Renault CAN CLIP V151 Lastest Ver + Patch + Instruction
- Download this document, you need 1000 Gallons
CAN Clip V151 for Renault Diagnostic Tool
Renault CAN Clip Language: Spanish,French,Italian,Portuguese,English,German,Denish,Finnish,Norwegian,Dutch,Romania,Swedish
CAN Clip for Renault is the newest V151 version
CAN Clip Function including automatic test all computers, reprogramming, airbag test and other functions
Multi-language like Spanish,French,Italian,Portuguese,English,German and so on
This is the cheap and good quality version
Can clip for Renault Functions:
1. See all the information relating to the vehicle
2. Computer test
3. Automatic test of all computers
4. Airbag test
5. Ccantool (OBD tests)
6. Base Doc (access to Technical Notes)
7. Physical measurements
8. Antipollution
9. Multimeter
It's very simple to diagnose a vehicle using Renault CAN Clip Diagnostic Interface: just select the vehicle make, enter the V.I.N. and press ENTER.
Instruction:
1. After Instalaltion finish DO NOT run your CLiP!
1st replace the original RSWin.exe file (backup 1st your original file!!!)
with the Cracked .exe file in C:\CLIP_X91\Lib\Application\
2. Now from the SAME location as you are (C:\CLIP_X91\Lib\Application\) run the RSWin.exe,
choose "Register me now" and in the next window select "NO"!
3. Use this Key for Registration: 333DEF-111DEF-111DEF-222DEF-221DEF-000DEF
It will work till 31/12/2020
4. Now as you are, RESTORE your original RSWin.exe and REMOVE the patched one!
(Just keep a backup from the patched file somewhere...)
5. From your Desktop anymore, run your CLiP, accept the Terms and CLiP it will load.
You Done!
SPECIAL NOTES:
Maybe when you try to make your 1st REAL Diagnosis you received an "Error" (about CLiP Damaged...)
try to Update your PC with ALL the Latest Windows Updates! IF again the SAME "Error"
then use 1x other PC or Roll-Back to Version V116! CLiP it seems, she no likes some PC's!
Also when you will make your Registration, try to have your PC On-Line to the Internet!
IF you NOT able to use 1x other PC and you insist to use this Latest Release,
then you can post your S/N and you will got your personal Registartion Key.
For this workaround you will need to use your ORIGINAL RSRWin.exe and also 1st of all to
DELETE these 2x files: "reg.xml" & "ntuser.dat" from your:
C:\Documents and Settings\All Users (Windows XP)
C:\ProgramData (Windows 7 32Bit)
NOTE: BEFORE to delete your reg.xml file, open it & note somewhere your COMPLETE S/N!
Enjoy & Good Clipping!
2. Computer test
4. Airbag test
8. Antipollution
9. Multimeter
Instruction:
You Done!
SPECIAL NOTES:
- Renault DDT2000 v2.9.0.8 Full + Instruction
- Renault Dialogys v4.49 [04.2016] Full Spare Parts and Manuals
- Renault Dialogys v4.59 [01.2017] Full Spare Parts and Manuals
- Renault DDT2000 Diagnostic Tool v3.0.0.3 + DATABASE [04.2017]
- Renault Wiring Diagrams [1998-2014] All Model Full DVD
- Renault Dialogys v4.65 [07.2017] Full Spare Parts and Manuals
- Renault Dialogys v4.78 [09.2018] Full Spare Parts and Manuals
- Renault CAN Clip v154 [12.2015] + Patch + Instruction
- Renault Dialogys v4.72 [03.2018] Full Spare Parts and Manuals
- Renault CAN Clip v153 [11.2015] + Patch + Instruction
- Renault Dialogys v4.52 [07.2016] Full Spare Parts and Manuals
- Renault Dialogys v4.56 [09.2016] Full Spare Parts and Manuals
- Renault Clip Tool v2.6 [ALL IN ONE]
- Renault CAN CLiP v172 [11.2017] Full Patch + Instruction
- Renault Dialogys 4.47 FR [2016] Full
