Remote install - Jaguar Land Rover JLR Pathfinder, SDD, EPC, Microcat, CCF Editor
motorstate
83
105
Remote install - Jaguar Land Rover JLR Pathfinder, SDD, EPC, Microcat, CCF Editor, Service Manual, Wiring Diagrams
JLR Pathfinder (with online updates) - $155
Pathfinder is the all-new diagnostic system specifically designed and released for the introduction of the following vehicles.
Land Rover: Range Rover L405 (17MY), Range Rover Sport L494 (17MY), New Discovery L462 (17MY)
Jaguar: F-TYPE X152 (18MY), F-PACE X761 (18MY), XE X760 (18MY), XF X260 (18MY)
These vehicles have been designed to communicate with new high-speed communication protocols. This allows faster software download, programming, and communication, making it faster to use and saving valuable time. These vehicles can only communicate with the all-new Pathfinder diagnostic software using the new Diagnostics over Internet Protocol (DoIP) Vehicle Communication Interface (VCI) unit which conforms to the new communication protocol.
Jaguar Land Rover JLR IDS SDD (with calibrations files) - $85
(without calibrations files) - $45
Configure drivers JLR SDD
for VAS5054, VAS6154, Ford VCM - $20
The official software for the diagnosis and repair of cars Jaguar, Land Rover. Symptom Driven Diagnostics (SDD) doesn't have the functionality to communicate with these 2017 model year vehicles.
JLR SDD Coded Access Password with 2000 Times Online Activation - $135
JLR SDD Coded Access Password with 100 Times Online Activation - $65
It works for:
1. For Jaguar:
CCF Editor
ODO APP (X150)
ODO APP (X250)
ODO APP (X351)
Software Download
VID Block Editor
VIN Bypass
Recover Keys (X351)
2. For Land Rover:
CCF Editor
ODO APP (L316))
Erase Keys (L322)
ODO APP (L322)
Recover Keys (L322)
Option 8
Software Download
Vehicle Update (Only Taiwan Models)
Jaguar EPC 2018 - $59
Spare parts catalog that contains for the legendary English Jaguar brands: Daimler Limousine Jaguar S-Type Jaguar X-Type Jaguar XJ6 & XJ12 (XJ40) Jaguar XK8 Coupe / Conv. Series III Saloon The New XJ Range XJ Series XJS Sports Coupe / Conv.
Land Rover Microcat 2014 - $35
The Land Rover Microcat auto parts catalog contains spare parts information for the legendary Land Rover and Range Rover brands that once belonged to the Rover Group.
JLR CCF Editor 9.27 - $295
CCF editor is a program for working with JLR calibration VBF files. It's for all Jaguar Land Rover from 2006 to 2024.
JLR CCF Editor Pro - $565
CCF Editor Pro performs all of the functions of CCF Editor plus using an Enet cable to connect to MY2017+ DoIP vehicles and a JLR 2534 passthru to connect to non-DoIP vehicles to be able to read and write the CCF directly.
Currently Topix and Pathfinder is needed to process ECUs after loading the CCF to the vehicle.
JLR CCF Tools 4.9 - $259
For Pathfinder, SDD from 2017 to 2023.
Functions:
  • Read VBF, search by keyword
  • Parameters set and save
  • EEPROM data
  • Compare VBF files
  • Self-made click-and-play coding scripts
  • VBF download and export by VIN
JLR CCF Tools 4.6 (for Pathfinder, SDD) - $75
The CCF tools is standalone applications that can be used in conjunction with SDD or Pathfinder software. There is an option to copy downloaded and edited files to relevant folders for SDD and Pathfinder, for Pathfinder you should use upload and let Pathfinder download them on its own.
This application allows downloading the vehicle’s CCF by VIN as built and as well as configuration files for all SDD and Pathfinder approved vehicle models. Then edit the entire vehicle configuration file for all Jaguar Land Rover vehicles, all vehicles using SDD software or Pathfinder.
The application supports SOAP-encoded VBF* files that sometimes emerge from the JLR. CCFs of similar generations can be compared using the improved compare function, which now allows the opening of ZIP files containing CCF.
CCF Tools 4.6 Features
  • read VBF, search by keyword
  • read header
  • compare VBF files
  • Translation, Efg Common Code
JLR TOPIx online Dealer account 1 year - $1099
JLR TOPIx online Dealer account 1 month - $449
JLR TOPIx online Dealer account 1 day - $115
For diagnostic and codig for cars after 2021. Because Pathfinder doesn't work with them.
How it works: I'll install tiny software by Teamviewer then icon on your desktop, just run it to access and use the service without username or password.
It works only with original JLR DoIP VCI, Cardaq 3+ and DA-DoIP VCI.
