Rexroth Axial Piston Variable Pump A4VG Series 40 Repair Manual
Brand: Rexroth
Type of Machine: Axial Piston Variable Pump
Type of Manual: Repair Manual
Model: Rexroth A4VG Series 40 Axial Piston Variable Pump
Publication Date: 2011
Number of Pages: 60 Pages
1 Repair manual Axial Piston Variable Pump A4VG
11 Settings
Brand: Rexroth
1.1 Related documents
1.2 Abbreviations used
2 General safety instructions2.1 Intended use
2.2 Improper use
2.3 Personnel qualifications
2.4 Safety instructions in this manual
2.5 Adhere to the following instructions
2.6 Operator's obligations
3 Product description3.1 Name plate
3.2 Functional description
3.3 Technical data
4 Controller4.1 Removing controller
4.2 Sealing controller
4.3 Installing the controller
4.4 Setting controller (hydraulic neutral position)
5 Internal gear pump5.1 Remove internal gear pump cover
5.1.1 Exchange internal gear pump5.2 Seal/install internal gear pump cover
6 Shaft seal6.1 Exchange shaft seal
7 Valves7.1 Seal/replace the high pressure relief valve
7.2 Seal/replace low pressure relief valve
7.3 Seal/replace pressure cut-off
7.3.1 Set pressure cut-off7.4 Seal control cartridge
7.4.1 Set beginning of control7.5 Seal shuttle valve
7.6 Exchange angle position sensor
8 Filter8.1 Mountable filter
8.2 Seal/replace filter head
9 Threaded plugs9.1 Seal/replace threaded plugs
10 Pump case/rotary group/stroke piston10.1 Pump case
10.2 Demount rotary group
10.3 Demount swashplate
10.4 Replace sensor shaft
10.5 Replacing/installing swashplate
10.6 Removing drive shaft with bearing
10.7 Replacing/installing drive shaft with bearing
10.8 Replacing/installing rotary group
10.9 Sealing cover on stroke piston
10.10 Sealing stroke piston
10.11 Installing stroke piston
10.11.1 Mechanical neutral position10.12 Checking orifices X1 and X2
10.13 Sealing threaded plug (cold start valve)
10.14 Sealing timing screw
10.14.1 Initial setting timing screw11 Settings
11.1 Low pressure
11.2 High pressure
11.3 Tightening torques
- Ingersoll Rand SD-100 Schematic, Repair & Troubleshooting Manual 2022
- Kalmar Reach Stackers 40-45T DRF 400-450 Maintenance Manual
- Parts catalog Isuzu 3LA1, 3LB1, 3LD1
- Hamm 3516, 3518 ,3520 ,3516 P, 3518 P ,3520 P Spare parts List
- HATZ Diesel 2W35,3W35,3W35T,4W35,4W35T Workshop Manual
- Schwing Service Training - Training Manual
- HBM Motor Grader NOBAS BG160T-4
- Yuchai Diesel Engine YC4D Parts Catalog
- ZF – ERGOPOWER TRANSMISSION 4 WG-190/210 Service
- PALFINGER PK4501 PK5001 Hydraulic Crane Spare Parts List
- Tamrock Ranger 700-2 Operator and Maintenance Manual
- XGMA XG 955II Wheel Loader Parts Catalog
- MF 50H, MF 50HX, MF 60HX Turbo Operator Manual
- VOITH Retarder 115 Actors After Sales Service Manual
- O&K RH23.5 Crawler Excavator Hydraulics Schematics and Spare Parts Catalogue
