydraulic Oil Description
Lubrication and Grease
Fuel
Engine Coolant
Engine Oil Viscosity/Temperature Data
Lubricating Grease/Temperature Data
Industrial Gear Oil/Temperature Data
Hydraulic Oil/Temperature Data
Capacities
Other Approved Products
Maintenance Schedule
Secure the Machine for Maintenance
When Required
Daily or 10 Hours
After the First 50 Hours
Weekly or 50 Hours
Monthly or 250 Hours
3 Months or 500 Hours
6 Months or 1000 Hours
Annually or 2000 Hours
Hydraulic Breaker Maintenance Interval
After Maintenance is Completed
Lubrication Chart
Maintenance Procedures
Relieve Hydraulic System Pressure
Check Accumulator Function
Check the Aftertreatment Exhaust Piping
Check the Air Conditioning Operation
Check and Adjust the Air Conditioner Compressor Belt
Check the Air Conditioner Fresh-Air and Recirculation Filters
Check the Air Intake and Charge Air Pipes
Check the Backup Camera
Check the Batteries
Replace the Batteries
Replace the Bucket
Check Doors and Locks
Check the Crankcase Breather Tube
Replace the Crankcase Ventilation Filter
Check the Decals
Replace the Diesel Exhaust Fluid (DEF) Pump Filter
Check the Diesel Exhaust Fluid (DEF) Level
Fill the Diesel Exhaust Fluid (DEF) Tank
Replace the Diesel Exhaust Fluid (DEF) Tank Filter
Check the Electrical System
Replace the Engine Air Filter
Check the Engine Air Filter System
Check the Engine Belts
Change the Engine Coolant
Check the Engine Coolant Level
Check the Engine Oil Level
Change the Engine Oil and Filter.
Check the Final Drive
Check the Final Drive Oil Level
Change the Final Drive Oil
Check the Fire Extinguisher
Check the Escape Tool
Check the Front Window Locks
Check the Fuel Level
Check the Fuel Lines
Drain the Fuel Tank
Fill the Fuel Tank
Check the Fuel Tank Strainer
Check the Grab Handles and Steps
Check the Hydraulic Hoses and Lines
Add Hydraulic Oil
Change the Hydraulic Oil
Replace the Hydraulic Pilot Filter Element
Check the Hydraulic Pump
Replace the Hydraulic System Breather Filter
Check the Hydraulic Oil Tank Level
Replace the Hydraulic Tank Return Filter
Check the Idler.
Adjust the Mirrors
Collect Oil Samples
Check Operating Functions
Check the Operator Controls
Check the Pattern Change (SAE/BHL) Valve
Replace the Primary and Secondary Fuel Filter
Drain the Primary Fuel Filter
Check the Hydraulic Pump Mounting Fasteners
Check the Radiator, Oil Cooler, and Air Conditioner Condenser
Check the Seat Belt
Check the Sheet Metal
Check the Stationary Regeneration
Perform a Structural Inspection
Lubricate the Swing Drive Bearing
Check the Swing Bearing Fasteners
Check the Swing Drive
Check the Swing Drive Fasteners
Change the Swing Drive Oil
Check the Swing Grease Bath Level
Check the Carrier Roller Fasteners
Check the Track Assemblies
Check the Track Fasteners
Check and Adjust Track Tension
Clean and Check the Upper Structure and Undercarriage
Bucket
Check the Windshield Washer Fluid and Windshield Wiper
Lubricate the Work Equipment
Machine Storage
SpecificationsMachine Dimensions – SY215C LC
Operating Ranges – SY215C LC
Lift Chart Standard Arm – SY215C LC
Technical Specifications – SY215C LC
Machine Dimensions – SY225C LC
Operating Ranges – SY225C LC
Lift Chart Standard Arm – SY225C LC
Technical Specifications– SY225C LC
Optional EquipmentOptional Equipment Safety
Optional Equipment Selection
Read Equipment Instructions
Removal and Installation Precautions
Optional Equipment Operation Precautions
Optional Equipment Control
Equipment Control Elements
Attach Optional Equipment
Disconnect Optional Equipment
- Sany Container Reach Stacker RSC45C2 Operation & Maintenance Manual
- SANY Hydraulic Crawler Crane SCC500E COMPLETE MANUAL
- Sany Hydraulic Excavator SY215C9M2K Parts Book
- Sany Container Reach Stacker Safety, Operation & Maintenance Manual
- Sany Body Container Reach Stacker SRSC45C2 Parts Book
- Sany SY205-215C9M2K Electrical Schematics
- SANY Crawler Hydraulic Excavator SY215C Shop Manual
- Sany SY65C-SY135C-8 Electric Hydraulic Schematics
- Sany SCC500E-R1 Crawler Crane Assembly Part Book
- SANY SCC8500 500-ton crawler crane offers multiple configurations
- SANY SY230C8E Electrical Schematics
- Sany QY50C Truck Crane Parts Book
- Earthdrill SANY SR220C hydraulic diaphram
- Sany SY200C1-Electrical Schematics
- Sany SY230C6B-1 Electrical Schematics