Needs Win 10 or 11 x64 and 10 Gb free on main drive C:/
Land Rover 2002-2019 Full Service Manual, Wiring Diagrams - $355
Land Rover 2002-2018 Full Service Manual, Wiring Diagrams - $249
For what cars:
Ranger Rover Landrover, Defender Discovery, Ranger Rover Sport, Freelander, Evogue, Velar
Type of document: Workshop Manual, Wiring Diagram, Body Dimension, Technical Library
Jaguar XE 2017 Workshop Manual & Electrical Wiring Diagrams - $115
Land Rover, Jaguar 1986-2015 Electrical Guides - $55
What inside:
Electrical Guides, Technical Guides, Vehicle Specification Books, Wire Repair
JLR Code Access Password Generator (unlimited token) - $85
Functions:
CCF Editor - Retrofit configuration coding
Odometer
Vehicle Programming
Programming upgrade/downdgrade
Recover Keys - restore/delete
Defender 8 Option
VIN Bypass
VID Block Eitor
Software download.
JLR Pathfinder + SDD PDF Book tricks and secrets (key learn, ccf editor retrofit and programming) - $249
It consist of 318 pages.
1. Device Selection: Davina3/JLR-VCI
2. En
3. SDD engineering mode entry (Enter the seed password to enter the engineering mode; Need code calculation)
4. Enter the seed password to enter the engineering mode
5. Enter the SDD engineering mode (run the current vehicle configuration adjustment in the maintenance function for CCF configuration; CCF change only some options can be changed( non-engineering mode options are grayed out ); CCF change engineering mode can change all options)
6. Engineering mode-programming software download mode
7. Mileage adjustment recovery mode
8. Traditional IDS use in engineer mode
9. SDD code calculator introduces common functions
10. CCF-EDITOR modified vehicle configuration
11. SOFTWARE-DOWNLOAD programming (download software)
12. ODO Replace with a new device to adjust the distance
13. Summary There are a total of five SDD . engineering modes
14. Use Pathfinder System (Main Interface; login interface; to read fault code select ECU diagnosis; Clear reading fault code Click all DTC; Read data stream Enter real-time data; Read data stream Select the item that needs to read data; to replace new module programming-select the module that need to be programed)
15. Pathfinder System ECU function
16. Select the module to be programmed For example (RFA keyless module Click RFA; click to replace ECU and follow the system prompts)
17. Follow the system prompts and click Next to continue programming to completion
18. Use the Pathfinder System to update the software of the control module-select the example diagram of the module the needs to be upgraded
19. Upgraded the software of the control module, such as the IPC instrument control module. Click Update ECU and follow the prompts to completion
20. CCF edit-using with pathfinder and SDD to edit configuration
21. Use Pathfinder to change vehicle configuration (Find the VBF file and configuration; Vehicle configuration opened; pathfinder software steps)
22. How to use pathfinder to change vehicle configuration
23. L494 pointer meter changed to LCD meter 2017 new
24. After vehicle communication, enter the main interface and select ECU diagnosis
25. Click ECU diagnosis
26. Configuration progress 1,2,3
27. Completed (If you install a video cable, please contact ú to change the full-screen map)
28. Use Pathfinder keyless entry to modify, select ECU diagnosis
29. Select the keyless entry module RFA
30. Choose to replace ECU
31. 17 additional electric pedal programming Click Next and follow the prompts to complete
32. SSD engineering mode brush hide
- Miles to kilometers and brake lights
- Localization of instrument and display
- Exclusive dashboard for SVR and HST instruments
- Carbon fiber meter skin
- Radio single frequency to multi-frequency function
- Glass remote control window lift function
- Unlimited fog lights
- LG/LW RS mode (dynamic mode)
33. Original equipment solution
Language\emissions\power
- Solve the LG/LW DPF fine particle filter; LG/LW SCR urea
- LG/LW 3.0 mechanical booster to increase power
- LR4/RRS with display pointer instrument finished
- Replacement of used ABS module and RCM
- The old and new fuel evaporation system problems
34. Use original equipment to restore high-end vehicle configuration
- Restore the keyless entry function; ACC function; 825 audio function; 494/405 electric suction door function; the function of the electric tailgate of various models and restore the electric tailgate of foot power; DVD function (support DTS disc, CD upload); the ambient light function; the blind spot monitoring function; the reversing image function; tire pressure monitoring function; the shift paddles; the cruise control function; the double lock function; the former radar function; the tank lock; heated/ventilated seats; the heated steering wheel; 494/405 second-generation terrain
- Change the barrel meter to LCD meter
- U.S.-regulated vehicles to restore the standard navigation method
35. Radar circuit diagram before restoration Twelve more ways to “Use original equipment to restore high-end car configuration
Need it? Write to me for details.
motorstate
83
105
#3
Added JLR Pathfinder + SDD Paper Book tricks and secrets (key learn, ccf editor retrofit and programming)
Added
JLR TOPIx Cloud (for 1 year)
Added User Guide for JLR CCF Editor 8.
And was released a new version of the JLR CCF Editor 8 (for Pathfinder, SDD) now with the latest parameter set covering all models including MY23, if you would like to upgrade it cost of $49. Please respond with your license number and I'll send the link to the new version a new license will be required to run this.
